Skip to main content
SXTsq Lite2
Low-cost small-size 10dBi 2.4GHz dual chain integrated CPE/Backbone
IP 54
Outdoors
PoE
SXTsq Lite2
Product image
Product image
Product image
Product image thumbnail
The SXTsq Lite2 is a compact and lightweight outdoor wireless device with an integrated antenna. Perfect for point-to-point links or as a CPE unit. It is compact, weatherproof and easy to mount.
The SXTsq Lite2 retains a 10 dBi antenna like the SXT Lite2, our previous model, yet the antenna design has been improved and the physical size has been dramatically reduced - the SXTsq is two times thinner.
Specification
Specifications
  • Product code RBSXTsq2nD
  • Suggested price $39.00
  • Architecture MIPSBE
  • CPU QCA9533
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Dimensions 129 x 129 x 34 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 5 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 10
  • Wireless 2.4 GHz chip model QCA9533
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.5 download files for mipsbe devices.
System Package
More
Netinstall:
More in download page
