The ceiling AP on steroids! Our bestseller cAP is back – juiced up and stronger than ever. Compared to the previous cAP models, the improved high-gain antenna increases the covered area by up to 100%!
An out-of-the-box 863-870 MHz IoT Gateway solution for LoRa® technology. For ultimate versatility and cost-effectiveness. The first gateway with a CAT-M interface for LoRa®!
An out-of-the-box 902-928 MHz IoT Gateway solution for LoRa® technology. For ultimate versatility and cost-effectiveness. The first gateway with a CAT-M interface for LoRa®!
The ultimate heavy-duty home lab router with USB 3.0, 1G and 2.5G Ethernet and a 10G SFP+ cage. You can mount four of these new routers in a single 1U rackmount space! Unprecedented processing power in such a small form factor.
This powerful and affordable router crushes all previous CCR models in single-core performance. 16x Gigabit Ethernet ports, 2x10G SFP+ cages, active cooling and the best single-core performance per watt & best overall performance per watt among all the CCR devices.
One router to delight them all – introducing the ultimate home AP with ultra-fast LTE/5G support
5x Ethernet, Small plastic case, 850MHz CPU, 64MB RAM, Most affordable MPLS router, RouterOS L4
5xEthernet with PoE output for four ports, USB, 650MHz CPU, 64MB RAM, RouterOS L4
650MHz CPU, 64MB RAM, 5xEthernet with PoE output for four ports, RouterOS L4, outdoor case, PSU
5x Gigabit Ethernet, SFP, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4, IPsec hardware encryption support and The Dude server package
5x Gigabit Ethernet with PoE output for four ports, SFP, USB, 800MHz CPU, 128MB RAM, RouterOS L4
Desktop metal case, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
1U rackmount, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
Five Gigabit Ethernet Router with 4xPoE-out ports, SFP cage and outdoor enclosure
Desktop metal case, 5xEthernet, 5xGigabit Ethernet, SFP cage, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
Desktop metal case, 5xEthernet, 5xGigabit Ethernet, USB, LCD, PoE out on port 10, 600MHz CPU, 128MB RAM, RouterOS L5
1U rackmount, 5xEthernet, 5xGigabit Ethernet, USB, LCD, PoE out on port 10, 600MHz CPU, 128MB RAM, RouterOS L5
1U rackmount, 10xGigabit Ethernet, SFP, USB 3.0, LCD, PoE out on port 10, 2x1.4GHz CPU, 1GB RAM, RouterOS L5
Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage and desktop case with rack ears
Powerful 1U rackmount router with 13x Gigabit Ethernet ports, 60GB M.2 drive for Dude database
7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 9 cores x 1GHz CPU, 1GB RAM, passive cooling case, RouterOS L6
7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1GHz CPU, 2GB RAM, LCD panel, passive cooling desktop enclosure, SmartCard slot, RouterOS L6, PSU
1U rackmount, 7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, SmartCard slot, RouterOS L6
The Connectivity Router - your best companion when it comes to SFP, SFP+ and SFP28 management! 1, 10 and 25 Gbps ports in a single device to make your life easier.
1U rackmount, 12x Gigabit Ethernet, LCD, 16 cores x 1.2GHz CPU, 2GB RAM, 17.8mpps fastpath, Up to 12Gbit/s throughput, RouterOS L6, Dual PSU
1U rackmount, 12xSFP cage, 1xSFP+ cage, 16 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, RouterOS L6
1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD, 36 cores x 1.2GHz CPU, 4GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6, Dual PSU
1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD, 36 cores x 1.2GHz CPU, 4GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6, Dual PSU
1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD, 36 cores x 1.2GHz CPU, 8GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6, Dual PSU
1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD, 36 cores x 1.2GHz CPU, 8GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6, Dual PSU
1U rackmount, 1x Gigabit Ethernet, 8xSFP+ cages, LCD, 72 cores x 1GHz CPU, 16GB RAM, up to 120 million packets per second, 80Gbps throughput, RouterOS L6
A remarkable outdoor switch for setting up an optical 10G network that can even perform some light routing. The spiritual successor to the beloved FiberBox. Gigabit Ethernet, SFP/SFP+, PoE.
