Scripting Host
| Document revision: | 2.7 (Thu Sep 22 13:33:55 GMT 2005) |
| Applies to: | V2.9 |
General Information
Summary
This manual provides introduction to RouterOS built-in powerful scripting language.
Scripting host provides a way to automate some router maintenance tasks by means of executing user-defined scripts bounded to some event occurence. A script consists of configuration commands and expressions (ICE - internal console expression). The configuration commands are standard RouterOS commands, e.g. /ip firewall filter add chain=forward protocol=gre action=drop that are described in the relevant manuals, while expressions are prefixed with : and are accessible from all submenus.
The events used to trigger script execution include, but are not limited to the System Scheduler, the Traffic Monitoring Tool, and the Netwatch Tool generated events.
Specifications
Packages required: systemLicense required: Level1
Submenu level: /system script
Standards and Technologies: None
Hardware usage: Not significant
Related Documents
Console Command Syntax
Description
Console commands are made of the following parts, listed in the order you type them in console:
prefix - indicates whether the command is an ICE, like : in
:putor that the command path starts from the root menu level, like / in[admin@MikroTik] ip firewall mangle> /ping 10.0.0.1
path - a relative path to the desired menu level, like .. filter in
[admin@MikroTik] ip firewall mangle> .. filter print
path_args - this part is required to select some menu levels, where the actual path can vary across different user inputs, like mylist in
[admin@MikroTik] ip firewall mangle> /routeing prefix-list list mylist
action - one of the actions available at the specified menu level, like add in
[admin@MikroTik] ip firewall mangle> /ip firewall filter add chain=forward action=drop
unnamed parameter - these are required by some actions and should be entered in fixed order after the action name, like in 10.0.0.1 in
name[=value] - a sequence of parameter names followed by respective values, if required, like ssid=myssid in
/interface wireless set wlan1 ssid=myssid
Notes
Variable substitution, command substitution and expressions are allowed only for path_args and unnamed parameter values. prefix, path, action and name[=value] pairs can be given only directly, as a word. Therefore, :put (1 + 2) is valid and :("pu" . "t") 3 is not.
Example
The parts of internal console commands are futher explained in the following examples:
/ping 10.0.0.1 count=5
| prefix | / |
| action | ping |
| unnamed parameter | 10.0.0.1 |
| name[=value] | count=5 |
.. ip firewall rule input
| path | .. ip firewall rule |
| path_args | input |
:for i from=1 to=10 do={:put $i}
| prefix | : |
| action | for |
| unnamed parameter | i |
| pname[=value] | from=1 to=10 do={:put $i} |
/interface monitor-traffic ether1,ether2,ipip1
| prefix | / |
| path | interface |
| action | monitor-traffic |
| unnamed parameter | ether1,ether2,ipip1 |
Expression Grouping
Description
This feature provides an easy way to execute commands from within one command level, by enclosing them in braces '{ }'.
Notes
Subsequent script commands are executed from the same menu level as the entire script. Consider the following example:
[admin@MikroTik] ip route> /user {
{... /ip route
{... print}
Flags: X - disabled
# NAME GROUP ADDRESS
0 ;;; system default user
admin full 0.0.0.0/0
1 uuu full 0.0.0.0/0
Although the current command level is changed to /ip route, it has no effect on next commands entered from prompt, therefore print command is still considered to be /user print.
Example
The example below demonstrates how to add two users to the user menu.
{... add name=x password=y group=write
{... add name=y password=z group=read
{... print}
Flags: X - disabled
1 x write 0.0.0.0/0
2 y read 0.0.0.0/0
Variables
Description
RouterOS scripting language suports two types of variables, which are global (system wide) and local (accessible only within the current script), respectively. A variable can be referenced by '$' (dollar) sign followed by the name of the variable with the exception of set and unset commands that take variable name without preceding dollar sign. Variable names should be composed of contain letters, digits and '-' character. A variable must be declared prior to using it in scripts. There are four types of declaration available:
- global - defined by global keyword, global variables can be accessed by all scripts and console logins on the same router. However, global variables are not kept across reboots.
