License Management
Document revision:3.1 (Thu Mar 03 11:06:06 GMT 2005)
Applies to: V2.9
General Information
Summary
MikroTik RouterOS software has a licensing system with Software License (Software Key) issued for each individual installation of the RouterOS.
Specifications
Packages required: system
License required: Level1
Submenu level: /system license
Hardware usage: Not significant
Description
The Software License can be obtained through the Account Server at www.mikrotik.com after the MikroTik RouterOS has been installed. The Software ID of the installation is required when obtaining the Software License. Please read the MikroTik RouterOS Basic Setup Guide for detailed explanation of the installation and licensing process.
RouterOS allows you to use all its features without registration for about 24 hours from the first run. Note that if you shut the router down, the countdown is paused, and it is resumed only when the router is started again. During this period you must get a key, otherwise you will need to reinstall the system. A purchased license key allows you to use RouterOS features according to the chosen license level for unlimited time, and gives you rights to freely upgrade and downgrade its versions for the term of one or three years since the key was purchased depending on license level. A free registred license key (referred as a DEMO key further on) allows you to use a restricted set of functions for unlimited period of time, but does not allow upgrading and downgrading versions.
There are 6 licensing levels, each providing some additional features. Level 0 means that there is no key and all the features are enabled for one day. Level 2 is a transitional license level from versions prior 2.8, that allows to use all the features were allowed by your original license key for a previus version.
Level number 1 (DEMO) 3 (WISP CPE) 4 (WISP) 5 (WISP 3Y) 6 (Controller 3Y)
Upgrade time - 1 year 1 year 3 years 3 years
Initial Config Support - - 15 days 30 days 30 days
Wireless Client and Bridge - yes yes yes yes
Wireless AP - - yes yes yes
Synchronous interfaces - - yes yes yes
EoIP tunnels 1 unlimited unlimited unlimited unlimited
PPPoE tunnels 1 200 200 500 unlimited
PPTP tunnels 1 200 200 unlimited unlimited
L2TP tunnels 1 200 200 unlimited unlimited
VLAN interfaces 1 unlimited unlimited unlimited unlimited
P2P firewall rules 1 unlimited unlimited unlimited unlimited
NAT rules 1 unlimited unlimited unlimited unlimited
HotSpot active users 1 1 200 500 unlimited
RADIUS client - yes yes yes yes
Queues 1 30 unlimited unlimited unlimited
Web proxy - yes yes yes yes
RIP, OSPF, BGP protocols - yes yes yes yes
Note that Wireless Client and Bridge means that wireless cards can be used in station and bridge modes. Bridge mode allows one wireless station to connect it.
There is a possibility to upgrade your key (i.e. to extend licensing term) from the console or WinBox.
Note that the license is kept on hard drive. You can move the hard drive to another system, but you can not move license on another hard drive. License transfer to another drive is a paid service (unless your hard drive has crashed). Please contact support@mikrotik.com to arrange this. Also note that you must not use MS-DOS format or fdisk utilities or you may loose the license.
Important: the abovementioned limits depict the limits enforced by the license. The actual number of concurrent tunnels, rules, queues, users, etc. will vary depending the combination of features used and the load they place on the MikroTik RouterOS.
License Management
Description
There are three methods of entering a key to the system console:
These methods also apply to WinBox, with the difference that key importing and exporting is happening through the Windows host PC itself. The options available:
Property Description
key (read-only: text) - software license key that unlocks the installation
level (read-only: integer: 0..6) - license level of the installation
software-id (read-only: text) - ID number of the installation
upgradable-until (read-only: text) - the date until which the software version can be upgraded or downgraded
Command Description
import - import a key file
Input Parameters
filename (name) - file name to use as a key
new-upgrade-key - request a new key
Input Parameters
server (IP address) - key server's IP address
user (text) - username to log into the key server
password (text) - password to log into the key server
level (integer: 2..6) - license level to request
pay-method (credit-card | credit-keys | credit-money | debit-keys | debit-money) - Payment method to use
do (text; default: "") - script to execute while the command is running
interval (time; default: 1s) - how frequently to execute the given script
once - if specified, executes the sctipt once, and then terminates the command
Return Values
status - command's execution status
  • Resolving www.mikrotik.com - resolving DNS name
  • Failed to resolve www.mikrotik.com, check your dns settings - check whether DNS client is set up on the router, and that it is allowed to resolve a DNS name on the DNS server set
  • Failed to connect, probably no IP address - self-explanatory
  • Failed to connect, is your router public? - check whether the router has a default route and is able to reack the key server
  • Connecion failed - connection has timed out
  • Bad response from server - try again
  • ERROR: You don't have appropriate debit key! - no existing debit keys on your account matches the requested one
  • ERROR: You don't have enought debit money! - self-explanatory
  • ERROR: Credit key limit exceeded! - self-explanatory
  • ERROR: Your credit limit is exceeded! - self-explanatory
  • ERROR: This payment method is not more allowed! Go to www.mikrotik.com, log on and purchase key there or use other payment methods. - you can not use the selected payment method from the router anymore due to system changes (for credit cards now)
  • ERROR: You must enable this feature in account server (change user information section)! - you should enable Allow to use my account in netinstall feature on the accout server (in change user information section
  • ERROR: Incorrect username or password! - self-explanatory
  • ERROR: You are not allowed to use this service! - please contact sales@mikrotik.com for further assistance
  • Key upgraded successfully - the upgrade procedure has been completed successfully
  • output - exports the current key to a key file
    update-key - request a free update of your existing key to the version's 2.9 one (this can be done during your existing key upgrade term)
    Input Parameters
    Return Values
  • ERROR: Someone has already converted this key! - the requested software ID has already been converted to 2.9 version
  • ERROR: Key for specified software ID is expired. You can purchase new key at www.mikrotik.com website! - you may not update an expired key to the version 2.9, you must purchase a new one
