Universal Client Interface
Document revision:2.2 (Fri Mar 05 08:39:12 GMT 2004)
Applies to: V2.8
General Information
Summary
Universal Client Interface allows to work with clients regardless of their IP addresses, translating these addresses to the ones the router is able to work with. It gives a possibility to provide a network access (for example, Internet access) to mobile clients that are not willing to change their networking settings. The feature is intended to use with HotSpot, but may be useful even without HotSpot.
Specifications
Packages required: system
License required: Level1
Submenu level: /ip hotspot universal
Hardware usage: Not significant
Description
Universal client accepts any incoming address from a connected network interface and does one to one network address translation so that data may be routed through standard IP networks. Clients may use any preconfigured addresses. If the Universal client feature is set to translate a client's address to a public IP address, then the client may even run a server or any other service that requires a public IP address. It is possible to add static entries, so that some clients will get the specified addresses.
Universal client is changing source address of each packet just after it is received by the router (even mangle 'sees' the translated address).
Note also that arp mode must be enabled on the interface you set Universal Client Interface on.
Universal Client Interface Setup
Property Description
interface (name) - interface to run universal client on
address-pool (name) - IP address pool name
arp (all-arp | no-arp; default: all-arp) - ARP handling mode:
all-arp - respond to all ARP requests
no-arp - respond to ARP requests normally
use-dhcp (yes | no; default: yes) - do not translate the addresses assigned by DHCP server
idle-timeout (time; default: 5m) - idle timeout (maximal period of inactivity) for client added dynamically
addresses-per-mac (integer; default: 2) - maximal amount of IP addresses assigned to one MAC address
Notes
Setting arp in all-arp is generally a good idea because in most cases you cannot know what is the gateway's IP address configured on the clients, but it can potentially disturb some network protocols.
Example
To enable Universal Client Interface on ether1 interface that will take the addresses to translate to from the exp pool:
[admin@MikroTik] ip hotspot universal> add address-pool=exp interface=ether1
[admin@MikroTik] ip hotspot universal> print
  #   INTERFACE    ADDRESS-POOL ADDRESSES-PER-MAC ARP     USE-DHCP IDLE-TIMEOUT
  0 X ether1       exp          2                 all-arp yes      5m
[admin@MikroTik] ip hotspot universal> enable 0
  0   ether1       exp          2                 all-arp yes      5m
Universal Host List
Submenu level: /ip hotspot universal host
Description
The list shows the current translation table. There are three ways a client may be added to the table:
mac-address (read-only: MAC address) - client's MAC address
address (read-only: IP address) - client's IP address
to-address (read-only: IP address) - IP address to translate the address to
interface (read-only: name) - interface name the client is connected to
idle-time (read-only: time) - inactivity time
uptime (read-only: time) - how long the client is active
bytes-in (read-only: integer) - the amount of bytes received from the client
bytes-out (read-only: integer) - the amount of bytes sent to the client
packets-in (read-only: integer) - the amount of packets received from the client
packets-out (read-only: integer) - the amount of packets sent to the client
Example
To check the current translation table:
[admin@MikroTik] ip hotspot universal host> print
Flags: I - invalid, H - DHCP, D - dynamic
  #   MAC-ADDRESS       ADDRESS         TO-ADDRESS      INTERFACE
  0 D 00:05:5D:5F:4E:34 10.1.0.144      192.168.0.254   int
Universal Access List
Submenu level: /ip hotspot universal access
Description
You can specify manually what IP address will a given IP and/or MAC addresses get.
mac-address (MAC address) - client's MAC address
address (IP address) - client's IP address
to-address (IP address) - IP address to translate the address to
interface (nameempty) - interface name the client is connected to
Example
To add an entry specifying that IP address 10.20.30.40 should be translated to 10.0.0.20 for packets coming from ether1 interface:
[admin@MikroTik] ip hotspot universal access> add address=10.20.30.40 \
\... interface=ether1 to-address=10.0.0.20
[admin@MikroTik] ip hotspot universal access> print
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic
  #   MAC-ADDRESS       ADDRESS         TO-ADDRESS      INTERFACE IDLE-TIME
  0                     10.20.30.40     10.0.0.20       ether1    1s
Service Port
Submenu level: /ip hotspot universal service-port
Description
Just like for classic NAT, the Universal Client Interface 'breaks' some protocols that are incompatible with address translation. To leave these protocols consistent, helper modules must be used. For the Universal Client Interface the only such a module is for FTP protocol.
name (read-only: name) - protocol name
ports (read-only: integer) - list of the ports on which the protocol is working
Example
To set the FTP protocol uses bot 20 and 21 TCP port:
[admin@MikroTik] ip hotspot universal service-port> print
Flags: X - disabled
  #   NAME        PORTS
  0   ftp        21
[admin@MikroTik] ip hotspot universal service-port> set ftp ports=20,21
Flags: X - disabled
  #   NAME        PORTS
  0   ftp        20
        21
