Software Version Management
Document revision:1.4 (Tue Oct 18 12:24:57 GMT 2005)
Applies to: V2.9
General Information
Summary
To upgrade RouterOS to a more recent version, you can simply transfer the packages to router via ftp, using the binary transfer mode, and then just rebooting the router.
This manual discusses a more advanced method how to upgrade a router automatically. If you have more than one router then this can be useful.
Specifications
Packages required: system
License required: Level1
Submenu level: /system upgrade
Standards and Technologies: None
Hardware usage: Not significant
System Upgrade
Related Documents
Description
In this submenu you can see available packages and are able to choose which to install from a remote router.
At first you upload new packages to the router via ftp, using the binary data transfer mode. Then (from another router, which you will upgrade) add the router's IP on which are the packages listed in the /system upgrade upgrade-package-source list. Afterwards, you type /system upgrade refresh to update the available package list. To see all available packages, choose /system upgrade print command.
Property Description
download - download packages from list by specifying their numbers
download-all - download all packages that are needed for the upgrade (packages which are available in '/system package print' list)
name (read-only: name) - package name
refresh - updates currently available package list
source (read-only: IP address) - source IP address of the router from which the package list entry is retrieved
status (read-only: available | scheduled | downloading | downloaded | installed) - package status
version (read-only: text) - version of the package
Example
See the available packages:
[admin@MikroTik] system upgrade> print
 # SOURCE          NAME             VERSION      STATUS      COMPLETED
 0 192.168.25.8    advanced-tools   2.9          available
 1 192.168.25.8    dhcp             2.9          available
 2 192.168.25.8    hotspot          2.9          available
 3 192.168.25.8    isdn             2.9          available
 4 192.168.25.8    ntp              2.9          available
 5 192.168.25.8    ppp              2.9          available
 6 192.168.25.8    routerboard      2.9          available
 7 192.168.25.8    routing          2.9          available
 8 192.168.25.8    security         2.9          available
 9 192.168.25.8    synchronous      2.9          available
10 192.168.25.8    system           2.9          available
11 192.168.25.8    telephony        2.9          available
12 192.168.25.8    ups              2.9          available
13 192.168.25.8    web-proxy        2.9          available
14 192.168.25.8    wireless         2.9          available
To upgrade chosen packages:
[admin@MikroTik] system upgrade> download 0,1,2,5,6,7,8,9,10,13,14
 0 192.168.25.8    advanced-tools   2.9          downloaded
 1 192.168.25.8    dhcp             2.9          downloading 16 %
 2 192.168.25.8    hotspot          2.9          scheduled
 5 192.168.25.8    ppp              2.9          scheduled
 6 192.168.25.8    routerboard      2.9          scheduled
 7 192.168.25.8    routing          2.9          scheduled
 8 192.168.25.8    security         2.9          scheduled
 9 192.168.25.8    synchronous      2.9          scheduled
10 192.168.25.8    system           2.9          scheduled
13 192.168.25.8    web-proxy        2.9          scheduled
14 192.168.25.8    wireless         2.9          scheduled
Adding Package Source
Submenu level: /system upgrade upgrade-package-source
Description
Here can you specify IP address, username and password of the remote hosts from which you will be able to get packages.
address (IP address) - source IP address of the router from which the package list entry will be retrieved
user (text) - username of the remote router
Notes
After specifying a remote router in '/system upgrade upgrade-package-source', you can type '/system upgrade refresh' to refresh the package list and '/system upgrade print' to see all available packages.
Adding an upgrade source you will be prompted for a password.
Example
To add a router, with username admin and no password, from which the packages will be retrieved:
[admin@MikroTik] system upgrade upgrade-package-source> print
# ADDRESS         USER
0 192.168.25.8    admin