Smart Switch, 5x SFP cages, 1x Combo port (SFP or Gigabit Ethernet), 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
Eight 1G Ethernet ports and two SFP+ ports for 10G fiber connectivity. Portable, powerful and extremely cost-effective – this switch is an instant classic!
8x Gigabit Ethernet Smart Switch, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
SwOS powered 24 port Gigabit Ethernet switch with two SFP+ ports in 1U rackmount case
8x Gigabit Smart Switch, 1x SFP cage, LCD, 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5, supports 10-57V, 802.3af/at compliant
Five-port desktop switch with one Gigabit Ethernet port and four SFP+ 10Gbps ports
An outdoor 18 port switch with 15 reverse PoE ports and SFP. Cut costs, not speed – choose GPEN over GPON!
8x Gigabit Ethernet Smart Switch with PoE-out, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
24 Gigabit ports, 2 SFP+ cages and a desktop case – server room power for your home!
24 Gigabit port switch with 2 x SFP+ cages in 1U rackmount case, Dual boot (RouterOS or SwitchOS)
24x Gigabit Ethernet layer 3 Smart Switch, 1x SFP cage, LCD, 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5
Smart Switch, 1x Gigabit LAN, 10x SFP cages, 1x SFP+ cage, LCD, 400MHz CPU, 64MB RAM, Metal desktop case, RouterOS L5
An outdoor 18 port switch with 16 Gigabit PoE-out ports and 2 SFP+. Power all your access points anywhere!
Smart Switch, 20 x SFP cages, 4 x SFP+ cages, 4 x Combo ports (Gigabit Ethernet or SFP), 800MHz CPU, 512MB RAM, 1U rackmount case, Dual Power Supplies, RouterOS L5 or SwitchOS (Dual Boot)
24 port Gigabit Ethernet router/switch with four 10Gbps SFP+ ports in 1U rackmount case, Dual Boot and PoE output, 500W
Smart Switch, 1 x Gigabit LAN, 16 x SFP+ cages, Dual Core 800MHz CPU, 1GB RAM, 1U rackmount passive cooling case, Dual Power Supplies
Best price and best performance on the market – this 48 port switch will rock any setup, including 40 Gbps devices!
Switch of the future: the first MikroTik product with 10G RJ45 Ethernet ports and SFP+
Low-cost High Power small-size 16dBi 5GHz dual chain integrated CPE/Backbone
Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone with AC support and Gigabit Ethernet
Dual chain 5GHz system with Gigabit Ethernet and 802.11ac support for long distance links with satellite offset dish antennas
Outdoor 5GHz 802.11a/n/ac wireless device with a backfire type 21dBi integrated antenna and Gigabit Ethernet for longer distances
2.4GHz/5GHz AP/Backbone/CPE, N-male connector, includes 2.4GHz/5GHz 6dBi Omni Antenna
Dual chain eXtra Large High Power 27dBi 5GHz CPE/Point-to-Point Integrated Antenna
5Ghz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
2.4Ghz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
Dual chain 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna with AC support and Gigabit Ethernet
6GHz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
2.4GHz/5GHz AP/Backbone/CPE with 802.11ac and Gigabit Ethernet, N-male connector + Omni antenna
Dual chain Long Range 27dBi 5GHz CPE/Point-to-Point Integrated Antenna with AC support and Gigabit Ethernet
2.4GHz 120 degree 12dBi dual polarization sector Integrated antenna with 600Mhz CPU, 64MB RAM, Gigabit Ethernet, PSU and PoE
7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports
2.4/5GHz software selectable AP/Backbone/CPE with AC support, high TX power, N-male connector, Omni antenna included
7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports with PoE-out
5GHz 120 degree 15dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
Dual chain 5GHz integrated 802.11a/n/ac AP/Backbone/CPE with an additional miniPCI-e slot, 2xRPSMA connectors, Gigabit Ethernet, waterproof metal enclosure
Dual chain 5GHz integrated 802.11ac AP/Backbone/CPE, 2xRPSMA connectors, high TX power, Gigabit Ethernet, waterproof metal enclosure
Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE with an additional miniPCI-e slot, Gigabit Ethernet, waterproof metal enclosure
A dual-band 2.4/5 GHz base station with a powerful built-in sector antenna, PoE support, Gigabit Ethernet and SFP. One powerful package for all your outdoor network needs, perfect for camps, stadiums and parks!
Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE, 3xRPSMA connectors, high power, Gigabit Ethernet, waterproof metal enclosure
Extremely powerful dual-band backbone / CPE for long-distance connection without downtime
5GHz 120 degree 19dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
Tiny size 2.4GHz Dual Chain access point with a 650MHz CPU, 64MB RAM and one Ethernet
Small weatherproof wireless access point for mounting on a ceiling, wall or pole. In black
In-wall Dual Concurrent 2.4GHz / 5GHz wireless access point with three Ethernet ports and telephone jack pass through for hospitality networks
Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support, universal tower case
2.4GHz AP with five Ethernet ports and PoE output on port 5. It has a 600MHz CPU, 128MB RAM and a USB port.
Dual-band 2.4 / 5GHz wireless access point for mounting on a ceiling or wall with two Gigabit Ethernet ports (one with PoE output), 802.11ac support and IPsec hardware encryption support
Dual-Concurrent 2.4/5GHz AP, 802.11a/b/g/n/ac, Five Gigabit Ethernet ports, USB for 3G/4G support, universal tower case and IPsec hardware encryption support
wAP ac – a small dual-band weatherproof wireless access point for mounting on a pole, wall, or the ceiling. The new revision features 2x Gigabit Ethernet ports, enhanced wireless antenna performance, more RAM, and a powerful quad-core CPU!
A wireless dual-band router with 5 Gigabit Ethernet ports and external high gain antennas for more coverage
2.4GHz AP, 5x Ethernet, 5x Gigabit Ethernet, SFP cage, USB, LCD, PoE output on Eth10, 600MHz CPU, 128MB RAM
Dual concurrent triple chain 2.4/5GHz AP, 802.11ac/a/n/b/g, Five Gigabit Ethernet ports, PoE-out on port 5, SFP, USB for 3G/4G support or storage
A wireless dual-band router with LTE support and 5 Gigabit Ethernet ports. The right choice for most homes!
One router to delight them all – introducing the ultimate home AP with LTE support
Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage, dual band 2.4GHz / 5GHz 4x4 MIMO 802.11a/b/g/n/ac wireless and desktop case
Tri-band (one 2.4 GHz & two 5 GHz) home access point with LTE CAT6 support and meshing technology
10.5dBi 60 degree LTE antenna with 2x Ethernet ports (one with PoE out), WITHOUT LTE modem
Small weatherproof wireless access point with LTE antennas, two SIM slots, integrated GPS and miniPCI-e slot
Small weatherproof wireless access point with International LTE modem, two SIM slots and GPS
Small weatherproof wireless access point with United States LTE modem, two SIM slots and GPS
SXT 2G/3G/4G/LTE CPE, 9dBi 60 degree antenna, 2x Ethernet ports (one with PoE out), two SIM, 650MHz CPU, 64MB RAM, enclosure, PoE and PSU (RouterOS L3), International bands
SXT 3G/4G/LTE CPE, 10.5dBi 60 degree antenna, 2x Ethernet ports (one with PoE out), two SIM, 650MHz CPU, 64MB RAM, enclosure, PoE and PSU (RouterOS L3), US bands
Small weatherproof wireless access point with LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43
Small weatherproof Dual Band 2.4 / 5 GHz wireless access point with LTE antennas and miniPCI-e slot
A heavy-duty 2.4GHz access point with two miniPCI-e slots, three SIM slots and GNSS support (GPS, GLONASS, BeiDou, Galileo)
This outdoor wireless system with a built-in antenna can provide a connection even in the most remote locations. Tiny, powerful, can be used with any satellite TV dish with an offset mount.
LHG 4G/LTE High gain 21dBi CPE for very remote areas, LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43
Small weatherproof Dual Band 2.4 / 5 GHz wireless access point with LTE antennas and modem for International LTE bands 1,2,3,7,8,20,38 and 40.
