Filter
Document revision: | 2.8 (February 11, 2008, 4:14 GMT) |
Applies to: | V3.0 |
General Information
Summary
The firewall implements packet filtering and thereby provides security functions that are used to manage data flow to, from and through the router. Along with the Network Address Translation it serve as a tool for preventing unauthorized access to directly attached networks and the router itself as well as a filter for outgoing traffic.
Quick Setup Guide
To add a firewall rule which drops all TCP packets that are destined to port 135 and going through the router, use the following command:
/ip firewall filter add chain=forward dst-port=135 protocol=tcp action=drop
To deny acces to the router via Telnet (protocol TCP, port 23), type the following command:
/ip firewall filter add chain=input protocol=tcp dst-port=23 action=drop
To only allow not more than 5 simultaneous connections from each of the clients, do the following:
/ip firewall filter add chain=forward protocol=tcp tcp-flags=syn connection-limit=6,32 action=drop
Specifications
Packages required: systemLicense required: Level1 (P2P filters limited to 1) , Level3
Submenu level: /ip firewall filter
Standards and Technologies: IP, RFC2113
Hardware usage: Increases with filtering rules count
Firewall Filter
Submenu level: /ip firewall filterDescription
Network firewalls keep outside threats away from sensitive data available inside the network. Whenever different networks are joined together, there is always a threat that someone from outside of your network will break into your LAN. Such break-ins may result in private data being stolen and distributed, valuable data being altered or destroyed, or entire hard drives being erased. Firewalls are used as a means of preventing or minimizing the security risks inherent in connecting to other networks. Properly configured firewall plays a key role in efficient and secure network infrastrure deployment.
MikroTik RouterOS has very powerful firewall implementation with features including:
- stateful packet inspection
- Layer-7 protocol detection
- peer-to-peer protocols filtering
traffic classification by:
- source MAC address
- IP addresses (network or list) and address types (broadcast, local, multicast, unicast)
- port or port range
- IP protocols
- protocol options (ICMP type and code fields, TCP flags, IP options and MSS)
- interface the packet arrived from or left through
- internal flow and connection marks
- DSCP byte
- packet content
- rate at which packets arrive and sequence numbers
- packet size
- packet arrival time
- and much more!
The firewall operates by means of firewall rules. A rule is a definitive form expression that tells the router what to do with a particular IP packet. Each rule consists of two parts that are the matcher which matches traffic flow against given conditions and the action which defines what to do with the mathched packets. Rules are organized in chains for better management.
The filter facility has three default chains: input, forward and output that are responsible for traffic coming from, through and to the router, respectively. New user-defined chains can be added, as necessary. Since these chains have no default traffic to match, rules with action=jump and relevant jump-target should be added to one or more of the three default chains.
Filter ChainsAs mentioned before, the firewall filtering rules are grouped together in chains. It allows a packet to be matched against one common criterion in one chain, and then passed over for processing against some other common criteria to another chain. For example a packet should be matched against the IP address:port pair. Of course, it could be achieved by adding as many rules with IP address:port match as required to the forward chain, but a better way could be to add one rule that matches traffic from a particular IP address, e.g.: /ip firewall filter add src-address=1.1.1.2/32 jump-target="mychain"
and in case of successfull match passes control over the IP packet to some other chain, id est
mychain in this example. Then rules that perform matching against separate ports can be added to mychain chain without specifying the IP addresses.
There are three predefined chains, which cannot be deleted:
- input - used to process packets entering the router through one of the interfaces with the destination IP address which is one of the router's addresses. Packets passing through the router are not processed against the rules of the input chain
- forward - used to process packets passing through the router
- output - used to process packets originated from the router and leaving it through one of the interfaces. Packets passing through the router are not processed against the rules of the output chain
When processing a chain, rules are taken from the chain in the order they are listed there from top to bottom. If a packet matches the criteria of the rule, then the specified action is performed on it, and no more rules are processed in that chain (the exception is the passthrough action). If a packet has not matched any rule within the chain, then it is accepted.
Property Description
action (accept | add-dst-to-address-list | add-src-to-address-list | drop | jump | log | passthrough | reject | return | tarpit; default: accept) - action to undertake if the packet matches the ruleadd-dst-to-address-list - adds destination address of an IP packet to the address list specified by address-list parameter
add-src-to-address-list - adds source address of an IP packet to the address list specified by address-list parameter
drop - silently drop the packet (without sending the ICMP reject message)
jump - jump to the chain specified by the value of the jump-target parameter
log - each match with this action will add a message to the system log
passthrough - ignores this rule and goes on to the next one
reject - reject the packet and send an ICMP reject message
return - passes control back to the chain from where the jump took place
tarpit - captures and holds incoming TCP connections (replies with SYN/ACK to the inbound TCP SYN packet)
invalid - a packet which could not be identified for some reason. This includes out of memory condition and ICMP errors which do not correspond to any known connection. It is generally advised to drop these packets
new - a packet which begins a new TCP connection
related - a packet which is related to, but not part of an existing connection, such as ICMP errors or a packet which begins FTP data connection (the later requires enabled FTP connection tracking helper under /ip firewall service-port)
local - matches addresses assigned to router's interfaces
broadcast - the IP packet is sent from one point to all other points in the IP subnetwork
multicast - this type of IP addressing is responsible for transmission from one or more points to a set of other points
time - specifies the time interval over which the packet rate is measured
burst - number of packets to match in a burst
mode - the classifier(-s) for packet rate limiting
expire - specifies interval after which recorded IP addresses / ports will be deleted
from-client - true, if a packet comes from any HotSpot client
http - true, if a HotSpot client sends a packet to the address and port previously detected as his proxy server (Universal Proxy technique) or if the destination port is 80 and transparent proxying is enabled for that particular client
local-dst - true, if a packet has local destination IP address
to-client - true, if a packet is sent to a client
loose-source-routing - match packets with loose source routing option. This option is used to route the internet datagram based on information supplied by the source
no-record-route - match packets with no record route option. This option is used to route the internet datagram based on information supplied by the source
no-router-alert - match packets with no router alter option
no-source-routing - match packets with no source routing option
no-timestamp - match packets with no timestamp option
record-route - match packets with record route option
router-alert - match packets with router alter option
strict-source-routing - match packets with strict source routing option
timestamp - match packets with timestamp
counter - specifies which counter to use. A counter increments each time the rule containing nth match matches
packet - match on the given packet number. The value by obvious reasons must be between 0 and every. If this option is used for a given counter, then there must be at least every+1 rules with this option, covering all values between 0 and every inclusively.
