Interface Bonding
Document revision: | 1.1 (oct-26-2004) |
Applies to: | V2.9 |
General Information
Summary
Bonding is a technology that allows to aggregate multiple ethernet-like interfaces into a single virtual link, thus getting higher data rates and providing failover.
Quick Setup Guide
Let us assume that we have 2 NICs in each router (Router1 and Router2) and want to get maximum data rate between 2 routers. To make this possible, follow these steps:
- Make sure that you do not have IP addresses on interfaces which will be enslaved for bonding interface!
Add bonding interface on Router1:
[admin@Router1] interface bonding> add slaves=ether1,ether2
And on Router2:
[admin@Router2] interface bonding> add slaves=ether1,ether2
Add addresses to bonding interfaces:
[admin@Router1] ip address> add address=172.16.0.1/24 interface=bonding1
[admin@Router2] ip address> add address=172.16.0.2/24 interface=bonding1
Test the link from Router1:
[admin@Router1] interface bonding> /pi 172.16.0.2 172.16.0.2 ping timeout 172.16.0.2 ping timeout 172.16.0.2 ping timeout 172.16.0.2 64 byte ping: ttl=64 time=2 ms 172.16.0.2 64 byte ping: ttl=64 time=2 ms
Note that bonding interface needs a couple of seconds to get connectivity with its peer.
Specifications
Packages required: systemLicense required: Level1
Submenu level: /interface bonding
Standards and Technologies: None
Hardware usage: Not significant
Related Documents
Description
To provide a proper failover, you should specify link-monitoring parameter. It can be:
- MII (Media Independent Interface) type1 or type2 - Media Independent Interface is an abstract layer between the operating system and the NIC which detects whether the link is running (it performs also other functions, but in our case this is the most important).
- ARP - Address Resolution Protocol periodically (for arp-interval time) checks the link status.
link-monitoring is used to check whether the link is up or not.
Property Description
arp (disabled | enabled | proxy-arp | reply-only; default: enabled) - Address Resolution Protocol for the interfaceenabled - the interface will use ARP
proxy-arp - the interface will use the ARP proxy feature
reply-only - the interface will only reply to the requests originated to its own IP addresses. Neighbour MAC addresses will be resolved using /ip arp statically set table only
mii-type1 - uses Media Independent Interface type1 to determine link status. Link status determenation relies on the device driver. If bonding shows that the link status is up, when it should not be, then it means that this card don't support this possibility.
mii-type2 - uses MII type2 to determine link status (used if mii-type1 is not supported by the NIC)
none - no method for link monitoring is used. If a link fails, it is not considered as down (but no traffic passes through it, thus).
active-backup - provides link backup. Only one slave can be active at a time. Another slave becomes active only, if first one fails.
balance-alb - adaptive load balancing. It includes balance-tlb and received traffic is also balanced. Device driver should support for setting the mac address, then it is active. Otherwise balance-alb doesn't work. No special switch is required.
balance-rr - round-robin load balancing. Slaves in bonding interface will transmit and receive data in sequential order. Provides load balancing and fault tolerance.
balance-tlb - Outgoing traffic is distributed according to the current load on each slave. Incoming traffic is received by the current slave. If receiving slave fails, then another slave takes the MAC address of the failed slave. Doesn't require any special switch support.
balance-xor - Use XOR policy for transmit. Provides only failover (in very good quality), but not load balancing, yet.
broadcast - Broadcasts the same data on all interfaces at once. This provides fault tolerance but slows down traffic throughput on some slow machines.
Notes
Link failure detection and failover is working significantly better with expensive network cards, for example, made by Intel, then with more cheap ones. For example, on Intel cards failover is taking place in less than a second after link loss, while on some other cards, it may require up to 20 seconds. Also, the Active load balancing (mode=balance-alb) does not work on some cheap cards.
Application Examples
Bonding two Eoip tunnels
Assume you need to configure the MikroTik router for the following network setup, where you have two offices with 2 ISP for each. You want combine links for getting double speed and provide failover:
We are assuming that connections to Internet through two ISP are configured for both routers.