- local - defined by local keyword, local variables are not shared with any other script, other instance of the same script or other console logins. The value of local variable value is lost when script finishes.
- loop index variables - defined within for and foreach statements, these variables are used only in do block of commands and are removed after command completes.
- monitor variables - some monitor commands that have do part can also introduce variables. You can obtain a list of available variables by placing :environment print statement inside the do block of commands.
You can assign a new value to variable using set action. It takes two unnamed parameters: the name of the variable and the new value of the variable. If a variable is no longer needed, it's name can be freed by :unset command. If you free local variable, it's value is lost. If you free global variable, it's value is still kept in router, it just becomes inaccessible from current script.
Notes
Loop variables "shadows" already introduced variables with the same name.
Example
[admin@MikroTik] ip route> / [admin@MikroTik] > :global g1 "this is global variable" [admin@MikroTik] > :put $g1 this is global variable [admin@MikroTik] >
Command Substitution and Return Values
Description
Some console commands are most useful if their output can be feed to other commands as an argument value. In RouterOS console this is done by using the return values from commands. Return values are not displayed on the screen. To get the return value from a command, it should be enclosed in square brackets '[ ]'. Upon execution the return value of the the command will become the value of these brackets. This is called command substitution.
The commands that produce return values are, but not limited to: find, which returns a reference to a particular item, ping, which returns the number of sucessful pings, time, which returns the measured time value, incr and decr, which return the new value of a variable, and add, which returns the internal number of newly created item.
Example
Consider the usage of find command:
[admin@MikroTik] > /interface [admin@MikroTik] interface> find type=ether [admin@MikroTik] interface> [admin@MikroTik] interface> :put [find type=ether] *1,*2 [admin@MikroTik] interface>
This way you can see internal console numbers of items. Naturally, you can use them as arguments in other commands:
[admin@MikroTik] interface> enable [find type=ether] [admin@MikroTik] interface>
Operators
Description
RouterOS console can do simple calculations with numbers, time values, IP addresses, strings and lists. To get result from an expression with operators, enclose it in parentheses '(' and ')'. The expression result serves as a return value for the parentheses.
Command Description
- - unary minus. Inverts given number value.- - binary minus. Substracts two numbers, two time values, two IP addresses or an IP address and a number! - logical NOT. Unary operator, which inverts given boolean value/ - division. Binary operator. Divides one number by another (gives number) or a time value by a number (gives time value).. - concatenation. Binary operator, concatenates two string or append one list to another or appends an element to a list.^ - bitwise XOR. The argumens and the result are both IP addresses~ - bit inversion. Unary operator, which inverts bits in IP address* - multiplication. Binary operator, which can multiply two numbers or a time value by a number.& - bitwise AND The argumens and the result are both IP addresses&& - logical AND. Binary operator. The argumens and the result are both logical values+ - binary plus. Adds two numbers, two time values or a number and an IP address.< - less. Binary operator which compares two numbers, two time values or two IP addresses. Returns boolean value<< - left shift. Binary operator, which shifts IP address by a given amount of bits. The first argument is an IP address, the second is an integer and the result is an IP address.<= - less or equal. Binary operator which compares two numbers, two time values or two IP addresses. Returns boolean value> - greater. Binary operator which compares two numbers, two time values or two IP addresses. Returns boolean value>= - greater or equal. Binary operator which compares two numbers, two time values or two IP addresses. Returns boolean value>> - right shift. Binary operator, which shifts IP address by a given amount of bits. The first argument is an IP address, the second is an integer and the result is an IP address.| - bitwise OR. The argumens and the result are both IP addresses|| - logical OR. Binary operator. The argumens and the result are both logical valuesNotes
When comparing two arrays note, that two arrays are equal only if their respective elements are equal.
