PPPoE
Document revision: | 1.4 (Fri Apr 30 06:43:11 GMT 2004) |
Applies to: | V2.8 |
General Information
Summary
The PPPoE (Point to Point Protocol over Ethernet) protocol provides extensive user management, network management and accounting benefits to ISPs and network administrators. Currently PPPoE is used mainly by ISPs to control client connections for xDSL and cable modems as well as plain Ethernet networks. PPPoE is an extension of the standard Point to Point Protocol (PPP). The difference between them is expressed in transport method: PPPoE employs Ethernet instead of modem connection.
Generally speaking, PPPoE is used to hand out IP addresses to clients based on the user (and workstation, if desired) authentication as opposed to workstation only authentication, when static IP addresses or DHCP are used. It is adviced not to use static IP addresses or DHCP on the same interfaces as PPPoE for security reasons.
MikroTik RouterOS can act as a RADIUS client - you can use a RADIUS server to authenticate PPPoE clients and use accounting for them.
A PPPoE connection is composed of a client and an access concentrator (server). The client may be a Windows computer that has the PPPoE client protocol installed. The MikroTik RouterOS supports both - client and access concentrator implementations of PPPoE. The PPPoE client and server work over any Ethernet level interface on the router - wireless 802.11 (Aironet, Cisco, WaveLan, Prism, Atheros), 10/100/1000 Mbit/s Ethernet, RadioLan and EoIP (Ethernet over IP tunnel). No encryption, MPPE 40bit RSA and MPPE 128bit RSA encryption is supported.
Note that when RADIUS server is authenticating a user with CHAP, MS-CHAPv1, MS-CHAPv2, it does not use shared secret, it is used only in authentication reply. So if you have a wrong shared secret, RADIUS server will accept the request. You can use /radius monitor command to see bad-replies parameter. This value should increase whenever a client tries to connect.
Supported connections
- MikroTik RouterOS PPPoE client to any PPPoE server (access concentrator)
- MikroTik RouterOS server (access concentrator) to multiple PPPoE clients (clients are avaliable for almost all operating systems and some routers)
Quick Setup Guide
To configure MikroTik RouterOS to be a PPPoE client
Just add a pppoe-client:
/interface pppoe-client add name=pppoe-user-mike user=mike password=123 interface=wlan1 \ \... service-name=internet disabled=no
To configure MikroTik RouterOS to be an Access Concentrator (PPPoE Server)
Add an address pool for the clients from 10.1.1.62 to 10.1.1.72, called pppoe-pool:
/ip pool add name="pppoe-pool" ranges=10.1.1.62-10.1.1.72
Add PPP profile, called pppoe-profile where local-address will be the router's address and clients will have an address from pppoe-pool:
/ppp profile add name="pppoe-profile" local-address=10.1.1.1 remote-address=pppoe-pool
Add a user with username mike and password 123:
/ppp secret add name=mike password=123 service=pppoe profile=pppoe-profile
Now add a pppoe server:
/interface pppoe-server server add service-name=internet interface=wlan1 \ \... default-profile=pppoe-profile
Specifications
Packages required: pppLicense required: Level1 (limited to 1 interface) , Level3 (limited to 200 interfaces) , Level4 (limited to 200 interfaces) , Level5 (limited to 500 interfaces) , Level6 (unlimited)
Submenu level: /interface pppoe-server, /interface pppoe-client
Standards and Technologies: PPPoE (RFC 2516)
Hardware usage: PPPoE server may require additional RAM (uses approx. 50kB for each connection) and CPU power. Supports maximum of 10000 connections
Related Documents
Additional Resources
Links for PPPoE documentation:
PPPoE Clients:
RASPPPoE for Windows 95, 98, 98SE, ME, NT4, 2000, XP, .NET
http://user.cs.tu-berlin.de/~normanb
PPPoE Client Setup
Submenu level: /interface pppoe-clientDescription
The PPPoE client supports high-speed connections. It is fully compatible with the MikroTik PPPoE server (access concentrator).
Note for Windows. Some connection instructions may use the form where the "phone number" us "MikroTik_AC\mt1" to indicate that "MikroTik_AC" is the access concentrator name and "mt1" is the service name.
