Filter
Document revision:2.7 (Fri Nov 04 16:04:37 GMT 2005)
Applies to: V2.9
General Information
Summary
The firewall implements packet filtering and thereby provides security functions that are used to manage data flow to, from and through the router. Along with the Network Address Translation it serve as a tool for preventing unauthorized access to directly attached networks and the router itself as well as a filter for outgoing traffic.
Quick Setup Guide
Specifications
Packages required: system
License required: Level1 (P2P filters limited to 1) , Level3
Submenu level: /ip firewall filter
Standards and Technologies: IP, RFC2113
Hardware usage: Increases with filtering rules count
Related Documents
Firewall Filter
Description
Network firewalls keep outside threats away from sensitive data available inside the network. Whenever different networks are joined together, there is always a threat that someone from outside of your network will break into your LAN. Such break-ins may result in private data being stolen and distributed, valuable data being altered or destroyed, or entire hard drives being erased. Firewalls are used as a means of preventing or minimizing the security risks inherent in connecting to other networks. Properly configured firewall plays a key role in efficient and secure network infrastrure deployment.
MikroTik RouterOS has very powerful firewall implementation with features including:
General Filtering Principles
The firewall operates by means of firewall rules. A rule is a definitive form expression that tells the router what to do with a particular IP packet. Each rule consists of two parts that are the matcher which matches traffic flow against given conditions and the action which defines what to do with the mathched packets. Rules are organized in chains for better management.
The filter facility has three default chains: input, forward and output that are responsible for traffic coming from, through and to the router, respectively. New user-defined chains can be added, as necessary. Since these chains have no default traffic to match, rules with action=jump and relevant jump-target should be added to one or more of the three default chains.
Filter Chains
As mentioned before, the firewall filtering rules are grouped together in chains. It allows a packet to be matched against one common criterion in one chain, and then passed over for processing against some other common criteria to another chain. For example a packet should be matched against the IP address:port pair. Of course, it could be achieved by adding as many rules with IP address:port match as required to the forward chain, but a better way could be to add one rule that matches traffic from a particular IP address, e.g.: /ip firewall filter add src-address=1.1.1.2/32 jump-target="mychain" and in case of successfull match passes control over the IP packet to some other chain, id est mychain in this example. Then rules that perform matching against separate ports can be added to mychain chain without specifying the IP addresses.
There are three predefined chains, which cannot be deleted:
When processing a chain, rules are taken from the chain in the order they are listed there from top to bottom. If a packet matches the criteria of the rule, then the specified action is performed on it, and no more rules are processed in that chain (the exception is the passthrough action). If a packet has not matched any rule within the chain, then it is accepted.
Property Description
action (accept | add-dst-to-address-list | add-src-to-address-list | drop | jump | log | passthrough | reject | return | tarpit; default: accept) - action to undertake if the packet matches the rule
accept - accept the packet. No action is taken, i.e. the packet is passed through and no more rules are applied to it
add-dst-to-address-list - adds destination address of an IP packet to the address list specified by address-list parameter
add-src-to-address-list - adds source address of an IP packet to the address list specified by address-list parameter
drop - silently drop the packet (without sending the ICMP reject message)
jump - jump to the chain specified by the value of the jump-target parameter
log - each match with this action will add a message to the system log
passthrough - ignores this rule and goes on to the next one
reject - reject the packet and send an ICMP reject message
return - passes control back to the chain from where the jump took place
tarpit - captures and holds incoming TCP connections (replies with SYN/ACK to the inbound TCP SYN packet)
address-list (name) - specifies the name of the address list to collect IP addresses from rules having action=add-dst-to-address-list or action=add-src-to-address-list actions. These address lists could be later used for packet matching
address-list-timeout (time; default: 00:00:00) - time interval after which the address will be removed from the address list specified by address-list parameter. Used in conjunction with add-dst-to-address-list or add-src-to-address-list actions
00:00:00 - leave the address in the address list forever
chain (forward | input | output | name) - specifies the chain to put a particular rule into. As the different traffic is passed through different chains, always be careful in choosing the right chain for a new rule. If the input does not match the name of an already defined chain, a new chain will be created
comment (text) - a descriptive comment for the rule. A comment can be used to identify rules form scripts
connection-bytes (integer-integer) - matches packets only if a given amount of bytes has been transfered through the particular connection
