Products
Products
    Metal 52 ac 2.4/5GHz software selectable AP/Backbone/CPE with AC support, high TX power, N-male connector, Omni antenna included
    Now with 802.11ac support, a Gigabit Ethernet port and a selectable wireless band (2.4GHz or 5GHz, up to 80 MHz wide channel). The new Gigabit port will help you utilize the full benefit of 802.11ac high speed wireless.
    The Metal 52 ac supports 2.4GHz, 5GHz and all the legacy wireless modes as well (802.11 b/g/n for 2.4GHz and 802.11 a/n/ac for 5GHz).
    We have two versions available.
    - RBMetalG-52SHPacn-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
    - RBMetalG-52SHPacn (International) supports 2412-2484MHz and 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
     Send purchase questions
    Specifications
    Details
    Product code RBMetalG-52SHPacn
    Architecture MIPSBE
    CPU QCA9556
    CPU core count 1
    CPU nominal frequency 720 MHz
    Dimensions 215x60x38mm
    RouterOS license 4
    Operating System RouterOS
    Size of RAM 64 MB
    Storage size 16 MB
    Storage type FLASH
    MTBF Approximately 200'000 hours at 25C
    Tested ambient temperature -40°C to 70°C
    Suggested price $119.00
    Powering
    Details
    Number of DC inputs 1 (PoE-IN)
    Max power consumption 11 W
    Cooling type Passive
    PoE in Passive PoE
    PoE in input Voltage 10-30 V
    Wireless specifications
    Details
    Wireless 2.4 GHz/5 GHz Max data rate 433 Mbit/s
    Wireless 2.4 GHz/5 GHz number of chains 1
    Wireless 2.4 GHz/5 GHz standards 802.11a/n/ac, 802.11b/g/n
    Antenna gain dBi for 2.4 GHz/5 GHz 6
    Wireless 2.4 GHz/5 GHz chip model QCA9889
    Wireless 2.4 GHz/5 GHz generation Wi-Fi 5
    Ethernet
    Details
    10/100/1000 Ethernet ports 1
    Other
    Details
    PCB temperature monitor Yes
    Voltage Monitor Yes
    Beeper Yes
    Certification & Approvals
    Details
    Certification CE, FCC, IC, EAC, ROHS
    IP IP55
    5 GHzTransmit (dBm)Receive Sensitivity
    6MBit/s31-93
    54MBit/s27-78
    MCS030-93
    MCS726-74
    MCS922-69
    2.4 GHzTransmit (dBm)Receive Sensitivity
    1MBit/s31-97
    11MBit/s31-91
    6MBit/s31-93
    54MBit/s28-77
    MCS031-93
    MCS727-72
    Included parts
    BrochureOpen
    Quick GuideOpen
    User ManualOpen
    Mounting dimensionsOpen
    Block DiagramOpen
    RouterOS software manualOpen
    Declaration of conformityOpen (CE)
    FCC Grant of Certification (2.4GHz)Open
    FCC Grant of Certification (5GHz)Open
    High resolution images
    Ethernet test results
    RBMetalG-52SHPacnQCA9556 1G all port test
    ModeConfiguration1518 byte512 byte64 byte
    kppsMbpskppsMbpskppsMbps
    Bridgingnone (fast path)81.2986.1233.1954.8576.7295.3
    Bridging25 bridge filter rules81.2986.1123.7506.7117.860.3
    Routingnone (fast path)81.2986.1233.1954.8454.8232.9
    Routing25 simple queues81.2986.1152.6625137.270.2
    Routing25 ip filter rules69.4842.866.3271.668.735.2
    1. All tests are done with Xena Networks specialized test equipment (XenaBay),and done according to RFC2544 (Xena2544)
    2. Max throughput is determined with 30+ second attempts with 0,1% packet loss tolerance in 64, 512, 1518 byte packet sizes
    3. Test results show device maximum performance, and are reached using mentioned hardware and software configuration, different configurations most likely will result in lower results
    The device has an operating system preinstalled and licensed. No separate purchase is necessary and the product is ready to use. The device includes free software updates for the life of the product or a minimum of 5 years starting from date of purchase..
    Related products
    Download: Full CE declaration (PDF)
    Information about Metal 52 ac
    [BG] Bulgarian С настоящето, "Mikrotikls SIA", декларира, че Metal 52 ac е в съответствие със съществените изисквания и другитеприложими разпоредби на Директива 2014/53/EC.
    [CZ] Czech "Mikrotikls SIA" tímto prohlašuje, že Metal 52 ac splňuje základní požadavky a všechna příslušná ustanoveni Směrnice 2014/53/ES.
