BGP Routing Filters
Document revision: | 1.4 (Fri Sep 23 08:43:17 GMT 2005) |
Applies to: | V2.9 |
General Information
Summary
Border Gateway Protocol (BGP) Routing filters allow to alter attributes of the route for the NLRI prefixes or completely exclude particular NLRI prefixes with routes from the BGP routing update message.
Specifications
Packages required:
routing
License required:
Level3
Submenu level:
/routing filter
Standards and Technologies:
RFC1771
Hardware usage:
Not significant
Related Documents
Description
BGP filtering refers to the ability of BGP peer to apply administrative policies to incoming and outgoing routing update messages. These policies are implemented as rules organized in chains. The following manual uses terms 'chain' and 'filter' interchengeably. Each rule consists of two parts, one of them specifies to which prefixes the rule applies to and the other tells the router what to do with these prefixes. A rule with no arguments applies to all prefixes and implies accept action.
The routing filters may be applied to incoming and outgoing routing update messages for a specific BGP peer and to outgoing BGP update messages for a particular BGP instance. Note, that in case both BGP instance and BGP peer outgoing filters are applied, BGP instance filters take precedence.
Additional Resources
Filter Rules
Property Description
action (accept | discard | jump | none | reject | return; default:
none) - action to perform on route or route attributes for the NLRI prefixes that match the rule
accept
- accept the routing information for the matching NLRI prefix
discard
- completely exclude matching prefix from the BGP processing. The route will be deleted from the incoming BGP routing update message, thus reducing memory usage on the router. For outgoing BGP update messages the discard action is equal to reject
jump
- pass control to another filter list that should be specified as jump-target parameter
none
- do not perform any action and pass execution to the next rule in chain. The none action is not displayed by print command
reject
- reject the routing information for matching prefix. The prefix from incoming BGP routing update message is be shown with R (rejected) flag in the /ip route print command output. The prefix is suppressed from outgoing routing update message
return
- return to the previous chain from which a jump to the current chain took place
as-path (
text) - unanchored pattern to be searched inside AS_PATH attribute of the route. Optional
^ sign preceiding parameter value restricts match to the beginning of AS_PATH attribute, while
$ sign, which follows
as-path value, restricts the match to the end of AS_PATH
as-path-length (
integer-
integer) - length of the AS_PATH attribute, representing the number of ASs that have been traversed. Note that multiple AS_SETs are combined together and counted as 1 AS
atomic-aggregate (absent | present) - match for the ATOMIC_AGGREGATE BGP attribute
chain (
text) - chain name to place this rule in. If a chain with the specified name does not exist it will be automatically created
distance (
integer-
integer; default:
no) - protocol-independent administrative distance used to compare routes obtained from different sources
jump-target (
name) - name of the target chain to jump to, if the
action=jump is used
local-pref (
integer-
integer) - match for the LOCAL_PREF BGP attribute
match-chain (
name) - the name of the chain which is used to evaluate the route. If the chain accepts the route,
match-chain property produces a true match
med (
integer-
integer) - match for the MULTI_EXIT_DISC BGP attribute
origin (igp | egp | incomplete) - match for the ORIGIN BGP attribute
prefix (
IP address/
netmask |
IP address-
IP address) - match for the NLRI prefix
prefix-length (
integer-
integer) - match for the NLRI prefix length
prefsrc (
IP address/
netmask |
IP address-
IP address) - match for the preferred source IP address of the route
route-comment (
text) - match for the route comment
routing-mark (
text) - match for the routing mark. A routing mark identifies certain routes for successive processing
scope (
integer: 0..255-
integer: 0..255) -
scope and
target-scope are used to recursively lookup next hop address for the route. Routes that are used to lookup the next hop address for a given route should have
scope value equal or less then the
target-scope value of this route
set-check-gateway (ping | arp) - specifies that the router should check whether the gateway for the particular route is reachable by using either ping or arp request prior to sending anything using this route
set-disabled - disables the route. Disabled routes are not considered by BGP best path selection algorithm
set-distance (
integer: 0..255) - sets administrative distance for a route. The distance is protocol-independent and is used to compare routes obtained from different sources
set-localpref (
integer: 0..4294967295) - specifies LOCAL_PREF BGP attribute value for the route
set-med (
integer: 0..4294967295) - sets MULTI_EXIT_DISC BGP attribute
set-nexthop (
IP address) - sets next hop IP address for the route
set-prefsrc (
IP address) - sets preffered source address for the route
set-prepend (
integer: 0..16) - specifies how many times the router should prepend its AS number to the AS_PATH BGP attribute value for this route
set-route-comment (
text) - specifies comment for the route
set-routing-mark (
text) - sets routing mark for the route
set-scope (
integer: 0..255) - sets scope for the route.
Scope and
set-target-scope (
integer: 0..255) - sets target scope for the route.
Scope and
set-weight (
integer: -2147483648..2147483647) - specifies weight for the route. Route weight is used by BGP best path selection algoritm to select the best route towards destination
target-scope (
integer: 0..255-
integer: 0..255) -
scope and
type (absent | present) - match for the ATOMIC_AGGREGATE BGP attribute
unset (
multiple choice: prefsrc | routing-mark | check-gateway | disabled) - unsets specified parameters of the route
weight (
integer: -2147483648..2147483647) - match for the weight of the route
© Copyright 1999-2006, MikroTik. All rights reserved. Mikrotik, RouterOS and RouterBOARD are trademarks of Mikrotikls SIA. Other trademarks and registered trademarks mentioned herein are properties of their respective owners.
