Bridge
| Document revision: | 1.4 (Wed Feb 02 17:06:55 GMT 2005) |
| Applies to: | V2.8 |
General Information
Summary
MAC level bridging of Ethernet, Ethernet over IP (EoIP), Prism, Atheros and RadioLAN interfaces are supported. All 802.11b and 802.11a client wireless interfaces (both ad-hoc and infrastructure or station modes) do not support this because of the limitations of 802.11 - it is possible to bridge over them using the Ethernet over IP protocol (please see documentation on EoIP).
For preventing loops in a network, you can use the Spanning Tree Protocol (STP). This protocol also makes redundant paths possible.
Features include:
- Spanning Tree Protocol (STP)
- Multiple bridge interfaces
- Bridge associations on a per interface basis
- Protocol can be selected to be forwarded or discarded
- MAC address table can be monitored in real time
- IP address assignment for router access
- Bridge interfaces can be firewalled
Quick Setup Guide
To put interface ether1 and ether2 in a bridge.
Add a bridge interface, called MyBridge:
/interface bridge add name="MyBridge" disabled=no
Add ether1 and ether2 to MyBridge interface:
/interface bridge port set ether1,ether2 bridge=MyBridge
Specifications
Packages required: systemLicense required: Level4
Submenu level: /interface bridge
Standards and Technologies: Media Access Control, IEEE801.1D
Hardware usage: Not significant
Related Documents
Description
Ethernet-like networks (Ethernet, Ethernet over IP, IEEE802.11 Wireless interfaces in AP mode) can be connected together using MAC Bridges. The bridge feature allows the interconnection of stations connected to separate LANs (using EoIP, geographically distributed networks can be bridged as well if any kind of IP network interconnection exists between them) as if they were attached to a single LAN. As bridges are transparent, they do not appear in traceroute list, and no utility can make a distinction between a host working in one LAN and a host working in another LAN if these LANs are bridged (depending on the way the LANs are interconnected, latency and data rate between hosts may vary).
Additional Resources
http://ebtables.sourceforge.net/
Bridge Interface Setup
Submenu level: /interface bridgeDescription
To bridge a number of networks into one bridge, a bridge interface should be created, that will group all the bridged interfaces. One MAC address will be assigned to all the bridged interfaces.
Property Description
ageing-time (time; default: 5m) - how long the host information will be kept in the bridge databasearp (disabled | enabled | proxy-arp | reply-only; default: enabled) - Address Resolution Protocol settingforward-delay (time; default: 15s) - time which is spent in listening/learning stateforward-protocols (multiple choice: ip, arp, appletalk, ipx, ipv6, other; default: ip, arp, appletalk, ipx, ipv6, other) - list of forwarded protocolsNotes
forwarded-protocols is a simple filter that also affects the locally-destined and locally-originated packets. So disabling ip protocol you will not be able to communicate with the router from the bridged interfaces.
Always take care not to bridge virtual interfaces with their respective parent interfaces.
Example
To add and enable a bridge interface that will forward all the protocols:
[admin@MikroTik] interface bridge> add; print
0 X name="bridge1" mtu=1500 arp=enabled mac-address=00:00:00:00:00:00
forward-protocols=ip,arp,appletalk,ipx,ipv6,other stp=no priority=32768
ageing-time=5m forward-delay=15s garbage-collection-interval=4s
hello-time=2s max-message-age=20s
[admin@MikroTik] interface bridge> enable 0
Port Settings
Submenu level: /interface bridge portDescription
The submenu is used to group interfaces in a particular bridge interface.
bridge (name; default: none) - the bridge interface the respective interface is grouped inExample
To group ether1 and ether2 in the bridge1 bridge:
[admin@MikroTik] interface bridge port> set ether1,ether2 bridge=bridge1 [admin@MikroTik] interface bridge port> print # INTERFACE BRIDGE PRIORITY PATH-COST 0 ether1 bridge1 128 10 1 ether2 bridge1 128 10 2 wlan1 none 128 10 [admin@MikroTik] interface bridge port>
Bridge Monitoring
Command name: /interface bridge monitorDescription
Used to monitor the current status of a bridge.