Property Description
name (name; default: pppoe-out1) - name of the PPPoE interface interface (name) - interface the PPPoE server can be connected through mtu (integer; default: 1480) - Maximum Transmission Unit. The optimal value is the MTU of the interface the tunnel is working over decreased by 20 (so, for 1500-byte ethernet link, set the MTU to 1480 to avoid fragmentation of packets) mru (integer; default: 1480) - Maximum Receive Unit. The optimal value is the MTU of the interface the tunnel is working over decreased by 20 (so, for 1500-byte ethernet link, set the MTU to 1480 to avoid fragmentation of packets) user (text; default: "") - a user name that is present on the PPPoE server password (text; default: "") - a user password used to connect the PPPoE server profile (name) - default profile for the connection allow (multiple choice: mschap2, mschap1, chap, pap; default: mschap2, mschap1, chap, pap) - the protocol to allow the client to use for authentication service-name (text; default: "") - specifies the service name set on the access concentrator. Leave it blank unless you have many services and need to specify the one you need to connect to ac-name (text; default: "") - this may be left blank and the client will connect to any access concentrator that offers the "service" name selected add-default-route (yes | no; default: no) - whether to add a default route automatically dial-on-demand (yes | no; default: no) - connects to AC only when outbound traffic is generated and disconnects when there is no traffic for the period set in the idle-timeout value use-peer-dns (yes | no; default: no) - whether to set the router's default DNS to the PPP peer DNS (i.e. whether to get DNS settings from the peer)Notes
If there is a default route, add-default-route will not create a new one.
Example
To add and enable PPPoE client on the gig interface connecting to the AC that provides testSN service using user name john with the password password:
[admin@RemoteOffice] interface pppoe-client> add interface=gig \ \... service-name=testSN user=john password=password disabled=no [admin@RemoteOffice] interface pppoe-client> print Flags: X - disabled, R - running 0 R name="pppoe-out1" mtu=1480 mru=1480 interface=gig user="john" password="password" profile=default service-name="testSN" ac-name="" add-default-route=no dial-on-demand=no use-peer-dns=no
Monitoring PPPoE Client
Command name: /interface pppoe-client monitorProperty Description
status (text) - status of the clientVerifying password... - connection has been established to the server, password verification in progress
Connected - self-explanatory
Terminated - interface is not enabled or the other side will not establish a connection uptime (time) - connection time displayed in days, hours, minutes and seconds
Example
To monitor the pppoe-out1 connection:
[admin@MikroTik] interface pppoe-client> monitor pppoe-out1 status: "connected" uptime: 10s encoding: "none" service-name: "testSN" ac-name: "10.0.0.1" ac-mac: 00:C0:DF:07:5E:E6 [admin@MikroTik] interface pppoe-client>
PPPoE Server Setup (Access Concentrator)
Submenu level: /interface pppoe-server serverDescription
The PPPoE server (access concentrator) supports multiple servers for each interface - with differing service names. Currently the throughput of the PPPoE server has been tested to 160 Mb/s on a Celeron 600 CPU. Using higher speed CPUs, throughput should increase proportionately.
The access concentrator name and PPPoE service name are used by clients to identity the access concentrator to register with. The access concentrator name is the same as the identity of the router displayed before the command prompt. The identity may be set within the /system identity submenu.
PPPoE users are created in /ppp secret menu, see the AAA manual for further information.
Note that if no service name is specified in WindowsXP, it will use only service with no name. So if you want to serve WindowsXP clients, leave your service name empty.
service-name (text) - the PPPoE service name mtu (integer; default: 1480) - Maximum Transmission Unit. The optimal value is the MTU of the interface the tunnel is working over decreased by 20 (so, for 1500-byte Ethernet link, set the MTU to 1480 to avoid fragmentation of packets) mru (integer; default: 1480) - Maximum Receive Unit. The optimal value is the MTU of the interface the tunnel is working over decreased by 20 (so, for 1500-byte Ethernet link, set the MTU to 1480 to avoid fragmentation of packets) authentication (multiple choice: mschap2 | mschap1 | chap | pap; default: mschap2, mschap1, chap, pap) - authentication algorithm keepalive-timeout - defines the time period (in seconds) after which the router is starting to send keepalive packets every second. If no traffic and no keepalive responses has came for that period of time (i.e. 2 * keepalive-timeout), not responding client is proclaimed disconnected. one-session-per-host (yes | no; default: no) - allow only one session per host (determined by MAC address). If a host will try to establish a new session, the old one will be closed default-profile (name; default: default) - default profile to useNotes
The default keepalive-timeout value of 10 is OK in most cases. If you set it to 0, the router will not disconnect clients until they log out or router is restarted. To resolve this problem, the one-session-per-host property can be used.
Security issue: do not assign an IP address to the interface you will be receiving the PPPoE requests on.
