MNDP
Document revision: | 1.5 (January 23, 2008, 16:06 GMT) |
Applies to: | V3.0 |
General Information
Summary
The MikroTik Neighbor Discovery Protocol (MNDP) eases network configuration and management by enabling each MikroTik router to discover other connected MikroTik routers and learn information about the system along with features which are enabled. The MikroTik routers can automatically use learned information to set up some features with minimal or no configuration.
MNDP features:
- works on IP level connections
- works on all non-dynamic interfaces
- distributes basic information on the software version
- distributes information on configured features that should interoperate with other MikroTik routers
MikroTik RouterOS is able to discover both MNDP and CDP (Cisco Discovery Protocol) devices.
Specifications
Packages required: systemLicense required: Level1
Submenu level: /ip neighbor
Standards and Technologies: MNDP
Hardware usage: Not significant
Related Documents
Description
MNDP basic function is to assist with automatic configuration of features that are only available between MikroTik routers. Currently this is used for the 'Packet Packer' feature. The 'Packet Packer' may be enabled on a per interface basis. The MNDP protocol will then keep information about what routers have enabled the 'unpack' feature and the 'Packet Packer' will be used for traffic between these routers.
Specific features
- works on interfaces that support IP protocol and have at least one IP address and on all ethernet-like interfaces even without IP addresses
- is enabled by default for all new Ethernet-like interfaces -- Ethernet, wireless, EoIP, IPIP tunnels, PPTP-static-server
- when older versions on the RouterOS are upgraded from a version without discovery to a version with discovery, current Ethernet like interfaces will not be automatically enabled for MNDP
- uses UDP protocol port 5678
- a UDP packet with router info is broadcasted over the interface every 60 seconds
- every 30 seconds, the router checks if some of the neighbor entries are not stale
- if no info is received from a neighbor for more than 180 seconds the neighbor information is discarded
Setup
Submenu level: /ip neighbor discoveryProperty Description
discover (yes | no; default: yes) - specifies whether the neighbour discovery is enabled or notname (read-only: name) - interface name for referenceExample
To disable MNDP protocol on Public interface:
[admin@MikroTik] ip neighbor discovery> set Public discover=no [admin@MikroTik] ip neighbor discovery> print # NAME DISCOVER 0 Public no 1 Local yes
Neighbour List
Submenu level: /ip neigborDescription
This submenu allows you to see the list of neighbours discovered
address (read-only: IP address) - IP address of the neighbour routerage (read-only: time) - specifies the record's age in seconds (time from the last update)identity (read-only: text) - system identity of the neighbour routerinterface (read-only: name) - local interface name the neighbour is connected tomac-address (read-only: MAC address) - MAC address of the neighbour routerplatform (read-only: text) - hardware/software platform type of neighbour routersoftwate-id (read-only: text) - Software ID of the neighbout MikroTik RouterOS routerunpack (read-only: none | simple | compress-headers | compress-all) - identifies if the interface of the neighbour router is unpacking packets packed with M3Puptime (read-only: time) - uptime of the neighbour routerversion (read-only: text) - operating system or firmware version of the neighbour routerExample
To view the table of discovered neighbours:
[admin@MikroTik] ip neighbor> pri # INTERFACE ADDRESS MAC-ADDRESS IDENTITY VERSION 0 ether2 10.1.0.113 00:0C:42:00:02:06 ID 2.9beta5 1 ether2 1.1.1.3 00:0C:42:03:02:ED MikroTik 2.9beta5 [admin@MikroTik] ip neighbor>
