NAT
Document revision: | 2.8 (Tue Feb 28 15:15:00 GMT 2006) |
Applies to: | V2.9 |
General Information
Summary
Network Address Translation (NAT) is a router facility that replaces source and (or) destination IP addresses of the IP packet as it pass through thhe router. It is most commonly used to enable multiple host on a private network to access the Internet using a single public IP address.
Specifications
Packages required: systemLicense required: Level1 (number of rules limited to 1) , Level3
Submenu level: /ip firewall nat
Standards and Technologies: IP, RFC1631, RFC2663
Hardware usage: Increases with the count of rules
Related Documents
NAT
Description
Network Address Translation is an Internet standard that allows hosts on local area networks to use one set of IP addresses for internal communications and another set of IP addresses for external communications. A LAN that uses NAT is referred as natted network. For NAT to function, there should be a NAT gateway in each natted network. The NAT gateway (NAT router) performs IP address rewriting on the way a packet travel from/to LAN.
There are two types of NAT:
- source NAT or srcnat. This type of NAT is performed on packets that are originated from a natted network. A NAT router replaces the private source address of an IP packet with a new public IP address as it travels through the router. A reverse operation is applied to the reply packets travelling in the other direction.
- destination NAT or dstnat. This type of NAT is performed on packets that are destined to the natted network. It is most comonly used to make hosts on a private network to be acceesible from the Internet. A NAT router performing dstnat replaces the destination IP address of an IP packet as it travel through the router towards a private network.
Hosts behind a NAT-enabled router do not have true end-to-end connectivity. Therefore some Internet protocols might not work in scenarios with NAT. Services that require the initiation of TCP connection from outside the private network or stateless protocols such as UDP, can be disrupted. Moreover, some protocols are inherently incompatible with NAT, a bold example is AH protocol from the IPsec suite.
RouterOS includes a number of so-called NAT helpers, that enable NAT traversal for various protocols.
Redirect and MasqueradeRedirect and masquerade are special forms of destination NAT and source NAT, respectively. Redirect is similar to the regular destination NAT in the same way as masquerade is similar to the source NAT - masquerade is a special form of source NAT without need to specify to-addresses - outgoing interface address is used automatically. The same is for redirect - it is a form of destination NAT where to-addresses is not used - incoming interface address is used instead. Note that to-ports is meaningful for redirect rules - this is the port of the service on the router that will handle these requests (e.g. web proxy).
When packet is dst-natted (no matter - action=nat or action=redirect), dst address is changed. Information about translation of addresses (including original dst address) is kept in router's internal tables. Transparent web proxy working on router (when web requests get redirected to proxy port on router) can access this information from internal tables and get address of web server from them. If you are dst-natting to some different proxy server, it has no way to find web server's address from IP header (because dst address of IP packet that previously was address of web server has changed to address of proxy server). Starting from HTTP/1.1 there is special header in HTTP request which tells web server address, so proxy server can use it, instead of dst address of IP packet. If there is no such header (older HTTP version on client), proxy server can not determine web server address and therefore can not work.
It means, that it is impossible to correctly transparently redirect HTTP traffic from router to some other transparent-proxy box. Only correct way is to add transparent proxy on the router itself, and configure it so that your "real" proxy is parent-proxy. In this situation your "real" proxy does not have to be transparent any more, as proxy on router will be transparent and will forward proxy-style requests (according to standard; these requests include all necessary information about web server) to "real" proxy.