0 - means infinity, exempli gratia: connection-bytes=2000000-0 means that the rule matches if more than 2MB has been transfered through the relevant connection
connection-limit (integer,netmask) - restrict connection limit per address or address block
connection-mark (name) - matches packets marked via mangle facility with particular connection mark
connection-state (estabilished | invalid | new | related) - interprets the connection tracking analysis data for a particular packet
estabilished - a packet which belongs to an existing connection, exempli gratia a reply packet or a packet which belongs to already replied connection
invalid - a packet which could not be identified for some reason. This includes out of memory condition and ICMP errors which do not correspond to any known connection. It is generally advised to drop these packets
new - a packet which begins a new TCP connection
related - a packet which is related to, but not part of an existing connection, such as ICMP errors or a packet which begins FTP data connection (the later requires enabled FTP connection tracking helper under /ip firewall service-port)
connection-type (ftp | gre | h323 | irc | mms | pptp | quake3 | tftp) - matches packets from related connections based on information from their connection tracking helpers. A relevant connection helper must be enabled under /ip firewall service-port
content (text) - the text packets should contain in order to match the rule
dst-address (IP address/netmask | IP address-IP address) - specifies the address range an IP packet is destined to. Note that console converts entered address/netmask value to a valid network address, i.e.:1.1.1.1/24 is converted to 1.1.1.0/24
dst-address-list (name) - matches destination address of a packet against user-defined address list
dst-address-type (unicast | local | broadcast | multicast) - matches destination address type of the IP packet, one of the:
unicast - IP addresses used for one point to another point transmission. There is only one sender and one receiver in this case
local - matches addresses assigned to router's interfaces
broadcast - the IP packet is sent from one point to all other points in the IP subnetwork
multicast - this type of IP addressing is responsible for transmission from one or more points to a set of other points
dst-limit (integer/time{0,1},integer,dst-address | dst-port | src-address{+},time{0,1}) - limits the packet per second (pps) rate on a per destination IP or per destination port base. As opposed to the limit match, every destination IP address / destination port has it's own limit. The options are as follows (in order of appearance):
Count - maximum average packet rate, measured in packets per second (pps), unless followed by Time option
Time - specifies the time interval over which the packet rate is measured
Burst - number of packets to match in a burst
Mode - the classifier(-s) for packet rate limiting
Expire - specifies interval after which recorded IP addresses / ports will be deleted
dst-port (integer: 0..65535-integer: 0..65535{*}) - destination port number or range
hotspot (multiple choice: from-client | auth | local-dst | http) - matches packets received from clients against various Hot-Spot. All values can be negated
from-client - true, if a packet comes from HotSpot client
auth - true, if a packet comes from authenticted client
local-dst - true, if a packet has local destination IP address
hotspot - true, if it is a TCP packet from client and either the transparent proxy on port 80 is enabled or the client has a proxy address configured and this address is equal to the address:port pair of the IP packet
icmp-options (integer:integer) - matches ICMP Type:Code fields
in-interface (name) - interface the packet has entered the router through
ipv4-options (any | loose-source-routing | no-record-route | no-router-alert | no-source-routing | no-timestamp | none | record-route | router-alert | strict-source-routing | timestamp) - match ipv4 header options
any - match packet with at least one of the ipv4 options
loose-source-routing - match packets with loose source routing option. This option is used to route the internet datagram based on information supplied by the source
no-record-route - match packets with no record route option. This option is used to route the internet datagram based on information supplied by the source
no-router-alert - match packets with no router alter option
no-source-routing - match packets with no source routing option
no-timestamp - match packets with no timestamp option
record-route - match packets with record route option
router-alert - match packets with router alter option
strict-source-routing - match packets with strict source routing option
timestamp - match packets with timestamp
jump-target (forward | input | output | name) - name of the target chain to jump to, if the action=jump is used
limit (integer/time{0,1},integer) - restricts packet match rate to a given limit. Usefull to reduce the amount of log messages
log-prefix (text) - all messages written to logs will contain the prefix specified herein. Used in conjunction with action=log
nth (integer,integer: 0..15,integer{0,1}) - match a particular Nth packet received by the rule. One of 16 available counters can be used to count packets
Every - match every Every+1th packet. For example, if Every=1 then the rule matches every 2nd packet
Counter - specifies which counter to use. A counter increments each time the rule containing nth match matches
Packet - match on the given packet number. The value by obvious reasons must be between 0 and Every. If this option is used for a given counter, then there must be at least Every+1 rules with this option, covering all values between 0 and Every inclusively.
