SSH (Secure Shell) Server and Client
| Document revision: | 2.0 (Fri Mar 05 09:09:40 GMT 2004) |
| Applies to: | V2.9 |
General Information
Summary
SSH Client authenticates server and encrypts traffic between the client and server. You can use SSH just the same way as telnet - you run the client, tell it where you want to connect to, give your username and password, and everything is the same after that. After that you won't be able to tell that you're using SSH. The SSH feature can be used with various SSH Telnet clients to securely connect to and administrate the router.
The MikroTik RouterOS supports:
- SSH 1.3, 1.5, and 2.0 protocol standards
- server functions for secure administration of the router
- telnet session termination with 40 bit RSA SSH encryption is supported
- secure ftp is supported
- preshared key authentication is not supported
The MikroTik RouterOS has been tested with the following SSH telnet terminals:
- PuTTY
- Secure CRT
- OpenSSH GNU/Linux client
Specifications
Packages required: securityLicense required: Level1
Submenu level: /system ssh
Standards and Technologies: SSH
Hardware usage: Not significant
Related Documents
Additional Resources
SSH Server
Submenu level: /ip serviceDescription
SSH Server is already up and running after MikroTik router installation. The default port of the service is 22. You can set a different port number.
Property Description
name (name) - service name port (integer: 1..65535) - port the service listens to address (IP address/netmask; default: 0.0.0.0/0) - IP address from which the service is accessibleExample
Let's change the default SSH port (22) to 65 on which the SSH server listens for requests:
[admin@MikroTik] ip service> set ssh port=65 [admin@MikroTik] ip service> print Flags: X - disabled, I - invalid # NAME PORT ADDRESS CERTIFICATE 0 telnet 23 0.0.0.0/0 1 ftp 21 0.0.0.0/0 2 www 80 0.0.0.0/0 3 ssh 65 0.0.0.0/0 4 X www-ssl 443 0.0.0.0/0 [admin@MikroTik] ip service>
SSH Client
Command name: /system sshProperty Description
port (integer; default: 22) - which TCP port to use for SSH connection to a remote host user (text; default: admin) - username for the SSH loginExample
[admin@MikroTik] > /system ssh 192.168.0.1 user=pakalns port=22 admin@192.168.0.1's password: MMM MMM KKK TTTTTTTTTTT KKK MMMM MMMM KKK TTTTTTTTTTT KKK MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK MikroTik RouterOS 2.9rc7 (c) 1999-2005 http://www.mikrotik.com/ Terminal unknown detected, using single line input mode [admin@MikroTik] >