Property Description
action (accept | add-dst-to-address-list | add-src-to-address-list | dst-nat | jump | log | masquerade | netmap | passthrough | redirect | return | same | src-nat; default: accept) - action to undertake if the packet matches the ruleadd-dst-to-address-list - adds destination address of an IP packet to the address list specified by address-list parameter
add-src-to-address-list - adds source address of an IP packet to the address list specified by address-list parameter
dst-nat - replaces destination address of an IP packet to values specified by to-addresses and to-ports parameters
jump - jump to the chain specified by the value of the jump-target parameter
log - each match with this action will add a message to the system log
masquerade - replaces source address of an IP packet to an automatically determined by the routing facility IP address
netmap - creates a static 1:1 mapping of one set of IP addresses to another one. Often used to distribute public IP addresses to hosts on private networks
passthrough - ignores this rule goes on to the next one
redirect - replaces destination address of an IP packet to one of the router's local addresses
return - passes control back to the chain from where the jump took place
same - gives a particular client the same source/destination IP address from supplied range for each connection. This is most frequently used for services that expect the same client address for multiple connections from the same client
src-nat - replaces source address of an IP packet to values specified by to-addresses and to-ports parameters
srcnat - a rule placed in this chain is applied after routing. The rules that replace the source addresses of IP packets should be placed there
local - matches addresses assigned to router's interfaces
broadcast - the IP packet is sent from one point to all other points in the IP subnetwork
multicast - this type of IP addressing is responsible for transmission from one or more points to a set of other points
Time - specifies the time interval over which the packet rate is measured
Burst - number of packets to match in a burst
Mode - the classifier(-s) for packet rate limiting
Expire - specifies interval after which recorded IP addresses / ports will be deleted
auth - true, if a packet comes from authenticted client
local-dst - true, if a packet has local destination IP address
loose-source-routing - match packets with loose source routing option. This option is used to route the internet datagram based on information supplied by the source
no-record-route - match packets with no record route option. This option is used to route the internet datagram based on information supplied by the source
no-router-alert - match packets with no router alter option
no-source-routing - match packets with no source routing option
no-timestamp - match packets with no timestamp option
record-route - match packets with record route option
router-alert - match packets with router alter option
strict-source-routing - match packets with strict source routing option
timestamp - match packets with timestamp
Counter - specifies which counter to use. A counter increments each time the rule containing nth match matches
Packet - match on the given packet number. The value by obvious reasons must be between 0 and Every. If this option is used for a given counter, then there must be at least Every+1 rules with this option, covering all values between 0 and Every inclusively.
Max - specifies upper boundary of the size range
DelayThreshold - delay for the packets with different destination ports coming from the same host to be treated as possible port scan subsequence
LowPortWeight - weight of the packets with privileged (<=1024) destination port
HighPortWeight - weight of the packet with non-priviliged destination port
max-throughput - maximize throughput (ToS=8)
min-cost - minimize monetary cost (ToS=2)
min-delay - minimize delay (ToS=16)
normal - normal service (ToS=0)
NAT Applications
Description
In this section some NAT applications and examples of them are discussed.
Basic NAT configurationAssume we want to create router that:
- "hides" the private LAN "behind" one address
- provides Public IP to the Local server
- creates 1:1 mapping of network addresses
Example of Source NAT (Masquerading)
If you want to "hide" the private LAN 192.168.0.0/24 "behind" one address 10.5.8.109 given to you by the ISP, you should use the source network address translation (masquerading) feature of the MikroTik router. The masquerading will change the source IP address and port of the packets originated from the network 192.168.0.0/24 to the address 10.5.8.109 of the router when the packet is routed through it.
To use masquerading, a source NAT rule with action 'masquerade' should be added to the firewall configuration:
/ip firewall nat add chain=srcnat action=masquerade out-interface=Public
All outgoing connections from the network 192.168.0.0/24 will have source address 10.5.8.109 of the router and source port above 1024. No access from the Internet will be possible to the Local addresses. If you want to allow connections to the server on the local network, you should use destination Network Address Translation (NAT).
Example of Destination NAT
If you want to link Public IP 10.5.8.200 address to Local one 192.168.0.109, you should use destination address translation feature of the MikroTik router. Also if you want allow Local server to talk with outside with given Public IP you should use source address translation, too
Add Public IP to Public interface:
/ip address add address=10.5.8.200/32 interface=Public
Add rule allowing access to the internal server from external networks:
/ip firewall nat add chain=dstnat dst-address=10.5.8.200 action=dst-nat \ to-addresses=192.168.0.109
Add rule allowing the internal server to talk to the outer networks having its source address translated to 10.5.8.200:
/ip firewall nat add chain=srcnat src-address=192.168.0.109 action=src-nat \ to-addresses=10.5.8.200
Example of 1:1 mapping
If you want to link Public IP subnet 11.11.11.0/24 to local one 2.2.2.0/24, you should use destination address translation and source address translation features with action=netmap.
/ip firewall nat add chain=dstnat dst-address=11.11.11.1-11.11.11.254 \ action=netmap to-addresses=2.2.2.1-2.2.2.254 /ip firewall nat add chain=srcnat src-address=2.2.2.1-2.2.2.254 \ action=netmap to-addresses=11.11.11.1-11.11.11.254
