Web Proxy
Document revision: | 1.5 (December 12, 2007, 11:44 GMT) |
Applies to: | V3.0 |
General Information
Summary
The MikroTik RouterOS implements the following proxy server features:
- Regular HTTP proxy
- Transparent proxy. Can be transparent and regular at the same time
- Access list by source, destination, URL and requested method
- Cache access list (specifies which objects to cache, and which not)
- Direct Access List (specifies which resources should be accessed directly, and which - through another proxy server)
- Logging facility
Quick Setup Guide
To set up a 1 GiB large web cache, which will listen on port 8000, do the following:
[admin@MikroTik] ip proxy> set enabled=yes port=8000 max-cache-size=1048576 [admin@MikroTik] ip proxy> print enabled: yes src-address: 0.0.0.0 port: 8000 parent-proxy: 0.0.0.0 parent-proxy-port: 0 cache-drive: system cache-administrator: "webmaster" max-cache-size: 1048576KiB cache-on-disk: no max-client-connections: 600 max-server-connections: 600 max-fresh-time: 3d serialize-connections: no always-from-cache: no cache-hit-dscp: 4 [admin@MikroTik] ip proxy>
Remember to secure your proxy by preventing unauthorized access to it, otherwise it may be used as an open proxy. Also you need to setup destination NAT in order to utilize transparent proxying facility:
[admin@MikroTik] ip firewall nat> add chain=dstnat protocol=tcp dst-port=80 action=redirect to-ports=8000 [admin@MikroTik] ip firewall nat>
Specifications
Packages required: web-proxyLicense required: Level3
Submenu level: /ip web-proxy
Standards and Technologies: HTTP/1.0, HTTP/1.1, FTP
Hardware usage: uses memory and disk space, if available (see description below)
Description
Web proxy performs Internet object cache function by storing requested Internet objects, i.e., data available via HTTP and FTP protocols on a system positioned closer to the recipient than the site the data is originated from. Here 'closer' means increased path reliability, speed or both. Web browsers can then use the local proxy cache to speed up access and external reduce bandwidth consumption.
When setting up Web proxy, make sure it serves only your clients, and is not misused as relay. Please read the security notice in the Access List Section!
Note that it may be useful to have Web proxy running even with no cache when you want to use it as something like HTTP and FTP firewall (for example, denying access to mp3 files) or to redirect requests to external proxy with large cache drives transparently.
Setup
Submenu level: /ip proxyProperty Description
always-from-cache (yes | no; default: no) - ignore client refresh requests if the content is considered freshcache-administrator (text; default: webmaster) - administrator's e-mail displayed on proxy error pagecache-drive (system | name; default: system) - specifies the target disk drive to be used for storing cached objects. You can use console completion to see the list of available drivescache-hit-dscp (integer: 0..63) - automatically mark cache hit with the provided DSCP valuecache-on-disk (yes | no; default: no) - whether to store cache files on disk or in RAM filesystemenabled (yes | no; default: no) - specifies whether the web proxy is enabledmax-cache-size (none | unlimited | integer: 0..4294967295; default: none) - specifies the maximal disk cache size, measured in kibibytesmax-client-connections (integer; default: 600) - maximum number of concurrent client connections accepted by the proxy. All further connections will be rejectedmax-fresh-time (time; default: 3d) - an upper limit on how long objects without an explicit expiry time will be considered freshmax-server-connections (integer; default: 600) - maximum number of concurrent proxy connections to external servers. All further connections will be put on hold until some of the existing server connections will terminateparent-proxy (IP address:port; default: 0.0.0.0) - IP address of the upper-level (parent) proxyparent-proxy-port (port) - TCP port the parent proxy is active onport (port{1,10}; default: 3128) - specifies the port(s) the web proxy will be listening onserialize-connections (yes | no; default: no) - Do not make multiple connections to server for multiple client connections, if possible (i.e. server supports persistent HTTP connections). Clients will be served on FIFO principle; next client is processed when response transfer to the previous one is completed. If a client is idle for too long (max 5 seconds by default), it will give up waiting and open another connection to the serversrc-address (IP address; default: 0.0.0.0) - the web-proxy will use this address connecting to the parent proxy or web site.Notes
The web proxy listens to all IP addresses that the router has in its IP address list.