    [DK] Danish Undertegnede "Mikrotikls SIA" erklærer herved, at følgende udstyr Metal 52 ac overholder de væsentlige krav og øvrige relevante krav i direktiv 2014/53/EF.
    [DE] German Hiermit erklärt "Mikrotikls SIA", dass sich das Gerät Metal 52 ac in Übereinstimmung mit den grundlegenden Anforderungen und den übrigen einschlägigen Bestimmungen der Richtlinie 2014/53/EG befindet.
    [EE] Estonian Käesolevaga kinnitab "Mikrotikls SIA" seadme Metal 52 ac vastavust direktiivi 2014/53/EÜ põhinõuetele ja nimetatud direktiivist tulenevatele teistele asjakohastele sätetele.
    [GR] Greek ΜΕ ΤΗΝ ΠΑΡΟΥΣΑ Ο ΚΑΤΑΣΚΕΥΑΣΤΗΣ "Mikrotikls SIA" ΔΗΛΩΝΕΙ ΟΤΙ Metal 52 ac ΣΥΜΜΟΡΦΩΝΕΤΑΙ ΠΡΟΣ ΤΙΣ ΟΥΣΙΩΔΕΙΣ ΑΠΑΙΤΗΣΕΙΣ ΚΑΙ ΤΙΣ ΛΟΙΠΕΣ ΣΧΕΤΙΚΕΣ ΔΙΑΤΑΞΕΙΣ ΤΗΣ ΟΔΗΓΙΑΣ 2014/53/ΕΚ
    [EN] English Hereby, "Mikrotikls SIA", declares that this Metal 52 ac is in compliance with the essential requirements and other relevant provisions of Directive 2014/53/EC.
    [ES] Spanish Por la presente, "Mikrotikls SIA", declara que este Metal 52 ac cumple con los requisitos esenciales y otras exigencias relevantes de la Directiva 2014/53/EC.
    [IT] Italian Con la presente "Mikrotikls SIA" dichiara che questo Metal 52 ac è conforme ai requisiti essenziali ed alle altre disposizioni pertinenti stabilite dalla direttiva 2014/53/CE.
    [LV] Latvian Ar šo "Mikrotikls SIA" deklarē, ka Metal 52 ac atbilst Direktīvas 2014/53/EK būtiskajām prasībām un citiem ar to saistītajiem noteikumiem.
    [LT] Lithuanian Šiuo "Mikrotikls SIA" deklaruoja, kad šis Metal 52 ac atitinka esminius reikalavimus ir kitas 2014/53/EB Direktyvos nuostatas
    [HU] Hungarian A "Mikrotikls SIA" ezzennel kijelenti, hogy a Metal 52 ac típusú beren-dezés teljesíti az alapvető követelményeket és más 2014/53/EK irányelvben meghatározott vonatkozó rendelkezéseket.
    [NL] Dutch Hierbij verklaart "Mikrotikls SIA" dat het toestel l Metal 52 ac in overeenstemming is met de essentiële eisen en de andere relevante bepalin-gen van richtlijn 2014/53/EG.
    [PL] Polish Niniejszym "Mikrotikls SIA" deklaruje że Metal 52 ac jest zgodny z zasadniczymi wymaganiami i innymi właściwymi postanowieniami Dyrektywy 2014/53/EC.
    [PT] Portuguese Eu, "Mikrotikls SIA", declaro que o Metal 52 ac cumpre os requisitos essenciais e outras provisões relevantes da Directiva 2014/53/EC.
    [RO] Romanian Prin prezenta, "Mikrotikls SIA", declară că aparatul Metal 52 ac este în conformitate cu cerinţele esenţiale şi cu alte prevederi pertinente ale Directivei 2014/53/CE.
    [SK] Slovak "Mikrotikls SIA" týmto vyhlasuje, že Metal 52 ac spĺňa základné požiadavky a všetky príslušné ustanovenia Smernice 2014/53/ES.
    [SI] Slovenian "Mikrotikls SIA" izjavlja, da je ta Metal 52 ac v skladu z bistvenimi zahtevami in drugimi relevantnimi določili direktive 2014/53/ES.
    [FI] Finish "Mikrotikls SIA" vakuuttaa täten että Metal 52 ac tyyppinen laite on direktiivin 2014/53/EY oleellisten vaatimusten ja sitä koskevien direktiivin muiden ehtojen mukainen.
    [SE] Swedish Denna utrustning är i överensstämmelse med de väsentliga kraven och andra relevanta bestämmelser i direktiv 2014/53/EC.
    [NO] Norwegian "Mikrotikls SIA", Erklærer herved at Metal 52 ac er i samsvar med de grunnleggende krav og øvrige relevante krav i direktiv 2014/53/EF.
