DNS Client and Cache
| Document revision: | 1.2 (Fri Apr 15 17:37:43 GMT 2005) |
| Applies to: | V2.9 |
General Information
Summary
DNS cache is used to minimize DNS requests to an external DNS server as well as to minimize DNS resolution time. This is a simple recursive DNS server with local items.
Specifications
Packages required: systemLicense required: Level1
Submenu level: /ip dns
Standards and Technologies: DNS
Hardware usage: Not significant
Related Documents
Description
The MikroTik router with DNS cache feature enabled can be set as a primary DNS server for any DNS-compliant clients. Moreover, MikroTik router can be specified as a primary DNS server under its dhcp-server settings. When the DNS cache is enabled, the MikroTik router responds to DNS TCP and UDP requests on port 53.
Additional Resources
Client Configuration and Cache Setup
Submenu level: /ip dnsDescription
DNS client is used to provide domain name resolution for router itself as well as for the P2P clients connected to the router.
Property Description
allow-remote-requests (yes | no) - specifies whether to allow network requestscache-max-ttl (time; default: 1w) - specifies maximum time-to-live for cahce records. In other words, cache records will expire after cache-max-ttl time.cache-size (integer: 512..10240; default: 2048KiB) - specifies the size of DNS cache in KiBcache-used (read-only: integer) - displays the currently used cache size in KiBprimary-dns (IP address; default: 0.0.0.0) - primary DNS serversecondary-dns (IP address; default: 0.0.0.0) - secondary DNS serverNotes
If the property use-peer-dns under /ip dhcp-client is set to yes then primary-dns under /ip dns will change to a DNS address given by DHCP Server.
Example
To set 159.148.60.2 as the primary DNS server and allow the router to be used as a DNS server, do the following:
[admin@MikroTik] ip dns> set primary-dns=159.148.60.2 \
\... allow-remote-requests=yes
[admin@MikroTik] ip dns> print
primary-dns: 159.148.60.2
secondary-dns: 0.0.0.0
allow-remote-requests: yes
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 17KiB
Cache Monitoring
Submenu level: /ip dns cacheProperty Description
address (read-only: IP address) - IP address of the hostname (read-only: name) - DNS name of the host ttl (read-only: time) - remaining time-to-live for the recordStatic DNS Entries
Submenu level: /ip dns staticDescription
The MikroTik RouterOS has an embedded DNS server feature in DNS cache. It allows you to link the particular domain names with the respective IP addresses and advertize these links to the DNS clients using the router as their DNS server.
address (IP address) - IP address to resolve domain name withname (text) - DNS name to be resolved to a given IP address ttl (time) - time-to-live of the DNS recordExample
To add a static DNS entry for www.example.com to be resolved to 10.0.0.1 IP address:
[admin@MikroTik] ip dns static> add name www.example.com address=10.0.0.1 [admin@MikroTik] ip dns static> print # NAME ADDRESS TTL 0 aaa.aaa.a 123.123.123.123 1d 1 www.example.com 10.0.0.1 1d [admin@MikroTik] ip dns static>
Flushing DNS cache
Command name: /ip dns cache flushCommand Description
flush - clears internal DNS cacheExample
[admin@MikroTik] ip dns> cache flush
cache-size: 2048 KiB
cache-max-ttl: 1w
cache-used: 10 KiB
