Peer to Peer Traffic Control
Document revision: | 1.5 (Thu Sep 16 11:03:16 GMT 2004) |
Applies to: | V2.8 |
General Information
Summary
This manual section describes techniques needed to control traffic from peer-to-peer (P2P) networks. Peer-to-peer is a concept whereby one individual host directly communicates with another, as opposed to each client referring to a common hub or server. This type of network connection allows users to share various information, including audio and video files and application programs. Uncontrolled P2P connections take all the available bandwith and left no space for other activities (like mail or HTTP browsing).
Quick Setup Guide
To drop all p2p application packets:
[admin@MikroTik] ip firewall rule forward> add action=drop p2p=all-p2p
Specifications
Packages required: systemLicense required: Level1 (Limited to 1 firewall rule) , Level3
Submenu level: /ip firewall, /ip firewall mangle, /queue
Hardware usage: Increases with rule count
Related Documents
Description
RouterOS is able to recognize connections of the most popular P2P protocols:
- Fasttrack (Kazaa, KazaaLite, Diet Kazaa, Grokster, iMesh, giFT, Poisoned, mlMac)
- Gnutella (Shareaza, XoLoX, , Gnucleus, BearShare, LimeWire (java), Morpheus, Phex, Swapper, Gtk-Gnutella (linux), Mutella (linux), Qtella (linux), MLDonkey, Acquisition (Mac OS), Poisoned, Swapper, Shareaza, XoloX, mlMac)
- Gnutella2 (Shareaza, MLDonkey, Gnucleus, Morpheus, Adagio, mlMac)
- DirectConnect (DirectConnect (AKA DC++), MLDonkey, NeoModus Direct Connect, BCDC++, CZDC++ )
- eDonkey (eDonkey2000, eMule, xMule (linux), Shareaza, MLDonkey, mlMac, Overnet)
- Soulseek (Soulseek, MLDonkey)
- BitTorrent (BitTorrent, BitTorrent++, Shareaza, MLDonkey, ABC, Azureus, BitAnarch, SimpleBT, BitTorrent.Net, mlMac)
- Blubster (Blubster, Piolet)
- WPNP (WinMX)
- Warez (Warez; starting from 2.8.18)
Notes
The Connection Tracking facility (/ip firewall connection tracking) must be enabled if you want to track Peet-to-Peer protocols.
It is impossible to recognize peer-to-peer traffic from the first packet. Only already established connections can be matched. That also means that in case source NAT is treating Peer-to-Peer traffic differently from the regular traffic, Peer-to-Peer programs will not work (general application is policy-routing redirecting regular traffic through one interface and Peer-to-Peer traffic - through another)
The filter will work only if it sees the traffic coming from both directions.
Traffic Marking
Submenu level: /ip firewall mangleDescription
Peer-to-peer traffic marking provided by Mangle facility labels the traffic for future processing aginst the firewall filters or queues.
Property Description
mark-connection (text; default: "") - change connection mark of the packet to this valuemark-flow (text; default: "") - change flow mark of the packet to this valuep2p (any | all-p2p | bit-torrent | direct-connect | fasttrack | soulseek | blubster | edonkey | gnutella | warez; default: any) - match Peer-to-Peer (P2P) connections:any - match any packet (i.e., do not check this property)
Traffic Filtering
Submenu level: /ip firewallDescription
RouterOS gives you ability to filter out traffic generated by P2P networks.
action (accept | drop | jump | passthrough | reject | return; default: accept) - ation to undertake if the packet matches the rule, one of the:drop - silently drop the packet (without sending the ICMP reject message)
jump - jump to the chain specified by the value of the jump-target argument
passthrough - ignore this rule, except for mangle, go on to the next one. Acts the same way as a disabled rule, except for ability to count and mangle packets
reject - reject the packet and send an ICMP reject message
return - return to the previous chain, from where the jump took place
Traffic Limiting
Submenu level: /queueDescription
You can limit peer-to-peer traffic to a given number of Kbits per second or give it lower priority than, for example HTTP traffic.
It is also possible to prioritize small file downloading over large ones using queue bursts.
Application Examples
Summary
This section will give you two examples of typical peer-to-peer traffic control configurations.
Cumulative Bandwith Limiting
Consider the following example:
Suppose we need to drop all the P2P traffic coming from the Internet, but allow the use of WinMX client between two offices limiting it to 284 Kbps in both directions. You need to do the following:
Allow WinMX client to be used between two offices
[admin@MikroTik] ip firewall rule forward> add p2p=winmx action=accept src-address=10.0.0.0/24 dst-address=10.0.1.0/24 [admin@MikroTik] ip firewall rule forward> add p2p=winmx action=accept dst-address=10.0.0.0/24 src-address=10.0.1.0/24
Drop all other P2P traffic
[admin@MikroTik] ip firewall rule forward> add p2p=all-p2p action=drop
Limit the traffic to 284 Kbps
[admin@MikroTik] queue simple> add dst-address=10.0.1.0/24 max-limit=290816/290816
Per Address Queuing
Suppose we want to limit each P2P user to a given amount of Kbps. This can be done on a per-address basis.
We should define custom queue type kind=pcq to accomplish the task. Each user upload and download rates would be limited to the pcq-rate value in the relevant queue.
First we need to mark the P2P traffic:
[admin@MikroTik] ip firewall mangle> add src-address=10.0.0.0/24 mark-flow=p2p-out \ \... p2p=all-p2p action=passthrough [admin@MikroTik] ip firewall mangle> add dst-address=10.0.0.0/24 mark-flow=p2p-in \ \... p2p=all-p2p action=passthrough [admin@MikroTik] ip firewall mangle>
Then create custom queue type with kind=pcq:
[admin@MikroTik] queue type> add name="p2p-out" kind=pcq \ \... pcq-rate=65536 pcq-classifier=src-address [admin@MikroTik] queue type> add name="p2p-in" kind=pcq pcq-rate=65536 \ \... pcq-classifier=dst-address [admin@MikroTik] queue type>
Finally, add two queues to the queue tree:
[admin@MikroTik] queue tree> add name="p2p-in" \ \... parent=global-in flow=p2p-in queue=p2p-in [admin@MikroTik] queue tree> add name="p2p-out" \ \... parent=global-out flow=p2p-out queue=p2p-out [admin@MikroTik] queue tree>