Example
To enable proxy on port 8080 with maximal available cache size:
[admin@MikroTik] ip proxy> set enabled=yes port=8080 \ \... max-cache-size=unlimited [admin@MikroTik] ip proxy> print enabled: yes src-address: 0.0.0.0 port: 8000 parent-proxy: 0.0.0.0 parent-proxy-port: 0 cache-drive: system cache-administrator: "webmaster" max-cache-size: 21000KiB cache-on-disk: no max-client-connections: 600 max-server-connections: 600 max-fresh-time: 3d serialize-connections: no always-from-cache: no cache-hit-dscp: 4 [admin@MikroTik] ip proxy>
Note how the max-cache-size value has been calculated from the unlimited to an accurate value in kibibytes
Proxy Monitoring
Command name: /ip proxy monitorProperty Description
cache-used (read-only: integer) - the amount of disk (or RAM if the cache is stored only in RAM) used by the cachefree-disk-space (read-only: integer) - the amount of free space on the cache drivehits (read-only: integer) - number of client requests resolved from the cachehits-sent-to-clients (read-only: integer) - the amount of cache hits sent to clientreceived-from-servers (read-only: integer) - total amount of data received from the external serversrequests (read-only: integer) - total number of client requests to the proxysent-to-clients (read-only: integer) - total amount of data sent to the clientsstatus (read-only: text; default: stopped) - display status information of the proxy serverrunning - proxy is enabled and running
formatting-disk - the cache drive is being formatted
checking-disk - the cache drive is being checked for errors and cache inconsistencies
invalid-address - proxy is enabled, but not running because of invalid address (you should change address or port)
Access List
Submenu level: /ip proxy accessDescription
Access list is configured in the same way as MikroTik RouterOS firewall rules. Rules are processed from the top to the bottom. First matching rule specifies decision of what to do with this connection. There is a total of 6 classifiers that specify matching constraints. If none of these classifiers is specified, the particular rule will match any connection.
If connection is matched by a rule, action property of this rule specifies whether connection will be allowed or not. If some connection does not match any rule, it will be allowed.
action (allow | deny; default: allow) - specifies whether to pass or deny matched packetsdst-address (IP address/netmask) - destination address of the IP packetdst-host (wildcard) - IP address or DNS name used to make connection the target server (this is the string user wrote in his/her browser before specifying port and path to a particular web page)dst-port (port{1,10}) - a list or range of ports the packet is destined tohits (read-only: integer) - the number of requests that were policed by this rulelocal-port (port) - specifies the port of the web proxy via which the packet was received. This value should match one of the ports web proxy is listening on.method (any | connect | delete | get | head | options | post | put | trace) - HTTP method used in the request (see HTTP Methods section at the end of this document)path (wildcard) - name of the requested page within the target server (i.e. the name of a particular web page or document without the name of the server it resides on)redirect-to (text) - in case access is denied by this rule, the user shall be redirected to the URL specified heresrc-address (IP address/netmask) - source address of the IP packetNotes
It is strongly recommended to deny all IP addresses except those behind the router as the proxy still may be used to access your internal-use-only (intranet) web servers. Also, consult examples in Firewall Manual on how to protect your router.
Wildcard property url matches a complete string (i.e., they will not match "example.com" if they are set to "example"). Available wildcards are '*' (match any number of any characters) and '?' (match any one character). Regular expressions are also accepted here, but if the property should be treated as a regular expression, it should start with a colon (':').
Small hits in using regular expressions:
- \\ symbol sequence is used to enter \ character in console
- \. pattern means . only (in regular expressions single dot in pattern means any symbol)
- to show that no symbols are allowed before the given pattern, we use ^ symbol at the beginning of the pattern
- to specify that no symbols are allowed after the given pattern, we use $ symbol at the end of the pattern
- to enter [ or ] symbols, you should escape them with backslash \.
Direct Access List
Submenu level: /ip proxy directDescription
If parent-proxy property is specified, it is possible to tell the proxy server whether to try to pass the request to the parent proxy or to resolve it connecting to the requested server directly. Direct Access List is managed just like Proxy Access List described in the previous chapter except the action argument.
action (allow | deny; default: allow) - specifies the action to perform on matched packetsdeny - resolve matched requests through the parent proxy. If no one is specified this has the same effect as allow
Notes
Unlike the access list, the direct proxy access list has default action equal to deny. It takes place when no rules are specified or a particular request did not match any rule.
Cache Management
Submenu level: /ip proxy cacheDescription
Cache access list specifies, which requests (domains, servers, pages) have to be cached locally by web proxy, and which not. This list is implemented exactly the same way as web proxy access list. Default action is to cache object (if no matching rule is found).
action (allow | deny; default: allow) - specifies the action to perform on matched packetsdeny - do not cache objects from matched request
Connection List
Submenu level: /ip proxy connectionsDescription
This menu contains the list of current connections the proxy is serving
dst-address (read-only: IP address) - IP address of to which data are passed via this proxyprotocol (read-only: text) - protocol namerx-bytes (read-only: integer) - the amount of bytes received from the remote endsrc-address (read-only: IP address) - IP address of the remote end of the connectionstate (read-only: connecting | idle | resolving | rx-body | rx-header | tx-body | tx-header | ) - opened connection stateidle - waiting for next client to serve
resolving - resolving server's DNS name
rx-body - receiving HTTP body
rx-header - receiving HTTP header; or waiting for next request from client
tx-body - transmitting HTTP body
tx-header - transmitting HTTP header
Cache Contents
Submenu level: /ip proxy cache-contentsDescription
This menu lists all the files stored in the cache
file-size (read-only: integer) - size of the stored filelast-accessed (read-only: date) - date of the last access to the resourcelast-accessed-time (read-only: time) - time of the last access to the resourcelast-modified (read-only: date) - modification datelast-modified-time (read-only: time) - modification timeuri (read-only: text) - full resource nameCache inserts
Submenu level: /ip proxy insertsDescription
This menu shows statistics on objects stored in cache (cache inserts)
denied (read-only: integer) - number of inserts denied by the caching listerrors (read-only: integer) - number of disk or other system-related errorsno-memory (read-only: integer) - number of objects not stored because there was not enough memorysuccesses (read-only: integer) - number of successfull cache insertstoo-large (read-only: integer) - number of objects too large to storeCache Lookups
Submenu level: /ip proxy lookupsDescription
This menu shows statistics on objects read from cache (cache lookups)
denied (read-only: integer) - number of requests denied by the access listexpired (read-only: integer) - number of requests found in cache, but expired, and, thus, requested from an external serverno-expiration-info (read-only: integer) - conditional request received for a page that does not have the information to compare the request withnon-cacheable (read-only: integer) - number of requests requested from the external servers unconditionally (as their caching is denied by the cache access list)not-found (read-only: integer) - number of requests not found in the cache, and, thus, requested from an external server (or parent proxy if configured accordingly)successes (read-only: integer) - number of requests found in the cacheComplementary Tools
Description
Web proxy has additional commands to handle non-system drive used for caching purposes and to recover the proxy from severe file system errors.