Example
Operator priority and evaluation order
[admin@MikroTik] ip firewall rule forward> :put (10+1-6*2=11-12=2+(-3)=-1) false [admin@MikroTik] ip firewall rule forward> :put (10+1-6*2=11-12=(2+(-3)=-1)) true [admin@MikroTik] ip firewall rule forward
logical NOT
[admin@MikroTik] interface> :put (!true) false [admin@MikroTik] interface> :put (!(2>3)) true [admin@MikroTik] interface>
unary minus
[admin@MikroTik] interface> :put (-1<0) true [admin@MikroTik] > 1
bit inversion
[admin@MikroTik] interface> :put (~255.255.0.0) 0.0.255.255 [admin@MikroTik] interface>
sum
[admin@MikroTik] interface> :put (3ms + 5s) 00:00:05.003 [admin@MikroTik] interface> :put (10.0.0.15 + 0.0.10.0) cannot add ip address to ip address [admin@MikroTik] interface> :put (10.0.0.15 + 10) 10.0.0.25 [admin@MikroTik] interface>
subtraction
[admin@MikroTik] interface> :put (15 - 10) 5 [admin@MikroTik] interface> :put (10.0.0.15 - 10.0.0.3) 12 [admin@MikroTik] interface> :put (10.0.0.15 - 12) 10.0.0.3 [admin@MikroTik] interface> :put (15h - 2s) 14:59:58 [admin@MikroTik] interface>
multiplication
[admin@MikroTik] interface> :put (12s * 4) 00:00:48 [admin@MikroTik] interface> :put (-5 * -2) 10 [admin@MikroTik] interface>
division
[admin@MikroTik] interface> :put (10s / 3) 00:00:03.333 [admin@MikroTik] interface> :put (5 / 2) 2 [admin@MikroTik] interface> [admin@MikroTik] > :put (0:0.10 / 3) 00:00:02 [admin@MikroTik] >
comparison
[admin@MikroTik] interface> :put (10.0.2.3<=2.0.3.10) false [admin@MikroTik] interface> :put (100000s>27h) true [admin@MikroTik] interface> :put (60s,1d!=1m,3600s) true [admin@MikroTik] interface> :put (bridge=routing) false [admin@MikroTik] interface> :put (yes=false) false [admin@MikroTik] interface> :put (true=aye) false [admin@MikroTik] interface>
logical AND, logical OR
[admin@MikroTik] interface> :put ((yes && yes) || (yes && no)) true [admin@MikroTik] interface> :put ((no || no) && (no || yes)) false [admin@MikroTik] interface>
bitwise AND, bitwise OR, bitwise XOR
[admin@MikroTik] interface> :put (10.16.0.134 & ~255.255.255.0) 0.0.0.134 [admin@MikroTik] interface>
shift operators
[admin@MikroTik] interface> :put (~((0.0.0.1 << 7) - 1)) 255.255.255.128 [admin@MikroTik] interface>
Concatenation
[admin@MikroTik] interface> :put (1 . 3) 13 [admin@MikroTik] interface> :put (1,2 . 3) 1,2,3 [admin@MikroTik] interface> :put (1 . 3,4) 13,4 [admin@MikroTik] interface> :put (1,2 . 3,4) 1,2,3,4 [admin@MikroTik] interface> :put ((1 . 3) + 1) 14 [admin@MikroTik] interface>
Data types
Description
The RouterOS console differentiates between several data types, which are string, boolean, number, time interval, IP address, internal number and list. The console tries to convert any value to the most specific type first, backing if it fails. The order in which the console attempts to convert an entered value is presented below:
- list
- internal number
- number
- IP address
- time
- boolean
- string
Internal scripting language supplies special functions to explicitly control type conversion. The toarray, tobool, toid, toip, tonum, tostr and totime functions convert a value accordingly to list, boolean, internal number, IP address, number, string or time.
The number type is internally represented as 64 bit signed integer, so the value a number type variable can take is in range from -9223372036854775808 to 9223372036854775807. It is possible to input number value in hexadecimal form, by prefixing it with 0x, e.g.:
[admin@MikroTik] > :global MyVar 0x10 [admin@MikroTik] > :put $MyVar 16 [admin@MikroTik] >
Lists are treated as comma separated sequence of values. Putting whitespaces around commas is not recommended, because it might confuse console about words' boundaries.
Boolean values can be either true or false. Console also accepts yes for true, and no for false.
