CISCO/Aironet 2.4GHz 11Mbps Wireless Interface
Document revision: | 1.2 (Mon May 31 20:18:58 GMT 2004) |
Applies to: | V2.8 |
General Information
Summary
The MikroTik RouterOS supports the following CISCO/Aironet 2.4GHz Wireless ISA/PCI/PC Adapter hardware:
- Aironet ISA/PCI/PC4800 2.4GHz DS 11Mbps Wireless LAN Adapters (100mW)
- Aironet ISA/PCI/PC4500 2.4GHz DS 2Mbps Wireless LAN Adapters (100mW)
- CISCO AIR-PCI340 2.4GHz DS 11Mbps Wireless LAN Adapters (30mW)
- CISCO AIR-PCI/PC350/352 2.4GHz DS 11Mbps Wireless LAN Adapters (100mW)
Specifications
Packages required: wirelessLicense required: Level4
Submenu level: /interface pc
Standards and Technologies: IEEE802.11b
Hardware usage: Not significant
Related Documents
Additional Resources
For more information about the CISCO/Aironet PCI/ISA adapter hardware please see the relevant User's Guides and Technical Reference Manuals in PDF format:
- 710-003638a0.pdffor PCI/ISA 4800 and 4500 series adapters
- 710-004239B0.pdffor PC 4800 and 4500 series adapters
Documentation about CISCO/Aironet Wireless Bridges and Access Points can be found in archives:
- AP48MAN.exe for AP4800 Wireless Access Point
- BR50MAN.exe for BR500 Wireless Bridge
Wireless Interface Configuration
Submenu level: /interface pcDescription
CISCO/Aironet 2.4GHz card is an interface for wireless networks operating in IEEE 802.11b standard. If the wireless interface card is not registered to an AP, the green status led is blinking fast. If the wireless interface card is registered to an AP, the green status led is blinking slow. To set the wireless interface for working with an access point (register to the AP), typically you should set the following parameters:
- The service set identifier. It should match the ssid of the AP. Can be blank, if you want the wireless interface card to register to an AP with any ssid. The ssid will be received from the AP, if the AP is broadcasting its ssid.
- The data-rate of the card should match one of the supported data rates of the AP. Data rate 'auto' should work in most cases.
PCI and PC (PCMCIA) cards do not require a 'manual' driver loading, since they are recognized automatically by the system and the driver is loaded at the system startup.
The ISA card requires the driver to be loaded by issuing the following command:
[admin@MikroTik]> driver add name=pc-isa io=0x180 [admin@MikroTik]> driver print Flags: I - invalid, D - dynamic # DRIVER IRQ IO MEMORY ISDN-PROTOCOL 0 D PCI NE2000 1 Aironet ISAxx00 0x180 [admin@MikroTik] driver>
There can be several reasons for a failure to load the driver:
The driver cannot be loaded because other device uses the requested IRQ.
Try to set different IRQ using the DIP switches.
The requested I/O base address cannot be used on your motherboard
Try to change the I/O base address using the DIP switches
Property Description
ap1 (MAC address) - forces association to the specified access pointap2 (MAC address) - forces association to the specified access pointap3 (MAC address) - forces association to the specified access pointap4 (MAC address) - forces association to the specified access pointarp (disabled | enabled | proxy-arp | reply-only; default: enabled) - Address Resolution Protocolbeacon-period (integer: 20..976; default: 100) - Specifies beaconing period (applicable to ad-hoc mode only)card-type (read-only: text) - your CISCO/Aironet adapter model and typeclient-name (text; default: "") - client namedata-rate - data rate in Mbit/sfragmentation-threshold (integer: 256..2312; default: 2312) - this threshold controls the packet size at which outgoing packets will be split into multiple fragments. If a single fragment transmit error occurs, only that fragment will have to be retransmitted instead of the whole packet. Use a low setting in areas with poor communication or with a great deal of radio interferencefrequency - Channel Frequency in MHz (applicable to ad-hoc mode only)join-net (time; default: 10) - an amount of time,during which the interface operating in ad-hoc mode will try to connect to an existing network rather than create a new onembok - M-ary Bi-Orthogonal Keying
Example
Interface informational printouts
