Small dual-band 2.4 / 5GHz white weatherproof wireless access point for mounting on a ceiling, wall or pole
The wAP ac is a small weatherproof wireless access point for your mobile devices, perfect for installation outside your house, in the garden, on your porch or anywhere else where you need wireless access from your phone or computer.
The device has one Gigabit Ethernet port, it supports 802.11a/b/g/n/ac wireless protocols and can work at both the 2.4GHz and 5GHz frequencies simultaneously. It looks unobtrusive and sleek.
The wAP ac is weatherproof and can be fixed to any external wall from the inside of the case - so that it is securely attached to it’s mounting location.
We have two versions available.
- RBwAPG-5HacT2HnD (International) supports 2412-2484MHz and 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
- RBwAPG-5HacT2HnD-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
| RBwAPG-5HacT2HnD | QCA9556 one port test | ||||||
| Mode | Configuration | 1518 byte | 512 byte | 64 byte | |||
| kpps | Mbps | kpps | Mbps | kpps | Mbps | ||
| Bridging | none (fast path) | 81.1 | 984.9 | 132.1 | 541.1 | 159.3 | 81.6 |
| Bridging | 25 bridge filter rules | 51.6 | 626.6 | 52.4 | 214.6 | 59 | 30.2 |
| Routing | none (fast path) | 81.3 | 987.3 | 131.9 | 540.3 | 143.1 | 73.3 |
| Routing | 25 simple queues | 45.2 | 548.9 | 48.9 | 200.3 | 55.6 | 28.5 |
| Routing | 25 ip filter rules | 37.4 | 454.2 | 38 | 155.6 | 37.3 | 19.1 |