Internal numbers are preceided * sign.
Time intervals can be entered either using HH:MM:SS.MS notation, e.g.:
[admin@MikroTik] > :put 01:12:1.01 01:12:01.010 [admin@MikroTik] >
or as sequence of numbers, optionally followed by letters specifying the units of time measure (d dor days, h for hours, m for minutes, s for seconds and ms for milliseconds), e.g.:
[admin@MikroTik] > :put 2d11h12 2d11:00:12 [admin@MikroTik] >
As can bee seen, time values with omitted unit specificators are treated as expressed in seconds.
Possible aliases for time units:
- d, day, days - one day, or 24 hours
- h, hour, hours - one hour
- m, min - one minute
- s - one second
- ms - one millisecond, id est 0.001 second
The console also accepts time values with decimal point:
[admin@MikroTik] > :put 0.1day1.2s 02:24:01.200 [admin@MikroTik] >
Command Reference
Description
RouterOS has a number of built-in console commands and expressions (ICE) that do not depend on the current menu level. These commands do not change configuration directly, but they are useful for automating various maintenance tasks. The full ICE list can be accessed by typing '?' after the ':' prefix (therefore it can be safely assumed that all ICE have ':' prefix), for example:
[admin@MikroTik] > : beep execute global list pick time toip typeof delay find if local put toarray tonum while do for led log resolve tobool tostr environment foreach len nothing set toid totime [admin@MikroTik] >
Command Description
beep - forces the built-in PC beeper to produce a signal for length seconds at frequency Hz.frequency (integer; default: 1000) - signal frequency measured in Hz
length (time; default: 100ms) - signal length
[admin@MikroTik] > :beep length=2s frequency=10000 [admin@MikroTik] >
delay-time (time) - amount of time to wait
unnamed (text) - actions to execute repeatedly
while (yes | no) - condition, which is evaluated each time after the execution of enclosed statements
if (yes | no) - condition, which is evaluated once before the execution of enclosed statements
[admin@MikroTik] > {:global i 10; :do {:put $i; :set i ($i - 1);} \
\... while (($i < 11) && ($i > 0)); :unset i;}
10
9
8
7
6
5
4
3
2
1
[admin@MikroTik] >[admin@MikroTik] > :local A "This is a local variable" [admin@MikroTik] > :global B "This is a global one" [admin@MikroTik] > :environment print Global Variables B=This is a global one Local Variables A=This is a local variable [admin@MikroTik] >
unnamed(text | list) - the string or value list the search will be performed in
unnamed(text) - value to be searched for
unnamed(integer) - position after which the search is started
[admin@MikroTik] interface pppoe-server> :put [:find "13sdf1sdfss1sfsdf324333" ] 0 [admin@MikroTik] interface pppoe-server> :put [:find "13sdf1sdfss1sfsdf324333" 3 ] 1 [admin@MikroTik] interface pppoe-server> :put [:find "13sdf1sdfss1sfsdf324333" 3 3] 17 [admin@MikroTik] interface pppoe-server> :put [:find "1,1,1,2,3,3,4,5,6,7,8,9,0,1,2,3" 3 ] 4 [admin@MikroTik] interface pppoe-server> :put [:find "1,1,1,2,3,3,4,5,6,7,8,9,0,1,2,3" 3 3] 4 [admin@MikroTik] interface pppoe-server> :put [:find "1,1,1,2,3,3,4,5,6,7,8,9,0,1,2,3" 3 4] 5 [admin@MikroTik] interface pppoe-server> :put [:find "1,1,1,2,3,3,4,5,6,7,8,9,0,1,2,3" 3 5] 15 [admin@MikroTik]
unnamed (name) - the name of the loop counter variable
from (integer) - start value of the loop counter variable
to (integer) - end value of the loop counter variable
step (integer; default: 1) - increment value. Depending on the loop counter variable start and end values, step parameter can be treated also as decrement
do (text) - contains the command to be executed repeatedly
