Scheduler
| Document revision: | 0.9 (Wed Nov 24 12:48:55 GMT 2004) |
| Applies to: | V2.9 |
General Information
Summary
System Scheduler executes scripts at designated time.
Specifications
Packages required: systemLicense required: Level1
Submenu level: /system scheduler
Standards and Technologies: None
Hardware usage: Not significant
Related Documents
Scheduler Configuration
Description
The scheduler can trigger script execution at a particular time moment, after a specified time interval, or both.
Property Description
interval (time; default: 0s) - interval between two script executions, if time interval is set to zero, the script is only executed at its start time, otherwise it is executed repeatedly at the time interval is specified name (name) - name of the task on-event (name) - name of the script to execute. It must be presented at /system script run-count (read-only: integer) - to monitor script usage, this counter is incremented each time the script is executed start-date (date) - date of the first script execution start-time (time) - time of the first script executionNotes
Rebooting the router will reset run-count counter.
If more than one script has to be executed simultaneously, they are executed in the order they appear in the scheduler configuration. This can be important if one scheduled script is used to disable another one. The order of scripts can be changed with the move command.
If a more complex execution pattern is needed, it can usually be done by scheduling several scripts, and making them enable and disable each other.
if scheduler item has start-time set to startup, it behaves as if start-time and start-date were set to time 3 seconds after console starts up. It means that all scripts having start-time=startup and interval=0 will be executed once each time router boots.
Example
We will add a task that executes the script log-test every hour:
[admin@MikroTik] system script> add name=log-test source=:log message=test
[admin@MikroTik] system script> print
0 name="log-test" source=":log messgae=test" owner=admin run-count=0
[admin@MikroTik] system script> .. scheduler
[admin@MikroTik] system scheduler> add name=run-1h interval=1h
on-event=log-test
[admin@MikroTik] system scheduler> print
Flags: X - disabled
# NAME ON-EVENT START-DATE START-TIME INTERVAL RUN-COUNT
0 run-1h log-test mar/30/2004 06:11:35 1h 0
In another example there will be two scripts added that will change the bandwidth setting of a queue rule "Cust0". Every day at 9AM the queue will be set to 64Kb/s and at 5PM the queue will be set to 128Kb/s. The queue rule, the scripts, and the scheduler tasks are below:
[admin@MikroTik] queue simple> add name=Cust0 interface=ether1 \
\... dst-address=192.168.0.0/24 limit-at=64000
[admin@MikroTik] queue simple> print
0 name="Cust0" target-address=0.0.0.0/0 dst-address=192.168.0.0/24
interface=ether1 limit-at=64000 queue=default priority=8 bounded=yes
[admin@MikroTik] queue simple> /system script
[admin@MikroTik] system script> add name=start_limit source={/queue simple set \
\... Cust0 limit-at=64000}
[admin@MikroTik] system script> add name=stop_limit source={/queue simple set \
\... Cust0 limit-at=128000}
0 name="start_limit" source="/queue simple set Cust0 limit-at=64000"
1 name="stop_limit" source="/queue simple set Cust0 limit-at=128000"
[admin@MikroTik] system scheduler> add interval=24h name="set-64k" \
\... start-time=9:00:00 on-event=start_limit
[admin@MikroTik] system scheduler> add interval=24h name="set-128k" \
\... start-time=17:00:00 on-event=stop_limit
Flags: X - disabled
0 set-64k start... oct/30/2008 09:00:00 1d 0
1 set-128k stop_... oct/30/2008 17:00:00 1d 0
The following example schedules a script that sends each week a backup of router configuration by e-mail.
[admin@MikroTik] system script> add name=e-backup source={/system backup
{... save name=email; /tool e-mail send to="root@host.com" subject=([/system
{... identity get name] . " Backup") file=email.backup}
0 name="e-backup" source="/system backup save name=ema... owner=admin
run-count=0
[admin@MikroTik] system scheduler> add interval=7d name="email-backup" \
\... on-event=e-backup
Flags: X - disabled
0 email-... e-backup oct/30/2008 15:19:28 7d 1
Do not forget to set the e-mail settings, i.e., the SMTP server and From: address under /tool e-mail. For example:
[admin@MikroTik] tool e-mail> set server=159.148.147.198 from=SysAdmin@host.com
[admin@MikroTik] tool e-mail> print
server: 159.148.147.198
Example below will put 'x' in logs each hour from midnight till noon:
[admin@MikroTik] system script> add name=enable-x source={/system scheduler
{... enable x}
[admin@MikroTik] system script> add name=disable-x source={/system scheduler
{... disable x}
[admin@MikroTik] system script> add name=log-x source={:log message=x}
[admin@MikroTik] system scheduler> add name=x-up start-time=00:00:00 \
\... interval=24h on-event=enable-x
[admin@MikroTik] system scheduler> add name=x-down start-time=12:00:00
\... interval=24h on-event=disable-x
[admin@MikroTik] system scheduler> add name=x start-time=00:00:00 interval=1h \
\... on-event=log-x
Flags: X - disabled
0 x-up enable-x oct/30/2008 00:00:00 1d 0
1 x-down disab... oct/30/2008 12:00:00 1d 0
2 x log-x oct/30/2008 00:00:00 1h 0