[admin@MikroTik] > interface print Flags: X - disabled, D - dynamic, R - running # NAME TYPE MTU 0 R ether1 ether 1500 1 X ether2 ether 1500 2 X pc1 pc 1500 [admin@MikroTik] interface> set 1 name aironet [admin@MikroTik] interface> enable aironet [admin@MikroTik] > interface print Flags: X - disabled, D - dynamic, R - running # NAME TYPE MTU 0 R ether1 ether 1500 1 X ether2 ether 1500 2 R aironet pc 1500 [admin@MikroTik] > interface pc [admin@MikroTik] interface pc> print Flags: X - disabled, R - running 0 R name="aironet" mtu=1500 mac-address=00:40:96:29:2F:80 arp=enabled client-name="" ssid1="tsunami" ssid2="" ssid3="" mode=infrastructure data-rate=1Mbit/s frequency=2437MHz modulation=cck tx-power=100 ap1=00:00:00:00:00:00 ap2=00:00:00:00:00:00 ap3=00:00:00:00:00:00 ap4=00:00:00:00:00:00 rx-antenna=right tx-antenna=right beacon-period=100 long-retry-limit=16 short-retry-limit=16 rts-threshold=2312 fragmentation-threshold=2312 join-net=10s card-type=PC4800A 3.65 [admin@MikroTik] interface pc>
Interface status monitoring
[admin@MikroTik] interface pc> monitor 0 synchronized: no associated: no error-number: 0 [admin@MikroTik] interface pc>
Example
Suppose we want to configure the wireless interface to accomplish registration on the AP with a ssid 'mt'.
We need to change the value of ssid property to the corresponding value.
To view the results, we can use monitor feature.
[admin@MikroTik] interface pc> set 0 ssid1 mt [admin@MikroTik] interface pc> monitor 0 synchronized: yes associated: yes frequency: 2412MHz data-rate: 11Mbit/s ssid: "mt" access-point: 00:02:6F:01:5D:FE access-point-name: "" signal-quality: 132 signal-strength: -82 error-number: 0 [admin@MikroTik] interface pc>
Troubleshooting
Description
Keep in mind, that not all combinations of I/O base addresses and IRQs may work on particular motherboard. It is recommended that you choose an IRQ not used in your system, and then try to find an acceptable I/O base address setting. As it has been observed, the IRQ 5 and I/O 0x300 or 0x180 will work in most cases.
The requested I/O base address cannot be used on your motherboard.
Try to change the I/O base address using the DIP switches.
The pc interface does not show up under the interfaces list
Obtain the required license for 2.4/5GHz Wireless Client feature.
The wireless card does not register to the Access Point
Check the cabling and antenna alignment.
Application Examples
Point-to-Multipoint Wireless LAN
Let us consider the following network setup with CISCO/Aironet Wireless Access Point as a base station and MikroTik Wireless Router as a client:
The access point is connected to the wired network's HUB and has IP address from the network 10.1.1.0/24.
The minimum configuration required for the AP is:
- Setting the Service Set Identifier (up to 32 alphanumeric characters). In our case we use ssid "mt".
- Setting the allowed data rates at 1-11Mbps, and the basic rate at 1Mbps.
- Choosing the frequency, in our case we use 2442MHz.
- (For CISCO/Aironet Bridges only) Set Configuration/Radio/Extended/Bridge/mode=access_point. If you leave it to 'bridge_only', it wont register clients.
- Setting the identity parameters Configuration/Ident: Inaddr, Inmask, and Gateway. These are required if you want to access the AP remotely using telnet or http.
The IP addresses assigned to the wireless interface should be from the network 10.1.1.0/24:
[admin@MikroTik] ip address> add address 10.1.1.12/24 interface aironet [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.1.1.12/24 10.1.1.0 10.1.1.255 aironet 1 192.168.0.254/24 192.168.0.0 192.168.0.255 Local [admin@MikroTik] ip address>
The default route should be set to the gateway router 10.1.1.254 (! not the AP 10.1.1.250 !):
[admin@MikroTik] ip route> add gateway=10.1.1.254 [admin@MikroTik] ip route> print Flags: X - disabled, I - invalid, D - dynamic, J - rejected, C - connect, S - static, R - rip, O - ospf, B - bgp # DST-ADDRESS G GATEWAY DISTANCE INTERFACE 0 S 0.0.0.0/0 r 10.1.1.254 1 aironet 1 DC 192.168.0.0/24 r 0.0.0.0 0 Local 2 DC 10.1.1.0/24 r 0.0.0.0 0 aironet [admin@MikroTik] ip route>
Point-to-Point Wireless LAN
Point-to-Point links provide a convenient way to connect a pair of clients on a short distance.
