Configuration Management
Document revision: | 1.6 (Mon Sep 19 12:55:52 GMT 2005) |
Applies to: | V2.9 |
General Information
Summary
This manual introduces you with commands which are used to perform the following functions:
- system backup
- system restore from a backup
- configuration export
- configuration import
- system configuration reset
Description
The configuration backup can be used for backing up MikroTik RouterOS configuration to a binary file, which can be stored on the router or downloaded from it using FTP. The configuration restore can be used for restoring the router's configuration from a backup file.
The configuration export can be used for dumping out MikroTik RouterOS configuration to the console screen or to a text (script) file, which can be downloaded from the router using FTP. The configuration import can be used to import the router configuration script from a text file.
System reset command is used to erase all configuration on the router. Before doing that, it might be useful to backup the router's configuration.
Note! In order to be sure that the backup will not fail, system backup load command must be used on the same computer with the same hardware where system backup save was done.
System Backup
Submenu level: /system backupDescription
The save command is used to store the entire router configuration in a backup file. The file is shown in the /file submenu. It can be downloaded via ftp to keep it as a backup for your configuration.
To restore the system configuration, for example, after a /system reset, it is possible to upload that file via ftp and load that backup file using load command in /system backup submenu.
Command Description
load name=[filename] - Load configuration backup from a filesave name=[filename] - Save configuration backup to a fileExample
To save the router configuration to file test:
[admin@MikroTik] system backup> save name=test Configuration backup saved [admin@MikroTik] system backup>
To see the files stored on the router:
[admin@MikroTik] > file print # NAME TYPE SIZE CREATION-TIME 0 test.backup backup 12567 sep/08/2004 21:07:50 [admin@MikroTik] >
Example
To load the saved backup file test:
[admin@MikroTik] system backup> load name=test Restore and reboot? [y/N]: y ...
The Export Command
Command name: /exportDescription
The export command prints a script that can be used to restore configuration. The command can be invoked at any menu level, and it acts for that menu level and all menu levels below it. If the argument from is used, then it is possible to export only specified items. In this case export does not descend recursively through the command hierarchy. export also has the argument file, which allows you to save the script in a file on the router to retrieve it later via FTP.
Command Description
file=[filename] - saves the export to a filefrom=[number] - specifies from which item to start to generate the export fileExample
[admin@MikroTik] > ip address print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.1.0.172/24 10.1.0.0 10.1.0.255 bridge1 1 10.5.1.1/24 10.5.1.0 10.5.1.255 ether1 [admin@MikroTik] >
To make an export file:
[admin@MikroTik] ip address> export file=address [admin@MikroTik] ip address>
To make an export file from only one item:
[admin@MikroTik] ip address> export file=address1 from=1 [admin@MikroTik] ip address>
[admin@MikroTik] > file print # NAME TYPE SIZE CREATION-TIME 0 address.rsc script 315 dec/23/2003 13:21:48 1 address1.rsc script 201 dec/23/2003 13:22:57 [admin@MikroTik] >
To export the setting on the display use the same command without the file argument:
[admin@MikroTik] ip address> export from=0,1 # nov/13/2004 13:25:30 by RouterOS 2.9 # software id = MGJ4-MAN # / ip address add address=10.1.0.172/24 network=10.1.0.0 broadcast=10.1.0.255 \ interface=bridge1 comment="" disabled=no add address=10.5.1.1/24 network=10.5.1.0 broadcast=10.5.1.255 \ interface=ether1 comment="" disabled=no [admin@MikroTik] ip address>
The Import Command
Command name: /importDescription
The root level command /import [file_name] restores the exported information from the specified file. This is used to restore configuration or part of it after a /system reset event or anything that causes configuration data loss.
Note that it is impossible to import the whole router configuration using this feature. It can only be used to import a part of configuration (for example, firewall rules) in order to spare you some typing.
Command Description
file=[filename] - loads the exported configuration from a file to routerExample
To load the saved export file use the following command:
[admin@MikroTik] > import address.rsc Opening script file address.rsc Script file loaded successfully [admin@MikroTik] >
Configuration Reset
Command name: /system resetDescription
The command clears all configuration of the router and sets it to the default including the login name and password ('admin' and no password), IP addresses and other configuration is erased, interfaces will become disabled. After the reset command router will reboot.
Command Description
reset - erases router's configurationNotes
If the router has been installed using netinstall and had a script specified as the initial configuration, the reset command executes this script after purging the configuration. To stop it doing so, you will have to reinstall the router.
Example
[admin@MikroTik] > system reset Dangerous! Reset anyway? [y/N]: n action cancelled [admin@MikroTik] >