[admin@MikroTik] > :for i from=1 to=100 step=37 do={:put ($i . " - " . 1000/$i)}
1 - 1000
38 - 26
75 - 13
[admin@MikroTik] >unnamed (name) - the name of the loop counter variable
in (list) - list of values over which to iterate
:foreach i in=[/interface find type=ether ] \
\... do={:put ("+--" . [/interface get $i name]); \
\... :foreach j in=[/ip address find interface=$i]
\... do={:put ("| `--" . [/ip address get $j address])}}
+--ether1
| `--1.1.1.3/24
| `--192.168.50.1/24
| `--10.0.0.2/24
+--ether2
| `--10.10.0.2/24
[admin@MikroTik] >unnamed(name) - name of the variable
unnamed(text) - value, which should be assigned to the variable
[admin@MikroTik] > :global MyString "This is a string" [admin@MikroTik] > :global IPAddr 10.0.0.1 [admin@MikroTik] > :global time 0:10 [admin@MikroTik] > :environment print Global Variables IPAddr=10.0.0.1 time=00:10:00 MyString=This is a string Local Variables [admin@MikroTik] >
unnamed(yes | no) - logical condition, which is evaluated once before the execution of enclosed statements
do(text) - this block of commands is executed if the logical condition evaluates to true
else(text) - this block of commands is executed if the logical condition evaluates to false
[admin@MikroTik] > :if ([:len [/ip firewall filter find]] > 0) do={:put true} else={:put false}
true
[admin@MikroTik] >Check whether the gateway is reachable. In this example, the IP address of the gateway is 10.0.0.254
[admin@MikroTik] > :if ([/ping 10.0.0.254 count=1] = 0) do {:put "gateway unreachable"}
10.0.0.254 ping timeout
1 packets transmitted, 0 packets received, 100% packet loss
gateway unreachable
[admin@MikroTik] >led1(yes | no) - controls first LED
led2(yes | no) - controls second LED
led3(yes | no) - controls third LED
led4(yes | no) - controls fourth LED
length(time) - specifies the length of the action
[admin@MikroTik] > :led led2=yes led3=yes length=5s
unnamed(name) - string or list the length of which should be returned
[admin@MikroTik] > :put [:len gvejimezyfopmekun] 17 [admin@MikroTik] > :put [:len gve,jim,ezy,fop,mek,un] 6 [admin@MikroTik] >
unnamed(text) - first search key
unnamed(text) - second search key
unnamed(text) - third search key
[admin@MikroTik] > :list user hotspot "add " List of console commands under "/" matching "user" and "hotspot" and "add ": ip hotspot profile add name= hotspot-address= dns-name= \ \... html-directory= rate-limit= http-proxy= smtp-server= \ \... login-by= http-cookie-lifetime= ssl-certificate= split-user-domain= \ \... use-radius= radius-accounting= radius-interim-update= copy-from= ip hotspot user add server= name= password= address= mac-address= \ \... profile= routes= limit-uptime= limit-bytes-in= limit-bytes-out= \ \... copy-from= comment= disabled= ip hotspot user profile add name= address-pool= session-timeout= \ \... idle-timeout= keepalive-timeout= status-autorefresh= \ \... shared-users= rate-limit= incoming-filter= outgoing-filter= \ \... incoming-mark= outgoing-mark= open-status-page= on-login= on-logout= copy-from= [admin@MikroTik] >
[admin@MikroTik] > :local MyString "This is a string" [admin@MikroTik] > :local IPAddr 10.0.0.1 [admin@MikroTik] > :local time 0:10 [admin@MikroTik] > :environment print Global Variables Local Variables IPAddr=10.0.0.1 time=00:10:00 MyString=This is a string [admin@MikroTik] >
unnamed(name) - name of the logging facility to send message to
unnamed(text) - the text of the message to be logged
[admin@MikroTik] > :log info "Very Good thing happened. We have received our first packet!" [admin@MikroTik] > /log print follow ... 19:57:46 script,info Very Good thing happened. We have received our first packet! ...
