EoIP
Document revision:1.5 (September 11, 2007, 9:06 GMT)
Applies to: V3.0
General Information
Summary
Ethernet over IP (EoIP) Tunneling is a MikroTik RouterOS protocol that creates an Ethernet tunnel between two routers on top of an IP connection. The EoIP interface appears as an Ethernet interface. When the bridging function of the router is enabled, all Ethernet traffic (all Ethernet protocols) will be bridged just as if there where a physical Ethernet interface and cable between the two routers (with bridging enabled). This protocol makes multiple network schemes possible.
Network setups with EoIP interfaces:
Quick Setup Guide
To make an EoIP tunnel between 2 routers which have IP addresses 10.5.8.1 and 10.1.0.1:
  1. On router with IP address 10.5.8.1, add an EoIP interface and set its MAC address:
    /interface eoip add remote-address=10.1.0.1 tunnel-id=1 mac-address=00-00-5E-80-00-01 \
    \... disabled=no
  2. On router with IP address 10.1.0.1, add an EoIP interface and set its MAC address::
    /interface eoip add remote-address=10.5.8.1 tunnel-id=1 mac-address=00-00-5E-80-00-02 \
    \... disabled=no
Now you can add IP addresses to the created EoIP interfaces from the same subnet.
Specifications
Packages required: system
License required: Level1 (limited to 1 tunnel) , Level3
Submenu level: /interface eoip
Standards and Technologies: GRE (RFC1701)
Hardware usage: Not significant
Description
EoIP interface may be configured between two routers that have active IP level connection. The EoIP tunnel may run over an IPIP tunnel, a PPTP 128bit encrypted tunnel, a PPPoE connection, or any other connection that transports IP.
Specific Properties:
EoIP Setup
Property Description
arp (disabled | enabled | proxy-arp | reply-only; default: enabled) - Address Resolution Protocol
mac-address (MAC address) - MAC address of the EoIP interface. The address numeration authority allows to use MAC addresses in the range from 00:00:5E:80:00:00 to 00:00:5E:FF:FF:FF freely. Other addresses can be used, but not recommended. You should keep the MAC addresses unique within one bridged network
mtu (integer; default: 1500) - Maximum Transmission Unit. The default value provides maximal compatibility, although it may lead to decreasing performance on wireless links due to fragmentation. If you can increase MTU on all links inbetween, you may be able to regain optimal performance
name (name; default: eoip-tunnelN) - interface name for reference
remote-address - the IP address of the other side of the EoIP tunnel - must be a MikroTik router
tunnel-id (integer) - a unique tunnel identifier, which must match th other side of the tunnel
Notes
tunnel-id is method of identifying tunnel. There should not be tunnels with the same tunnel-id on the same router. tunnel-id on both participant routers must be equal.
mtu should be set to 1500 to eliminate packet refragmentation inside the tunnel (that allows transparent bridging of Ethernet-like networks, so that it would be possible to transport full-sized Ethernet frame over the tunnel).
When bridging EoIP tunnels, it is highly recommended to set unique MAC addresses for each tunnel for the bridge algorithms to work correctly. For EoIP interfaces you can use MAC addresses that are in the range from 00-00-5E-80-00-00 to 00-00-5E-FF-FF-FF, which IANA has reserved for such cases. Alternatively, you can set the second bit of the first byte to mark the address as locally administered address, assigned by network administrator, and use any MAC address, you just need to ensure they are unique between the hosts connected to one bridge.
Example
To add and enable an EoIP tunnel named to_mt2 to the 10.5.8.1 router, specifying tunnel-id of 1:
[admin@MikroTik] interface eoip> add name=to_mt2 remote-address=10.5.8.1 \
\... tunnel-id 1
[admin@MikroTik] interface eoip> print
  0 X  name="to_mt2" mtu=1500 arp=enabled remote-address=10.5.8.1 tunnel-id=1
[admin@MikroTik] interface eoip> enable 0
  0 R  name="to_mt2" mtu=1500 arp=enabled remote-address=10.5.8.1 tunnel-id=1
EoIP Application Example
Description
Let us assume we want to bridge two networks: 'Office LAN' and 'Remote LAN'. The networks are connected to an IP network through the routers [Our_GW] and [Remote]. The IP network can be a private intranet or the Internet. Both routers can communicate with each other through the IP network.
