FrameRelay (PVC, Private Virtual Circuit) Interface
Document revision: | 1.1 (Fri Mar 05 08:14:41 GMT 2004) |
Applies to: | V2.8 |
General Information
Summary
Frame Relay is a multiplexed interface to packet switched network and is a simplified form of Packet Switching similar in principle to X.25 in which synchronous frames of data are routed to different destinations depending on header information. Frame Relay uses the synchronous HDLC frame format.
Specifications
Packages required: synchronousLicense required: Level4
Submenu level: /interface pvc
Standards and Technologies: Frame Relay (RFC1490)
Hardware usage: Not significant
Description
To use Frame Relay interface you must have already working synchronous interface. You can read how to set up synchronous boards supported by MikroTik RouterOS:
Additional Resources
Configuring Frame Relay Interface
Submenu level: /interface pvcDescription
To configure frame relay, at first you should set up the synchronous interface, and then the PVC interface.
Property Description
name (name; default: pvcN) - assigned name of the interface mtu (integer; default: 1500) - Maximum Transmission Unit of an interface dlci (integer; default: 16) - Data Link Connection Identifier assigned to the PVC interface interface (name) - Frame Relay interfaceNotes
A DLCI is a channel number (Data Link Connection Identifier) which is attached to data frames to tell the network how to route the data. Frame Relay is "statistically multiplexed", which means that only one frame can be transmitted at a time but many logical connections can co-exist on a single physical line. The DLCI allows the data to be logically tied to one of the connections so that once it gets to the network, it knows where to send it.
Frame Relay Configuration
Example with Cyclades Interface
Let us consider the following network setup with MikroTik router with Cyclades PC300 interface connected to a leased line with baseband modems and a Cisco router at the other end.
[admin@MikroTik] ip address> add interface=pvc1 address=1.1.1.1 netmask=255.255.255.0 [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 1.1.1.1/24 1.1.1.0 1.1.1.255 pvc1 [admin@MikroTik] ip address>
PVC and Cyclades interface configuration
Cyclades
[admin@MikroTik] interface cyclades> print Flags: X - disabled, R - running 0 R name="cyclades1" mtu=1500 line-protocol=frame-relay media-type=V35 clock-rate=64000 clock-source=external line-code=B8ZS framing-mode=ESF line-build-out=0dB rx-sensitivity=short-haul frame-relay-lmi-type=ansi frame-relay-dce=no chdlc-keepalive=10s [admin@MikroTik] interface cyclades>
PVC
[admin@MikroTik] interface pvc> print Flags: X - disabled, R - running # NAME MTU DLCI INTERFACE 0 R pvc1 1500 42 cyclades1 [admin@MikroTik] interface pvc>
Cisco router setup
CISCO# show running-config Building configuration... Current configuration... ... ! ip subnet-zero no ip domain-lookup frame-relay switching ! interface Ethernet0 description connected to EthernetLAN ip address 10.0.0.254 255.255.255.0 ! interface Serial0 description connected to Internet no ip address encapsulation frame-relay IETF serial restart-delay 1 frame-relay lmi-type ansi frame-relay intf-type dce ! interface Serial0.1 point-to-point ip address 1.1.1.2 255.255.255.0 no arp frame-relay frame-relay interface-dlci 42 ! ... end.
Send ping to MikroTik router
CISCO#ping 1.1.1.1 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 28/31/32 ms CISCO#
Example with MOXA Interface
Let us consider the following network setup with MikroTik router with MOXA C502 synchronous interface connected to a leased line with baseband modems and a Cisco router at the other end.
PVC and Moxa interface configuration
Moxa
[admin@MikroTik] interface moxa-c502> print Flags: X - disabled, R - running 0 R name="moxa1" mtu=1500 line-protocol=frame-relay clock-rate=64000 clock-source=external frame-relay-lmi-type=ansi frame-relay-dce=no cisco-hdlc-keepalive-interval=10s 1 X name="moxa-c502-2" mtu=1500 line-protocol=sync-ppp clock-rate=64000 clock-source=external frame-relay-lmi-type=ansi frame-relay-dce=no cisco-hdlc-keepalive-interval=10s [admin@MikroTik] interface moxa-c502>
PVC
[admin@MikroTik] interface pvc> print Flags: X - disabled, R - running # NAME MTU DLCI INTERFACE 0 R pvc1 1500 42 moxa1 [admin@MikroTik] interface pvc> CISCO router setup CISCO# show running-config Building configuration... Current configuration... ... ! ip subnet-zero no ip domain-lookup frame-relay switching ! interface Ethernet0 description connected to EthernetLAN ip address 10.0.0.254 255.255.255.0 ! interface Serial0 description connected to Internet no ip address encapsulation frame-relay IETF serial restart-delay 1 frame-relay lmi-type ansi frame-relay intf-type dce ! interface Serial0.1 point-to-point ip address 1.1.1.2 255.255.255.0 no arp frame-relay frame-relay interface-dlci 42 ! ... end. Send ping to MikroTik router CISCO#ping 1.1.1.1 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 28/31/32 ms CISCO#
Example with MikroTik Router to MikroTik Router
Let us consider the following example:
In this example we will use two Moxa C101 synchronous cards.
Do not forget to set line-protocol for synchronous interfaces to frame-relay. To achieve proper result, one of the synchronous interfaces must operate in DCE mode:
[admin@r1] interface moxa-c101> set 0 frame-relay-dce=yes [admin@r1] interface moxa-c101> print Flags: X - disabled, R - running 0 R name="moxa-c101-1" mtu=1500 line-protocol=frame-relay clock-rate=64000 clock-source=external frame-relay-lmi-type=ansi frame-relay-dce=yes cisco-hdlc-keepalive-interval=10s ignore-dcd=no [admin@r1] interface moxa-c101>
Then we need to add PVC interfaces and IP addresses.
On the R1:
[admin@r1] interface pvc> add dlci=42 interface=moxa-c101-1 [admin@r1] interface pvc> print Flags: X - disabled, R - running # NAME MTU DLCI INTERFACE 0 X pvc1 1500 42 moxa-c101-1 [admin@r1] interface pvc> /ip address add address 4.4.4.1/24 interface pvc1
on the R2:
[admin@r2] interface pvc> add dlci=42 interface=moxa-c101-1 [admin@r2] interface pvc> print Flags: X - disabled, R - running # NAME MTU DLCI INTERFACE 0 X pvc1 1500 42 moxa-c101-1 [admin@r2] interface pvc> /ip address add address 4.4.4.2/24 interface pvc1
Finally, we must enable PVC interfaces:
[admin@r1] interface pvc> enable pvc1 [admin@r1] interface pvc> [admin@r2] interface pvc> enable pvc1 [admin@r2] interface pvc>
Troubleshooting
Description
I cannot ping through the synchronous frame relay interface between MikroTik router and a Cisco router
Frame Relay does not support address resolving and IETF encapsulation should be used. Please check the configuration on the Cisco router