out-interface (name) - interface the packet will leave the router through
p2p (all-p2p | bit-torrent | blubster | direct-connect | edonkey | fasttrack | gnutella | soulseek | warez | winmx) - matches packets from various peer-to-peer (P2P) protocols
packet-mark (text) - matches packets marked via mangle facility with particular packet mark
packet-size (integer: 0..65535-integer: 0..65535{0,1}) - matches packet of the specified size or size range in bytes
Min - specifies lower boundary of the size range or a standalone value
Max - specifies upper boundary of the size range
phys-in-interface (name) - matches the bridge port physical input device added to a bridge device. It is only useful if the packet has arrived through the bridge
phys-out-interface (name) - matches the bridge port physical output device added to a bridge device. It is only useful if the packet will leave the router through the bridge
protocol (ddp | egp | encap | ggp | gre | hmp | icmp | idrp-cmtp | igmp | ipencap | ipip | ipsec-ah | ipsec-esp | iso-tp4 | ospf | pup | rdp | rspf | st | tcp | udp | vmtp | xns-idp | xtp | integer) - matches particular IP protocol specified by protocol name or number. You should specify this setting if you want to specify ports
psd (integer,time,integer,integer) - attempts to detect TCP and UDP scans. It is advised to assign lower weight to ports with high numbers to reduce the frequency of false positives, such as from passive mode FTP transfers
WeightThreshold - total weight of the latest TCP/UDP packets with different destination ports coming from the same host to be treated as port scan sequence
DelayThreshold - delay for the packets with different destination ports coming from the same host to be treated as possible port scan subsequence
LowPortWeight - weight of the packets with privileged (<=1024) destination port
HighPortWeight - weight of the packet with non-priviliged destination port
random (integer: 1..99) - matches packets randomly with given propability
reject-with (icmp-admin-prohibited | icmp-echo-reply | icmp-host-prohibited | icmp-host-unreachable | icmp-net-prohibited | icmp-network-unreachable | icmp-port-unreachable | icmp-protocol-unreachable | tcp-reset | integer) - alters the reply packet of reject action
routing-mark (name) - matches packets marked by mangle facility with particular routing mark
src-address (IP address/netmask | IP address-IP address) - specifies the address range an IP packet is originated from. Note that console converts entered address/netmask value to a valid network address, i.e.:1.1.1.1/24 is converted to 1.1.1.0/24
src-address-list (name) - matches source address of a packet against user-defined address list
src-address-type (unicast | local | broadcast | multicast) - matches source address type of the IP packet, one of the:
src-mac-address (MAC address) - source MAC address
src-port (integer: 0..65535-integer: 0..65535{*}) - source port number or range
tcp-flags (ack | cwr | ece | fin | psh | rst | syn | urg) - tcp flags to match
ack - acknowledging data
cwr - congestion window reduced
ece - ECN-echo flag (explicit congestion notification)
fin - close connection
psh - push function
rst - drop connection
syn - new connection
urg - urgent data
tcp-mss (integer: 0..65535) - matches TCP MSS value of an IP packet
time (time-time,sat | fri | thu | wed | tue | mon | sun{+}) - allows to create filter based on the packets' arrival time and date or, for locally generated packets, departure time and date
tos (max-reliability | max-throughput | min-cost | min-delay | normal) - specifies a match for the value of Type of Service (ToS) field of an IP header
max-reliability - maximize reliability (ToS=4)
max-throughput - maximize throughput (ToS=8)
min-cost - minimize monetary cost (ToS=2)
min-delay - minimize delay (ToS=16)
normal - normal service (ToS=0)
Notes
Because the NAT rules are applied first, it is important to hold this in mind when setting up firewall rules, since the original packets might be already modified by the NAT
Filter Applications
Protect your RouterOS router
To protect your router, you should not only change admin's password but also set up packet filtering. All packets with destination to the router are processed against the ip firewall input chain. Note, that the input chain does not affect packets which are being transferred through the router.