Command Description
check-drive - checks non-system cache drive for errorsclear-cache - deletes existing cache and creates new cache directoriesformat-drive - formats non-system cache drive and prepairs it for holding the cacheTransparent Mode
Description
Transparent proxy feature performs request caching invisibly to the end-user. This way the user does not notice that his connection is being processed by the proxy and therefore does not need to perform any additional configuration of the software he is using.
This feature may as well be combined with bridge to simplify deployment of web proxy in the existing infrastructure.
To enable the transparent mode, place a firewall rule in destination NAT, specifying which connections, id est traffic coming to which ports should be redirected to the proxy.
Notes
Only HTTP traffic is supported in transparent mode of the web proxy. HTTPS and FTP protocols are not going to work this way.
Example
To configure the router to transparently redirect all connections coming from ether1 interface to port 80 to the web proxy listening on port 8080, then add the following destination NAT rule:
[admin@MikroTik] > /ip firewall nat add in-interface=ether1 dst-port=80 \ \... protocol=tcp action=redirect to-ports=8080 chain=dstnat [admin@MikroTik] > /ip firewall nat print Flags: X - disabled, I - invalid, D - dynamic 0 chain=dstnat protocol=tcp in-interface=ether1 dst-port=80 action=redirect to-ports=8080 [admin@MikroTik] >Notes
Be aware, that you will not be able to access the router's web page after addition of the rule above unless you will change the port for the www service under /ip service submenu to a different value or explicitly exclude router's IP address from those to be matched, like:
/ip firewall nat add in-interface=ether1 dst-port=80 \ \... protocol=tcp action=redirect to-ports=8080 chain=dstnat dst-address=!1.1.1.1/32
It is assumed that the router's address is 1.1.1.1/32.
HTTP Methods
Description
OPTIONSThis method is a request of information about the communication options available on the chain between the client and the server identified by the Request-URI. The method allows the client to determine the options and (or) the requirements associated with a resource without initiating any resource retrieval
GETThis method retrieves whatever information identified by the Request-URI. If the Request-URI refers to a data processing process than the response to the GET method should contain data produced by the process, not the source code of the process procedure(-s), unless the source is the result of the process.
The GET method can become a conditional GET if the request message includes an If-Modified-Since, If-Unmodified-Since, If-Match, If-None-Match, or If-Range header field. The conditional GET method is used to reduce the network traffic specifying that the transfer of the entity should occur only under circumstances described by conditional header field(-s).
The GET method can become a partial GET if the request message includes a Range header field. The partial GET method intends to reduce unnecessary network usage by requesting only parts of entities without transferring data already held by client.
The response to a GET request is cacheable if and only if it meets the requirements for HTTP caching.
HEADThis method shares all features of GET method except that the server must not return a message-body in the response. This retrieves the metainformation of the entity implied by the request which leads to a wide usage of it for testing hypertext links for validity, accessibility, and recent modification.
The response to a HEAD request may be cacheable in the way that the information contained in the response may be used to update previously cached entity identified by that Request-URI.
POSTThis method requests that the origin server accept the entity enclosed in the request as a new subordinate of the resource identified by the Request-URI.
The actual action performed by the POST method is determined by the origin server and usually is Request-URI dependent.
Responses to POST method are not cacheable, unless the response includes appropriate Cache-Control or Expires header fields.
PUTThis method requests that the enclosed entity be stored under the supplied Request-URI. If another entity exists under specified Request-URI, the enclosed entity should be considered as updated (newer) version of that residing on the origin server. If the Request-URI is not pointing to an existing resource, the origin server should create a resource with that URI.
If the request passes through a cache and the Request-URI identifies one or more currently cached entities, those entries should be treated as stale. Responses to this method are not cacheable.
TRACEThis method invokes a remote, application-layer loop-back of the request message. The final recipient of the request should reflect the message received back to the client as the entity-body of a 200 (OK) response. The final recipient is either the origin server or the first proxy or gateway to receive a Max-Forwards value of 0 in the request. A TRACE request must not include an entity.
Responses to this method MUST NOT be cached.