[admin@MikroTik] > :local string qwerty
[admin@MikroTik] > :if ([:pick $string 10]=[:nothing]) do={
{... :put "pick and nothing commands return the same value"}
[admin@MikroTik] >
unnamed(text | list) - the string or value list from which a substring or a subrange should be returned
unnamed(integer) - start position of substring or subrange
unnamed(integer) - end position for substring or subrange
[admin@MikroTik] > :set a 1,2,3,4,5,6,7,8 [admin@MikroTik] > :put [:len $a] 8 [admin@MikroTik] > :put [:pick $a] 1 [admin@MikroTik] > :put [:pick $a 0 4] 1,2,3,4 [admin@MikroTik] > :put [:pick $a 2 4] 3,4 [admin@MikroTik] > :put [:pick $a 2] 3 [admin@MikroTik] > :put [:pick $a 5 1000000] 6,7,8 [admin@MikroTik] > :set a abcdefghij [admin@MikroTik] > :put [:len $a] 10 [admin@MikroTik] > :put [:pick $a] a [admin@MikroTik] > :put [:pick $a 0 4] abcd [admin@MikroTik] > :put [:pick $a 2 4] cd [admin@MikroTik] > :put [:pick $a 2] c [admin@MikroTik] > :put [:pick $a 5 1000000] fghij
unnamed(text) - the text to be echoed to the console
[admin@MikroTik] > :put [/interface get ether1 mtu] 1500 [admin@MikroTik] >
unnamed(text) - domain name to be resolved into an IP address
[admin@MikroTik] ip route> /ip dns set primary-dns=159.148.60.2 [admin@MikroTik] ip route> :put [:resolve www.example.com] 192.0.34.166
unnamed(name) - the name of the variable
unnamed(text) - the new value of the variable
[admin@MikroTik] > :put [:time [:resolve www.example.com ]] 00:00:00.006 [admin@MikroTik] >
unnamed(text) - the console commands to measure execution time of
unnamed(yes | no) - condition, which is evaluated each time before the execution of enclosed statements
do(text) - console commands that should be executed repeatedly
[admin@MikroTik] > :set i 0; :while ($i < 10) do={:put $i; :set i ($i + 1)};
0
1
2
3
4
5
6
7
8
9
[admin@MikroTik] >Special Commands
Description
MonitorIt is possible to access values that are shown by most monitor actions from scripts. A monitor command that has a do parameter can be supplied either script name (see /system scripts), or console commands to execute.
GetMost print commands produce values that are accessible from scripts. Such print commands have a corresponding get command on the same menu level. The get command accepts one parameter when working with regular values or two parameters when working with lists.
Notes
Monitor command with do argument can also be called directly from scripts. It will not print anything then, just execute the given script.
The names of the properties that can be accessed by get are the same as shown by print command, plus names of item flags (like the disabled in the example below). You can use [T ab] key completions to see what properties any particular get action can return.
Example
In the example below monitor action will execute given script each time it prints stats on the screen, and it will assign all printed values to local variables with the same name:
[admin@MikroTik] interface> monitor-traffic ether2 once do={:environment print}
received-packets-per-second: 0
received-bits-per-second: 0bps
sent-packets-per-second: 0
sent-bits-per-second: 0bps
Global Variables
i=1
Local Variables
sent-bits-per-second=0
received-packets-per-second=0
received-bits-per-second=0
sent-packets-per-second=0
Additional Features
Description
To include comment in the console script prefix it with '#'. In a line of script that starts with '#' all characters until the newline character are ignored.
To put multiple commands on a single line separate them with ';'. Console treats ';' as the end of line in scripts.
Any of the {}[]"'\$ characters should be escaped in a reqular string with '\' character. Console takes any character following '\' literally, without assigning any special meaning to it, except for such cases:
\a bell (alarm), character code 7 \b backspace, character code 8 \f form feed, character code 12 \n newline, character code 10 \r carriage return, character code 13 \t tabulation, character code 9 \v vertical tabulation, character code 11 \_ space, character code 32
Note that '\', followed by any amount of whitespace characters (spaces, newlines, carriage returns, tabulations), followed by newline is treated as a single whitespace, except inside quotes, where it is treated as nothing. This is used by console to break up long lines in scripts generated by export commands.