Example
To add PPPoE server on ether1 interface providing ex service and allowing only one connection per host:
[admin@MikroTik] interface pppoe-server server> add interface=ether1 \ \... service-name=ex one-session-per-host=yes [admin@MikroTik] interface pppoe-server server> print Flags: X - disabled 0 X service-name="ex" interface=ether1 mtu=1480 mru=1480 authentication=mschap2,mschap,chap,pap keepalive-timeout=10 one-session-per-host=yes default-profile=default [admin@MikroTik] interface pppoe-server server>
PPPoE Server Users
Submenu level: /interface pppoe-serverProperty Description
name (name) - interface name service-name (name) - name of the service the user is connected to remote-address (MAC address) - MAC address of the connected client user (name) - the name of the connected user encoding (text) - encryption and encoding (if asymmetric, separated with '/') being used in this connection uptime - shows how long the client is connectedExample
To view the currently connected users:
[admin@MikroTik] interface pppoe-server> print Flags: R - running # NAME SERVICE REMOTE-ADDRESS USER ENCO... UPTIME 0 R <pppoe-ex> ex 00:C0:CA:16:16:A5 ex 12s [admin@MikroTik] interface pppoe-server>
To disconnect the user ex:
[admin@MikroTik] interface pppoe-server> remove [find user=ex] [admin@MikroTik] interface pppoe-server> print [admin@MikroTik] interface pppoe-server>
Troubleshooting
Description
I can connect to my PPPoE server. The ping goes even through it, but I still cannot open web pages
Make sure that you have specified a valid DNS server in the router (in /ip dns or in /ppp profile the dns-server parameter).
The PPPoE server shows more than one active user entry for one client, when the clients disconnect, they are still shown and active
Set the keepalive-timeout parameter (in the PPPoE server configuration) to 10 if You want clients to be considered logged off if they do not respond for 10 seconds.
Note that if the keepalive-timeout parameter is set to 0 and the only-one parameter (in PPP profile settings) is set to yes then the clients might be able to connect only once. To resolve this problem one-session-per-host parameter in PPPoE server configuration should be set to yes
I can get through the PPPoE link only small packets (eg. pings)
You need to change mss of all the packets passing through the PPPoE link to the value of PPPoE link's MTU-40 at least on one of the peers. So for PPPoE link with MTU of 1480:
[admin@MT] interface pppoe-server server> set 0 max-mtu=1440 max-mru=1440 [admin@MT] interface pppoe-server server> print Flags: X - disabled 0 service-name="mt" interface=wlan1 max-mtu=1440 max-mru=1440 authentication=pap,chap,mschap1,mschap2 keepalive-timeout=10 one-session-per-host=yes max-sessions=0 default-profile=default [admin@MT] interface pppoe-server server>
My windows PPPoE client obtains IP address and default gateway from the MikroTik PPPoE server, but it cannot ping beyond the PPPoE server and use the Internet
PPPoE server is not bridging the clients. Configure masquerading for the PPPoE client addresses, or make sure you have proper routing for the address space used by the clients, or you enable Proxy-ARP on the Ethernet interface (See the IP Addresses and Address Resolution Protocol (ARP) Manual)
My Windows XP client cannot connect to the PPPoE server
You have to specify the "Service Name" in the properties of the XP PPPoE client. If the service name is not set, or it does not match the service name of the MikroTik PPPoE server, you get the "line is busy" errors, or the system shows "verifying password - unknown error"
I want to have logs for PPPoE connection establishment
Configure the logging feature under the /system logging facility and enable the PPP type logs
Application Examples
PPPoE in a multipoint wireless 802.11 network
In a wireless network, the PPPoE server may be attached to an Access Point (as well as to a regular station of wireless infrastructure). Either our RouterOS client or Windows PPPoE clients may connect to the Access Point for PPPoE authentication. Further, for RouterOS clients, the radio interface may be set to MTU 1600 so that the PPPoE interface may be set to MTU 1500. This optimizes the transmission of 1500 byte packets and avoids any problems associated with MTUs lower than 1500. It has not been determined how to change the MTU of the Windows wireless interface at this moment.
Let us consider the following setup where the MikroTik Wireless AP offers wireless clients transparent access to the local network with authentication:
Note that you should have Basic + Wireless + Wireless AP licenses for this setup.