Example
Our goal is to create a secure channel between the routers and bridge both networks through it. The network setup diagram is as follows:
To make a secure Ethernet bridge between two routers you should:
  1. Create a PPTP tunnel between them. Our_GW will be the pptp server:
    [admin@Our_GW] interface pptp-server> /ppp secret add name=joe service=pptp \
    \... password=top_s3 local-address=10.0.0.1 remote-address=10.0.0.2
    [admin@Our_GW] interface pptp-server> add name=from_remote user=joe
    [admin@Our_GW] interface pptp-server> server set enable=yes
    [admin@Our_GW] interface pptp-server> print
    Flags: X - disabled, D - dynamic, R - running
     #     NAME         USER         MTU        CLIENT-AD... UPTIME   ENCODING
     0     from_remote  joe
    The Remote router will be the pptp client:
    [admin@Remote] interface pptp-client> add name=pptp user=joe \
    \... connect-to=192.168.1.1 password=top_s3 mtu=1500 mru=1500
    [admin@Remote] interface pptp-client> enable pptp
    [admin@Remote] interface pptp-client> print
      0  R name="pptp" mtu=1500 mru=1500 connect-to=192.168.1.1 user="joe"
           password="top_s2" profile=default add-default-route=no
    [admin@Remote] interface pptp-client> monitor pptp
          status: "connected"
          uptime: 39m46s
        encoding: "none"
    See the PPTP Interface Manual for more details on setting up encrypted channels.
  2. Configure the EoIP tunnel by adding the eoip tunnel interfaces at both routers. Use the ip addresses of the pptp tunnel interfaces when specifying the argument values for the EoIP tunnel:
    [admin@Our_GW] interface eoip> add name="eoip-remote" tunnel-id=0 \
    \... remote-address=10.0.0.2
    [admin@Our_GW] interface eoip> enable eoip-remote
    [admin@Our_GW] interface eoip> print
      0    name=eoip-remote mtu=1500 arp=enabled remote-address=10.0.0.2 tunnel-id=0
    [admin@Remote] interface eoip> add name="eoip" tunnel-id=0 \
    \... remote-address=10.0.0.1
    [admin@Remote] interface eoip> enable eoip-main
    [admin@Remote] interface eoip> print
      0   name=eoip mtu=1500 arp=enabled remote-address=10.0.0.1 tunnel-id=0
    [Remote] interface eoip>
  3. Enable bridging between the EoIP and Ethernet interfaces on both routers.
    On the Our_GW:
    [admin@Our_GW] interface bridge> add
    [admin@Our_GW] interface bridge> print
     0  R name="bridge1" mtu=1500 arp=enabled mac-address=00:00:00:00:00:00
          protocol-mode=none priority=0x8000 auto-mac=yes
          admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s
          transmit-hold-count=6 ageing-time=5m
    [admin@Our_GW] interface bridge> port add bridge=bridge1 interface=eoip-remote
    [admin@Our_GW] interface bridge> port add bridge=bridge1 interface=office-eth
    [admin@Our_GW] interface bridge> port print
    Flags: X - disabled, I - inactive, D - dynamic
     #    INTERFACE      BRIDGE  PRIORITY PATH-COST
     0    eoip-remote    bridge1 128      10
     1    office-eth     bridge1 128      10
    And the same for the Remote:
    [admin@Remote] interface bridge> add
    [admin@Remote] interface bridge> print
    [admin@Remote] interface bridge> port add bridge=bridge1 interface=ether
    [admin@Remote] interface bridge> port add bridge=bridge1 interface=eoip-main
    [admin@Remote] interface bridge> port print
     0    ether          bridge1 128      10
     1    eoip-main      bridge1 128      10
  4. Addresses from the same network can be used both in the Office LAN and in the Remote LAN.
Troubleshooting
Description