/ ip firewall filter
add chain=input connection-state=invalid action=drop \
	comment="Drop Invalid connections"
add chain=input connection-state=established action=accept \
	comment="Allow Established connections"
add chain=input protocol=udp action=accept \
	comment="Allow UDP"
add chain=input protocol=icmp action=accept \
	comment="Allow ICMP"
add chain=input src-address=192.168.0.0/24 action=accept \
	comment="Allow access to router from known network"
add chain=input action=drop comment="Drop anything else"
Protecting the Customer's Network
To protect the customer's network, we should check all traffic which goes through router and block unwanted. For icmp, tcp, udp traffic we will create chains, where will be droped all unwanted packets:
add chain=forward protocol=tcp connection-state=invalid \
 	action=drop comment="drop invalid connections"
add chain=forward connection-state=established action=accept \
 	comment="allow already established connections"
add chain=forward connection-state=related action=accept \
 	comment="allow related connections"
Block IP addreses called "bogons":
add chain=forward src-address=0.0.0.0/8 action=drop
add chain=forward dst-address=0.0.0.0/8 action=drop
add chain=forward src-address=127.0.0.0/8 action=drop
add chain=forward dst-address=127.0.0.0/8 action=drop
add chain=forward src-address=224.0.0.0/3 action=drop
add chain=forward dst-address=224.0.0.0/3 action=drop
Make jumps to new chains:
add chain=forward protocol=tcp action=jump jump-target=tcp
add chain=forward protocol=udp action=jump jump-target=udp
add chain=forward protocol=icmp action=jump jump-target=icmp
Create tcp chain and deny some tcp ports in it:
add chain=tcp protocol=tcp dst-port=69 action=drop \
 	comment="deny TFTP"
add chain=tcp protocol=tcp dst-port=111 action=drop \
 	comment="deny RPC portmapper"
add chain=tcp protocol=tcp dst-port=135 action=drop \
add chain=tcp protocol=tcp dst-port=137-139 action=drop \
 	comment="deny NBT"
add chain=tcp protocol=tcp dst-port=445 action=drop \
 	comment="deny cifs"
add chain=tcp protocol=tcp dst-port=2049 action=drop comment="deny NFS"
add chain=tcp protocol=tcp dst-port=12345-12346 action=drop comment="deny NetBus"
add chain=tcp protocol=tcp dst-port=20034 action=drop comment="deny NetBus"
add chain=tcp protocol=tcp dst-port=3133 action=drop comment="deny BackOriffice"
add chain=tcp protocol=tcp dst-port=67-68 action=drop comment="deny DHCP"
Deny udp ports in udp chain:
add chain=udp protocol=udp dst-port=69 action=drop comment="deny TFTP"
add chain=udp protocol=udp dst-port=111 action=drop comment="deny PRC portmapper"
add chain=udp protocol=udp dst-port=135 action=drop comment="deny PRC portmapper"
add chain=udp protocol=udp dst-port=137-139 action=drop comment="deny NBT"
add chain=udp protocol=udp dst-port=2049 action=drop comment="deny NFS"
add chain=udp protocol=udp dst-port=3133 action=drop comment="deny BackOriffice"
Allow only needed icmp codes in icmp chain:
add chain=icmp protocol=icmp icmp-options=0:0 action=accept \
add chain=icmp protocol=icmp icmp-options=3:0 action=accept \
 	comment="allow established connections"
add chain=icmp protocol=icmp icmp-options=3:1 action=accept \
add chain=icmp protocol=icmp icmp-options=4:0 action=accept \
 	comment="allow source quench"
add chain=icmp protocol=icmp icmp-options=8:0 action=accept \
 	comment="allow echo request"
add chain=icmp protocol=icmp icmp-options=11:0 action=accept \
 	comment="allow time exceed"
add chain=icmp protocol=icmp icmp-options=12:0 action=accept \
 	comment="allow parameter bad"
add chain=icmp action=drop comment="deny all other types"