Let us consider the following point-to-point wireless network setup with two MikroTik wireless routers:
To establish a point-to-point link, the configuration of the wireless interface should be as follows:
- A unique Service Set Identifier should be chosen for both ends, say "mt"
- A channel frequency should be selected for the link, say 2412MHz
- The operation mode should be set to ad-hoc
- One of the units (slave) should have wireless interface property join-net set to 0s (never create a network), the other unit (master) should be set to 1s or whatever, say 10s. This will enable the master unit to create a network and register the slave unit to it.
The following command should be issued to change the settings for the pc interface of the master unit:
[admin@MikroTik] interface pc> set 0 mode=ad-hoc ssid1=mt frequency=2442MHz \ \... bitrate=auto [admin@MikroTik] interface pc>
For 10 seconds (this is set by the property join-net) the wireless card will look for a network to join. The status of the card is not synchronized, and the green status light is blinking fast. If the card cannot find a network, it creates its own network. The status of the card becomes synchronized, and the green status led becomes solid.
The monitor command shows the new status and the MAC address generated:
[admin@MikroTik] interface pc> monitor 0 synchronized: yes associated: yes frequency: 2442MHz data-rate: 11Mbit/s ssid: "mt" access-point: 2E:00:B8:01:98:01 access-point-name: "" signal-quality: 35 signal-strength: -62 error-number: 0 [admin@MikroTik] interface pc>
The other router of the point-to-point link requires the operation mode set to ad-hoc, the System Service Identifier set to 'mt', and the channel frequency set to 2412MHz. If the cards are able to establish RF connection, the status of the card should become synchronized, and the green status led should become solid immediately after entering the command:
[admin@wnet_gw] interface pc> set 0 mode=ad-hoc ssid1=b_link frequency=2412MHz \ \... bitrate=auto [admin@wnet_gw] interface pc> monitor 0 synchronized: yes associated: no frequency: 2442MHz data-rate: 11Mbit/s ssid: "b_link" access-point: 2E:00:B8:01:98:01 access-point-name: "" signal-quality: 131 signal-strength: -83 error-number: 0 [admin@wnet_gw] interface pc>
As we see, the MAC address under the access-point property is the same as on the first router.
If desired, IP addresses can be assigned to the wireless interfaces of the pint-to-point linked routers using a smaller subnet, say 30-bit one:
[admin@MikroTik] ip address> add address 192.168.11.1/30 interface aironet [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 192.168.11.1/30 192.168.11.0 192.168.11.3 aironet 1 192.168.0.254/24 192.168.0.0 192.168.0.255 Local [admin@MikroTik] ip address>
The second router will have address 192.168.11.2. The network connectivity can be tested by using ping or bandwidth test:
[admin@wnet_gw] ip address> add address 192.168.11.2/30 interface aironet [admin@wnet_gw] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 192.168.11.2/30 192.168.11.0 192.168.11.3 aironet 1 10.1.1.12/24 10.1.1.0 10.1.1.255 Public [admin@wnet_gw] ip address> /ping 192.168.11.1 192.168.11.1 pong: ttl=255 time=3 ms 192.168.11.1 pong: ttl=255 time=1 ms 192.168.11.1 pong: ttl=255 time=1 ms 192.168.11.1 pong: ttl=255 ping interrupted 4 packets transmitted, 4 packets received, 0% packet loss round-trip min/avg/max = 1/1.5/3 ms [admin@wnet_gw] interface pc> /tool bandwidth-test 192.168.11.1 protocol tcp status: running rx-current: 4.61Mbps rx-10-second-average: 4.25Mbps rx-total-average: 4.27Mbps [admin@wnet_gw] interface pc> /tool bandwidth-test 192.168.11.1 protocol udp size 1500 status: running rx-current: 5.64Mbps rx-10-second-average: 5.32Mbps rx-total-average: 4.87Mbps [admin@wnet_gw] interface pc>