max - specifies upper boundary of the size range
DelayThreshold - delay for the packets with different destination ports coming from the same host to be treated as possible port scan subsequence
LowPortWeight - weight of the packets with privileged (<=1024) destination port
HighPortWeight - weight of the packet with non-priviliged destination port
cwr - congestion window reduced
ece - ECN-echo flag (explicit congestion notification)
fin - close connection
psh - push function
rst - drop connection
syn - new connection
urg - urgent data
Notes
Because the NAT rules are applied first, it is important to hold this in mind when setting up firewall rules, since the original packets might be already modified by the NAT
Filter Applications
Protect your RouterOS router
To protect your router, you should not only change admin's password but also set up packet filtering. All packets with destination to the router are processed against the ip firewall input chain. Note, that the input chain does not affect packets which are being transferred through the router.
/ ip firewall filter add chain=input connection-state=invalid action=drop \ comment="Drop Invalid connections" add chain=input connection-state=established action=accept \ comment="Allow Established connections" add chain=input protocol=udp action=accept \ comment="Allow UDP" add chain=input protocol=icmp action=accept \ comment="Allow ICMP" add chain=input src-address=192.168.0.0/24 action=accept \ comment="Allow access to router from known network" add chain=input action=drop comment="Drop anything else"
Protecting the Customer's Network
To protect the customer's network, we should check all traffic which goes through router and block unwanted. For icmp, tcp, udp traffic we will create chains, where will be droped all unwanted packets:
/ip firewall filter add chain=forward protocol=tcp connection-state=invalid \ action=drop comment="drop invalid connections" add chain=forward connection-state=established action=accept \ comment="allow already established connections" add chain=forward connection-state=related action=accept \ comment="allow related connections"
Block IP addreses called "bogons":
add chain=forward src-address=0.0.0.0/8 action=drop add chain=forward dst-address=0.0.0.0/8 action=drop add chain=forward src-address=127.0.0.0/8 action=drop add chain=forward dst-address=127.0.0.0/8 action=drop add chain=forward src-address=224.0.0.0/3 action=drop add chain=forward dst-address=224.0.0.0/3 action=drop
Make jumps to new chains:
add chain=forward protocol=tcp action=jump jump-target=tcp add chain=forward protocol=udp action=jump jump-target=udp add chain=forward protocol=icmp action=jump jump-target=icmp
Create tcp chain and deny some tcp ports in it:
add chain=tcp protocol=tcp dst-port=69 action=drop \ comment="deny TFTP" add chain=tcp protocol=tcp dst-port=111 action=drop \ comment="deny RPC portmapper" add chain=tcp protocol=tcp dst-port=135 action=drop \ comment="deny RPC portmapper" add chain=tcp protocol=tcp dst-port=137-139 action=drop \ comment="deny NBT" add chain=tcp protocol=tcp dst-port=445 action=drop \ comment="deny cifs" add chain=tcp protocol=tcp dst-port=2049 action=drop comment="deny NFS" add chain=tcp protocol=tcp dst-port=12345-12346 action=drop comment="deny NetBus" add chain=tcp protocol=tcp dst-port=20034 action=drop comment="deny NetBus" add chain=tcp protocol=tcp dst-port=3133 action=drop comment="deny BackOriffice" add chain=tcp protocol=tcp dst-port=67-68 action=drop comment="deny DHCP"
Deny udp ports in udp chain:
add chain=udp protocol=udp dst-port=69 action=drop comment="deny TFTP" add chain=udp protocol=udp dst-port=111 action=drop comment="deny PRC portmapper" add chain=udp protocol=udp dst-port=135 action=drop comment="deny PRC portmapper" add chain=udp protocol=udp dst-port=137-139 action=drop comment="deny NBT" add chain=udp protocol=udp dst-port=2049 action=drop comment="deny NFS" add chain=udp protocol=udp dst-port=3133 action=drop comment="deny BackOriffice"
Allow only needed icmp codes in icmp chain:
add chain=icmp protocol=icmp icmp-options=0:0 action=accept \ comment="drop invalid connections" add chain=icmp protocol=icmp icmp-options=3:0 action=accept \ comment="allow established connections" add chain=icmp protocol=icmp icmp-options=3:1 action=accept \ comment="allow already established connections" add chain=icmp protocol=icmp icmp-options=4:0 action=accept \ comment="allow source quench" add chain=icmp protocol=icmp icmp-options=8:0 action=accept \ comment="allow echo request" add chain=icmp protocol=icmp icmp-options=11:0 action=accept \ comment="allow time exceed" add chain=icmp protocol=icmp icmp-options=12:0 action=accept \ comment="allow parameter bad" add chain=icmp action=drop comment="deny all other types"