Configuration on routers
on Office1
[admin@office1] > /interface print Flags: X - disabled, D - dynamic, R - running # NAME TYPE RX-RATE TX-RATE MTU 0 R isp1 ether 0 0 1500 1 R isp2 ether 0 0 1500 [admin@office1] > /ip address print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 1.1.1.1/24 1.1.1.0 1.1.1.255 isp2 1 10.1.0.111/24 10.1.0.0 10.1.0.255 isp1
on Office2
[admin@office2] interface> print Flags: X - disabled, D - dynamic, R - running # NAME TYPE RX-RATE TX-RATE MTU 0 R isp2 ether 0 0 1500 1 R isp1 ether 0 0 1500 [admin@office2] interface> /ip add print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 2.2.2.1/24 2.2.2.0 2.2.2.255 isp2 1 10.1.0.112/24 10.1.0.0 10.1.0.255 isp1
Eoip tunnel confguration
for Office1 through ISP1
[admin@office1] > interface eoip add remote-address=10.1.0.112 tunnel-id=2 \... mac-address=FE:FD:00:00:00:04 [admin@office1] > interface eoip print Flags: X - disabled, R - running 0 R name="eoip-tunnel2" mtu=1500 mac-address==FE:FD:00:00:00:04 arp=enabled \... remote-address=10.1.0.112 tunnel-id=2
for Office2 through ISP1
[admin@office2] > interface eoip add remote-address=10.1.0.111 tunnel-id=2 \... mac-address=FE:FD:00:00:00:02 [admin@office2] > interface eoip print Flags: X - disabled, R - running 0 R name="eoip-tunnel2" mtu=1500 mac-address=FE:FD:00:00:00:02 arp=enabled \... remote-address=10.1.0.111 tunnel-id=2
for Office1through ISP2
[admin@office1] > interface eoip add remote-address=2.2.2.1 tunnel-id=1 \... mac-address=FE:FD:00:00:00:03 [admin@office1] interface eoip> print Flags: X - disabled, R - running 0 R name="eoip-tunnel1" mtu=1500 mac-address=FE:FD:00:00:00:03 arp=enabled remote-address=2.2.2.1 tunnel-id=1 1 R name="eoip-tunnel2" mtu=1500 mac-address=FE:FD:00:00:00:04 arp=enabled remote-address=10.1.0.112 tunnel-id=2
for Office2through ISP2
[admin@office2] > interface eoip add remote-address=1.1.1.1 tunnel-id=1 \... mac-address=FE:FD:00:00:00:01 [admin@office2] interface eoip> print Flags: X - disabled, R - running 0 R name="eoip-tunnel1" mtu=1500 mac-address=FE:FD:00:00:00:01 arp=enabled remote-address=1.1.1.1 tunnel-id=1 1 R name="eoip-tunnel2" mtu=1500 mac-address=FE:FD:00:00:00:02 arp=enabled remote-address=10.1.0.111 tunnel-id=2
Bonding confguration
for Office1
[admin@office1] interface bonding> add slaves=eoip-tunnel1,eoip-tunnel2 [admin@office1] interface bonding> print Flags: X - disabled, R - running 0 R name="bonding1" mtu=1500 mac-address=00:0C:42:03:20:E7 arp=enabled slaves=eoip-tunnel1,eoip-tunnel2 mode=balance-rr primary=none link-monitoring=none arp-interval=00:00:00.100 arp-ip-targets="" mii-interval=00:00:00.100 down-delay=00:00:00 up-delay=00:00:00 lacp-rate=30secs [admin@office1] ip address> add address=3.3.3.1/24 interface=bonding1 [admin@office1] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 1.1.1.1/24 1.1.1.0 1.1.1.255 isp2 1 10.1.0.111/24 10.1.0.0 10.1.0.255 isp1 2 3.3.3.1/24 3.3.3.0 3.3.3.255 bonding1
for Office2
[admin@office2] interface bonding> add slaves=eoip-tunnel1,eoip-tunnel2 [admin@office2] interface bonding> print Flags: X - disabled, R - running 0 R name="bonding1" mtu=1500 mac-address=00:0C:42:03:20:E7 arp=enabled slaves=eoip-tunnel1,eoip-tunnel2 mode=balance-rr primary=none link-monitoring=none arp-interval=00:00:00.100 arp-ip-targets="" mii-interval=00:00:00.100 down-delay=00:00:00 up-delay=00:00:00 lacp-rate=30secs [admin@office2] ip address> add address=3.3.3.2/24 interface=bonding1 [admin@office2] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 2.2.2.1/24 2.2.2.0 2.2.2.255 isp2 1 10.1.0.112/24 10.1.0.0 10.1.0.255 isp1 2 3.3.3.2/24 3.3.3.0 3.3.3.255 bonding1 [admin@office2] ip address> /ping 3.3.3.1 3.3.3.1 64 byte ping: ttl=64 time=2 ms 3.3.3.1 64 byte ping: ttl=64 time=2 ms 2 packets transmitted, 2 packets received, 0% packet loss round-trip min/avg/max = 2/2.0/2 ms
