Support Output File
Document revision:2.2 (January 23, 2008, 16:06 GMT)
Applies to: V3.0
General Information
Summary
The support file is used for debugging MikroTik RouterOS and to solve the support questions faster. All MikroTik Router information is saved in a binary file, which is stored on the router and can be downloaded from the router using ftp. This file does not contain RouterOS user paswords, so you are not disclosing access information by sending us this file.
Specifications
Packages required: system
License required: Level1
Submenu level: /system
Hardware usage: Not significant
Generating Support Output File
Command name: /system sup-output
Example
To make a Support Output File:
[admin@MikroTik] > system sup-output
creating supout.rif file, might take a while
done
[admin@MikroTik] >
To see the files stored on the router:
[admin@MikroTik] > file print
 # NAME                         TYPE SIZE                 CREATION-TIME
 0 supout.rif                   .r.. 277042               jan/23/2008 18:03:29
[admin@MikroTik] >
Connect to the router using FTP and download the supout.rif file using BINARY file transfer mode. Send the supout.rif file to MikroTik Support support@mikrotik.com with detailed description of the problem.