Script Repository
Submenu level: /system scriptDescription
All scripts are stored in the /system script menu along with some service information such as script name, script owner, number of times the script was executed and permissions for particular script.
In RouterOS, a script may be automatically started in three different ways:
- via the scheduler
- on event occurence - for example, the netwatch tool generates an event if a network host it is configured to monitor becomes unaccessible
- by another script
It is also possible to start a script manually via /system script run command.
Property Description
last-started (time) - date and time when the script has been last invoked. The argument is shown only if the run-count!=0.owner (name; default: admin) - the name of the user who created the scriptpolicy (multiple choice: ftp | local | policy | read | reboot | ssh | telnet | test | web | write; default: reboot,read,write,policy,test) - the list of the policies applicable:local - user can log on locally via console
policy - manage user policies, add and remove user
read - user can retrieve the configuration
reboot - user can reboot the router
ssh - user can log on remotely via secure shell
telnet - user can log on remotely via telnet
test - user can run ping, traceroute, bandwidth test
web - user can log on remotely via http
write - user can retrieve and change the configuration
Command Description
run (name) - executes a given scriptunnamed(name) - the name of the script to execute
Notes
You cannot do more in scripts than you are allowed to do by your current user rights, that is, you cannot use disabled policies. For example, if there is a policy group in /user group which allows you ssh,local,telnet,read,write,policy,test,web and this group is assigned to your user name, then you cannot make a script that reboots the router.
Example
The following example is a script for writing message "Hello World!" to the info log:
[admin@MikroTik] system script> add name="log-test" source={:log info "Hello World!"}
[admin@MikroTik] system script> run log-test
[admin@MikroTik] system script> print
0 name="log-test" owner="admin" policy=ftp,reboot,read,write,policy,test,winbox,password last-started=mar/20/2001 22:51:41
run-count=1 source=:log info "Hello World!"
Task Management
Submenu level: /system script jobDescription
This facility is used to manage the active or scheduled tasks.
name (read-only: name) - the name of the script to be referenced when invoking itowner (text) - the name of the user who created the scriptsource (read-only: text) - the script source code itselfExample
[admin@MikroTik] system script> job print # SCRIPT OWNER STARTED 0 DelayeD admin dec/27/2003 11:17:33 [admin@MikroTik] system script>
You can cancel execution of a script by removing it from the job list
[admin@MikroTik] system script> job remove 0 [admin@MikroTik] system script> job print [admin@MikroTik] system script>
Script Editor
Command name: /system script editDescription
RouterOS console has a simple full-screen editor for scripts with support for multiline script writing.
Keyboard Shortcuts- Delete - deletes character at cursor position
- Ctrl+h, backspase - deletes character before cursor. Unindents line
- Tab - indents line
- Ctrl+b, LeftArrow - moves cursor left
- Ctrl+f, RightArrow - moves cursor right
- Ctrl+p, UpArrow - moves cursor up
- Ctrl+n, DownArrow - moves cursor down
- Ctrl+a, Home - moves cursor to the beginning of line or script
- Ctrl+e, End - moves cursor to the end of line or script
- Ctrl+y - inserts contents of buffer at cursor position
- Ctrl+k - deletes characters from cursor position to the end of line
- Ctrl+u - undoes last action
- Ctrl+o - exits editor accepting changes
- Ctrl+x - exits editor discarding changes
Command Description
edit (name) - opens the script specified by the name argument in full-screen editorNotes
All characters that are deleted by backspace, delete or Ctrl+k keys are accumulated in the buffer. Pressing any other key finishes adding to this buffer (Ctrl+y can paste it's contents), and the next delete operation will replace it's contents. Undo doesn't change contents of cut buffer.
Script editor works only on VT102 compatible terminals (terminal names "vt102", "linux", "xterm", "rxvt" are recognized as VT102 at the moment). Delete, backspace and cursor keys might not work with all terminal programs, use 'Ctrl' alternatives in such cases.
Example
The following example shows the script editor window with a sample script open:
This script is used for writing message "hello" and 3 messages "kuku" to the system log.