bridge-id (text) - the bridge ID, which is in form of bridge-priority.bridge MAC Addressdesignated-root (text) - ID of the root bridgepath-cost (integer) - the total cost of path along to the root-bridgeroot-port (name) - port to which the root bridge is connected toExample
To monitor a bridge:
[admin@MikroTik] interface bridge> monitor bridge1
bridge-id: 32768.00:02:6F:01:CE:31
designated-root: 32768.00:02:6F:01:CE:31
root-port: ether2
path-cost: 180
Bridge Port Monitoring
Command name: /interface bridge port monitorDescription
Statistics of an interface that belongs to a bridge
designated-port (text) - port of designated-root bridgedesignated-root (text) - ID of bridge, which is nearest to the root-bridgeport-id (integer) - port ID, which represents from port priority and port number, and is uniquestatus (disabled | blocking | listening | learning | forwarding) - the status of the bridge port:blocking - the port does not forward any frames, but listens for BPDUs
listening - the port does not forward any frames, but listens to them
learning - the port does not forward any frames, but learns the MAC addresses
forwarding - the port forwards frames, and learns MAC addresses
Example
To monitor a bridge port:
[admin@MikroTik] interface bridge port> mo 0
status: forwarding
port-id: 28417
designated-bridge: 32768.00:02:6F:01:CE:31
designated-port: 28417
designated-cost: 0
-- [Q quit|D dump|C-z pause]
Bridge Host Monitoring
Command name: /interface bridge hostProperty Description
age (read-only: time) - the time since the last packet was received from the hostbridge (read-only: name) - the bridge the entry belongs tomac-address (read-only: MAC address) - host's MAC addresson-interface (read-only: name) - which of the bridged interfaces the host is connected toExample
To get the active host table:
[admin@MikroTik] interface bridge host> print Flags: L - local BRIDGE MAC-ADDRESS ON-INTERFACE AGE bridge1 00:00:B4:5B:A6:58 ether1 4m48s bridge1 00:30:4F:18:58:17 ether1 4m50s L bridge1 00:50:08:00:00:F5 ether1 0s L bridge1 00:50:08:00:00:F6 ether2 0s bridge1 00:60:52:0B:B4:81 ether1 4m50s bridge1 00:C0:DF:07:5E:E6 ether1 4m46s bridge1 00:E0:C5:6E:23:25 prism1 4m48s bridge1 00:E0:F7:7F:0A:B8 ether1 1s [admin@MikroTik] interface bridge host>
Bridge Firewall
Submenu level: /interface bridge firewallDescription
Traffic between bridged interfaces can be filtered.
Note that packets between bridged interfaces are also passed through the 'generic' /ip firewall rules, so they even can be NATted. These rules can be used with real, physical receiving/transmitting interfaces, as well as with bridge interface that simply groups bridged interfaces.
action (accept | drop | passthrough; default: accept) - action to undertake if the packet matches the rule:drop - silently drop the packet (without sending the ICMP reject message)
passthrough - ignore this rule. Acts the same way as a disabled rule, except for ability to count packets
0x0004 - 802.2
0x0800 - IP
0x0806 - ARP
0x8035 - RARP
0x809B - AppleTalk (EtherTalk)
0x80F3 - AppleTalk Address Resolution Protocol (AARP)
0x8037 - IPX
0x8100 - VLAN
0x8137 - Novell (old) NetWare IPX (ECONFIG E option)
0x8191 - NetBEUI
0x86DD - IPv6
Drop broadcast packets
[admin@MikroTik] interface bridge firewall> add mac-dst-address=FF:FF:FF:FF:FF:FF action=drop
[admin@MikroTik] interface bridge firewall> print
0 mac-src-address=00:00:00:00:00:00 in-interface=all
mac-dst-address=FF:FF:FF:FF:FF:FF out-interface=all mac-protocol=all
src-address=0.0.0.0/0 dst-address=0.0.0.0/0 protocol=all action=drop
Drop IP, ARP and RARP
To make a brouter (the router that routes routable (IP in our case) protocols and bridges unroutable protocols), make a rule that drops IP, ARP, and RARP traffic (these protocols should be disabled in bridge firewall, not in forwarded protocols as in the other case the router will not be able to receive IP packets itself, and thus will not be able to provide routing).
