GPS Synchronization
Document revision:2.0 (Fri Mar 05 08:56:37 GMT 2004)
Applies to: V2.9
General Information
Summary
Global Positioning System (GPS) receiver can be used by MikroTik RouterOS to get the precise location and time (which may be used as NTP time source)
Specifications
Packages required: gps
License required: Level1
Submenu level: /system gps
Standards and Technologies: GPS, NMEA 0183, Simple Text Output Protocol
Hardware usage: Not significant
Related Documents
Description
Global Positioning System (GPS) is used for determining precise location of a GPS receiver. There are two types of GPS service:
GPS system is based on 24 satellites rotating on 6 different orbital planes with 12h orbital period. It makes that at least 5, but usually 6 or more satellites are visible at any time anywhere on the Earth. GPS receiver calculates more or less precise position (latitude, longitude and altitude) and time based on signals received from 4 satellites (three are used to determine position and fourth is used to correct time), which are broadcasting their current positions and UTC time.
MikroTik RouterOS can communicate with many GPS receivers which are able to send the positioning and time via asynchronous serial line using NMEA 0183, NMEA/RTCM or Simple Text Output Protocol. Note that you might need to configure the router's serial port in order to work with your device. For example, many GPS receivers work on 4800bit/s bitrate, to the same should be set in the /port menu for the respective serial port.
Precise time is mainly intended to be used by built-in NTP server, which can use it as a time source without any additional configuration if GPS is configured to set system time.
Additional Resources
Synchronizing with a GPS Receiver
Property Description
enabled (yes | no) - whether the router will communicate with a GPS receiver or not
port (name) - the port that will be used to communicate with a GPS receiver
set-system-time (time) - whether to set the system time to the value received from a GPS receiver or not
Notes
If you are synchronizing system time with a GPS device, you should correctly choose time zone if it is different from GMT as satellites are broadcasting GMT (a.k.a. UTC) time.
Example
To enable GPS communication through serial0 port:
[admin@MikroTik] system gps> print
            enabled: no
               port: (unknown)
    set-system-time: yes
[admin@MikroTik] system gps> set enabled=yes port=serial0
            enabled: yes
               port: serial0
GPS Monitoring
Submenu level: /system gps monitor
Description
This command is used for monitoring the data received from a GPS receiver.
date-and-time (read-only: text) - date and time received from GPS server
longitude (read-only: text) - longitude of the current location
latitude (read-only: text) - latitude of the current location
altitude (read-only: text) - altitude of the current location
speed (read-only: text) - mean velocity
valid (read-only: yes | no) - whether the received information is valid or not (e.g. you can set a GPS receiver to the demo mode to test the connection, in which case you will receive information, but it will not be valid)
Example
[admin@MikroTik] system gps> monitor
    date-and-time: jul/23/2003 12:25:00
        longitude: "E 24 8' 17''"
         latitude: "N 56 59' 22''"
         altitude: "-127.406400m"
            speed: "0.001600 km/h"
            valid: yes
