Skip to main content
mAP lite
Tiny size 2.4GHz Dual Chain access point with a 650MHz CPU, 64MB RAM and one Ethernet
PoE
mAP lite
Product image
Product image
Product image
Product image
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
The mAP lite is our smallest wireless access point. It is barely larger than a matchbox, we even had to use a special Ethernet port to match it’s slim profile.
You can carry it anywhere: use as a travel router to extend that hotel internet to all your devices, or as a client device to improve your laptop signal range, the tiny mAP lite will be always with you.
It can also serve as a simple configuration tool for your servers, if there is no ethernet on your mobile device.
The mAP lite is a dual chain 802.11 b/g/n device and operates in 2GHz.
Specification
Specifications
  • Product code RBmAPL-2nD
  • Suggested price $30.00
  • Architecture MIPSBE
  • CPU QCA9533
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Dimensions 48x49x11mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -30°C to 70°C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 1.5
  • Wireless 2.4 GHz chip model QCA9533
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 1
Powering
  • MicroUSB input Voltage 5 V
  • Number of DC inputs 2 (PoE-IN, MicroUSB)
  • Max power consumption 3.5 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 10-60 V
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP20
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.20.6 download files for mipsbe devices.
System Package
More in download page