To make bridge, drop IP, ARP and RARP packets:
[admin@MikroTik] interface bridge firewall> add mac-protocol=2048 action=drop
[admin@MikroTik] interface bridge firewall> add mac-protocol=2054 action=drop
[admin@MikroTik] interface bridge firewall> add mac-protocol=32821 action=drop
mac-dst-address=00:00:00:00:00:00 out-interface=all mac-protocol=2048
1 mac-src-address=00:00:00:00:00:00 in-interface=all
mac-dst-address=00:00:00:00:00:00 out-interface=all mac-protocol=2054
2 mac-src-address=00:00:00:00:00:00 in-interface=all
mac-dst-address=00:00:00:00:00:00 out-interface=all mac-protocol=32821
Application Example
Example
Assume we want to enable bridging between two Ethernet LAN segments and have the MikroTik router be the default gateway for them:
When configuring the MikroTik router for bridging you should do the following:
- Add a bridge interface
- Configure the bridge interface
- Enable the bridge interface
- Assign an IP address to the bridge interface, if needed
Note that there should be no IP addresses on the bridged interfaces. Moreover, IP address on the bridge interface itself is not required for the bridging to work.
When configuring the bridge settings, each protocol that should be forwarded should be added to the forward-protocols list. The other protocol includes all protocols not listed before (as VLAN).
[admin@MikroTik] interface bridge> add forward-protocols=ip,arp,other
[admin@MikroTik] interface bridge> print
forward-protocols=ip,arp,other stp=no priority=32768 ageing-time=5m
forward-delay=15s garbage-collection-interval=4s hello-time=2s
max-message-age=20s
The priority argument is used by the Spanning Tree Protocol to determine, which port remains enabled if two ports form a loop.
Next, each interface that should be included in the bridging port table:
[admin@MikroTik] interface bridge> port [admin@MikroTik] interface bridge port> print # INTERFACE BRIDGE PRIORITY PATH-COST 0 ether1 none 128 10 1 ether2 none 128 10 2 prism1 none 128 10 [admin@MikroTik] interface bridge port> set 0,1 bridge=bridge1 [admin@MikroTik] interface bridge port> print # INTERFACE BRIDGE PRIORITY PATH-COST 0 ether1 bridge1 128 10 1 ether2 bridge1 128 10 2 prism1 none 128 10 [admin@MikroTik] interface bridge port>
After setting some interfaces for bridging, the bridge interface should be enabled in order to start using it:
0 X name="bridge1" mtu=1500 arp=enabled mac-address=00:0B:6B:31:01:6A
max-message-age=20s
0 R name="bridge1" mtu=1500 arp=enabled mac-address=00:0B:6B:31:01:6A
max-message-age=20s
If you want to access the router through unnumbered bridged interfaces, it is required to add an IP address to the bridge interface:
[admin@MikroTik] ip address> add address=192.168.0.254/24 interface=bridge1 [admin@MikroTik] ip address> add address=10.1.1.12/24 interface=prism1 [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 192.168.0.254/24 192.168.0.0 192.168.0.255 bridge1 1 10.1.1.12/24 10.1.1.0 10.1.1.255 prism1 [admin@MikroTik] ip address>
Note! Assigning an IP address to bridged interfaces ether1 or ether2 has no sense, because the actual interface will be the bridge interface to which these interfaces belong. You can check this by typing /ip address print detail
Hosts on LAN segments #1 and #2 should use IP addresses from the same network. 192.168.0.0/24 and have the default gateway set to 192.168.0.254 (MikroTik router).
Troubleshooting
Description
After I configure the bridge, there is no ping response from hosts on bridged networks.
It may take up to 20...30s for bridge to learn addresses and start responding.
I have added a bridge interface, but no IP traffic is passed.
You should include 'arp' in forwarded protocols list, e.g., 'forward-protocols=ip,arp,other'.
