Skip to main content
LHG XL HP5
Dual chain eXtra Large High Power 27dBi 5GHz CPE/Point-to-Point Integrated Antenna
IP 54
Outdoors
PoE
LHG XL HP5
Product image
Product image
Product image thumbnail
The LHG XL HP5 is a 5GHz 802.11 a/n wireless device with an integrated dual polarization 27 dBi grid antenna and high TX output power, designed to reach up to 40km in point-to-point setups at full speed.
The grid design ensures protection against wind, and the fact that the antenna element is built into the wireless unit means no loss on cables.
Shipped as a kit of 4 units (RBLHG-5HPnD-XL4pack) - 4 antennas in a single box
We have two versions available.
LHG XL HP5-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
LHG XL HP5 (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBLHG-5HPnD-XL
  • Suggested price $89.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions Ø 550 x 245 mm;
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 7 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-28 V
Wireless specifications
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n
  • Antenna gain dBi for 5 GHz 27
  • Wireless 5 GHz chip model AR9344
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.23.3 download files for mipsbe devices.
System Package
More in download page
Related Products