First of all, the Prism interface should be configured:
[admin@MT_Prism_AP] interface prism> set 0 mode=ap-bridge frequency=2442MHz \ \... ssid=mt disabled=no [admin@MT_Prism_AP] interface prism> print Flags: X - disabled, R - running 0 R name="prism1" mtu=1500 mac-address=00:90:4B:02:17:E2 arp=enabled mode=ap-bridge root-ap=00:00:00:00:00:00 frequency=2442MHz ssid="mt" default-authentication=yes default-forwarding=yes max-clients=2007 card-type=generic tx-power=auto supported-rates=1-11 basic-rates=1 hide-ssid=no [admin@MT_Prism_AP] interface prism> /ip address
Now, the Ethernet interface and IP address are to be set:
[admin@MT_Prism_AP] ip address> add address=10.0.0.217/24 interface=Local [admin@MT_Prism_AP] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.0.0.217/24 10.0.0.0 10.0.0.255 Local [admin@MT_Prism_AP] ip address> /ip route [admin@MT_Prism_AP] ip route> add gateway=10.0.0.1 [admin@MT_Prism_AP] ip route> print Flags: X - disabled, I - invalid, D - dynamic, J - rejected, C - connect, S - static, R - rip, O - ospf, B - bgp # DST-ADDRESS G GATEWAY DISTANCE INTERFACE 0 S 0.0.0.0/0 r 10.0.0.1 1 Local 1 DC 10.0.0.0/24 r 0.0.0.0 0 Local [admin@MT_Prism_AP] ip route> /interface ethernet [admin@MT_Prism_AP] interface ethernet> set Local arp=proxy-arp [admin@MT_Prism_AP] interface ethernet> print Flags: X - disabled, R - running # NAME MTU MAC-ADDRESS ARP 0 R Local 1500 00:50:08:00:00:F5 proxy-arp [admin@MT_Prism_AP] interface ethernet>
We should add PPPoE server to the Prism interface:
[admin@MT_Prism_AP] interface pppoe-server server> add interface=prism1 \ \... service-name=mt one-session-per-host=yes disabled=no [admin@MT_Prism_AP] interface pppoe-server server> print Flags: X - disabled 0 service-name="mt" interface=prism1 mtu=1480 mru=1480 authentication=mschap2,mschap,chap,pap keepalive-timeout=10 one-session-per-host=yes default-profile=default [admin@MT_Prism_AP] interface pppoe-server server>
MSS should be changed for the packets flowing through the PPPoE link:
[admin@MT_Prism_AP] ip firewall mangle> add protocol=tcp tcp-options=syn-only \ \.. action=passthrough tcp-mss=1440 [admin@MT_Prism_AP] ip firewall mangle> print Flags: X - disabled, I - invalid 0 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 protocol=tcp tcp-options=syn-only icmp-options=any:any flow="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=passthrough mark-flow="" tcp-mss=1440 [admin@MT_Prism_AP] ip firewall mangle>
And finally, we can set up PPPoE clients:
[admin@MT_Prism_AP] ip pool> add name=pppoe ranges=10.0.0.230-10.0.0.240 [admin@MT_Prism_AP] ip pool> print # NAME RANGES 0 pppoe 10.0.0.230-10.0.0.240 [admin@MT_Prism_AP] ip pool> /ppp profile [admin@MT_Prism_AP] ppp profile> set default use-encryption=yes \ \... local-address=10.0.0.217 remote-address=pppoe [admin@MT_Prism_AP] ppp profile> print Flags: * - default 0 * name="default" local-address=10.0.0.217 remote-address=pppoe session-timeout=0s idle-timeout=0s use-compression=no use-vj-compression=no use-encryption=yes require-encryption=no only-one=no tx-bit-rate=0 rx-bit-rate=0 incoming-filter="" outgoing-filter="" [admin@MT_Prism_AP] ppp profile> .. secret [admin@MT_Prism_AP] ppp secret> add name=w password=wkst service=pppoe [admin@MT_Prism_AP] ppp secret> add name=l password=ltp service=pppoe [admin@MT_Prism_AP] ppp secret> print Flags: X - disabled # NAME SERVICE CALLER-ID PASSWORD PROFILE 0 w pppoe wkst default 1 l pppoe ltp default [admin@MT_Prism_AP] ppp secret>
Thus we have completed the configuration and added two users: w and l who are able to connect using PPPoE client software.
Note that Windows XP built-in client supports encryption, but RASPPPOE does not. So, if it is planned not to support Windows clients older than Windows XP, it is recommended to switch require-encryption to yes value in the default profile configuration. In other case, the server will accept clients that do not encrypt data.
