GPRS PCMCIA
| Document revision: | 1.0 (Fri Jul 15 15:07:41 GMT 2005) |
| Applies to: | V2.9 |
How to make a GPRS connection
Description
Let us consider a situation that you are in a place where no internet connection is available, but you have access to your mobile network provider. In this case you can connect MikroTik router to your mobile phone provider using GPRS (General Packet Radio Service) and so establish an internet connection.
Example
Plug the GPRS PCMCIA card (with your SIM card) into the router, turn on the router and after it has started, see if a new port has appeared. In this case it is the serial1 port which is our GPRS device:
[admin@MikroTik] port> print # NAME USED-BY BAUD-RATE 0 serial0 Serial Console 115200 1 serial1 9600 [admin@MikroTik] port>
Enter the pin code from serial-terminal (in this case, PIN code is 3663) :
/system serial-terminal serial1 AT+CPIN=”3663”
Now you should see OK on your screen. Wait for about 5 seconds and see if the green led started to blink. Press Ctrl+Q to quit the serial-terminal.
Change remote-address in /ppp profile, in this case to 212.93.96.65 (you should obtain it from your mobile network operator):
/ppp profile set default remote-address=212.93.96.65
Add a ppp client:
/interface ppp-client add dial-command=ATD phone=*99***1# \ \... modem-init="AT+CGDCONT=1,\"IP\",\"internet\"" port=serial1
Now enable the interface and see if it is connected:
[admin@MikroTik] interface ppp-client> enable 0 [admin@MikroTik] interface ppp-client> mo 0 status: dialing... status: link established status: authenticated uptime: 0s idle-time: 0s status: authenticated uptime: 1s idle-time: 1s status: connected uptime: 2s idle-time: 2s [admin@MikroTik] interface ppp-client>Check the IP addresses:
[admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 192.168.0.5/24 192.168.0.0 192.168.0.255 ether1 1 D 10.40.205.168/32 212.93.96.65 0.0.0.0 ppp-out1 [admin@MikroTik] ip address>