Small weatherproof Dual Band 2.4 / 5 GHz wireless access point with LTE antennas and modem for International bands 3, 7, 20, 31, 41n, 42 and 43
A heavy-duty 2.4GHz access point with extra miniPCI-e slot, three SIM slots, GNSS support (GPS, GLONASS, BeiDou, Galileo) and LTE modem for International bands 1,2,3,7,8,20,38 and 40
Powerful and versatile dual-band wireless access point with CAT6 LTE support
LHGG LTE6 KIT – a great solution for great distances. With Gigabit Ethernet, an upgraded dual-core CPU, a powerful 17 dBi antenna, and a massive heat sink, you can trust the LHGG LTE6 kit to handle any challenge!
LtAP LR8 LTE - a compact all-in-one solution with LTE, GPS and wireless support for LoRa® in a rugged heavy-duty case
2G/3G/4G/LTE miniPCI-e card with carrier aggregation support (up to 300 Mbps) for bands 1/2/3/5/7/8/12/17/20/25/26/38/39/40/41n
Power adapter with PWR-LINE functionality for microUSB powered MikroTik router (Type A power plug)
802.11b/g/n WiFi AP with a single Ethernet port and capability to connect to other PWR-LINE devices through the electrical lines in your premises (Type C plug, European)
802.11b/g/n WiFi AP with a single Ethernet port and capability to connect to other PWR-LINE devices through the electrical lines in your premises (Type A plug, US plug)
Power adapter with PWR-LINE functionality for microUSB powered MikroTik router (Type C power plug)
Next level product for even faster power-line connection without long LAN cables
Indoor Bluetooth tags for the MikroTik KNOT or other IoT asset-tracking/telemetry setups.
An outdoor heavy-duty Bluetooth tag for the MikroTik KNOT or other IoT asset-tracking/telemetry setups. Built-in temperature sensors and accelerometer. Cast in industrial grade molds for maximum protection.
The upgrade of our antenna kit for LoRa® with a 6.5 dBi Omni antenna for 824-960 MHz, 1m long SMA cable and mechanical holder for quick and easy mast attachment. Smaller size, increased durability, and added IP66 water resistance.
Concentrator gateway card for LoRa® technology in mini PCIe form factor for 863-870 MHz
Concentrator gateway card for LoRa® technology in mini PCIe form factor for 902-928 MHz
60 GHz CPE with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L3
A high-speed 60 GHz CPE with Gigabit Ethernet and a 5 GHz failover. The easy and affordable way of eliminating interference and downtime!
60 GHz Base Station with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L4
For use as 60GHz CPE in Point -to-Multipoint setups for connections up to 800m with a 60GHz Base Stations, with Gigabit Ethernet port for speeds up to 1Gbps
60 GHz Base Station with Phase array 180° beamforming Integrated antenna, specially designed for Multipoint connections.
The most compact wireless 2 Gb/s aggregate link in the 1500 m range or more! Improved snow-resistant design is perfect for harsh weather environments. Cables can no longer limit you!
A 2 Gb/s 60 GHz aggregate link with a 5 GHz failover. Forget about wires or downtime!
600Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz Dual chain wireless, RouterOS L3
650Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz dual chain wireless with AC, RouterOS L3
600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 5Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 2.4Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, onboard 802.11ac Two Chain 5Ghz wireless, RouterOS L3
720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, 1xSFP cage, 1xminiPCI-e, 1xSIM, onboard 802.11ac Two Chain 5Ghz wireless, RouterOS L4
Black aluminium indoor, fits RB411, RB911, RB912 and RB922 series, set of front panels
A kit of two combined 1.25G SFP, 10G SFP+ and 25G SFP28 modules. 15 km, 1270nm + 1330nm.
Direct attach cable that supports not only SFP 1G and SFP+ 10G, but also the 25G SFP28 standard!
A passive MUX/DEMUX unit that allows the combining of up to eight fiber links into one. And you can split it up again later! Upgraded version – featuring a handy EXP/1310 expansion port!
A handy IoT combo antenna for both LTE and LoRa® frequencies. Perfect for the MikroTik KNOT LR series!
GESP+PoE is a passive PoE injector with surge protection. Combine it with the GESP devices for maximum security and peace of mind.
A 19” 10U desktop rack with adjustable angle and additional space for cable management.
Hot-swap power supply: replace the CCR2004 power supply without having to turn off or even restart the router. Zero downtime!
Outdoor 53V 250W AC/DC power supply units for the MikroTik netPower product line. Built for situations when your outdoor switches need that extra juice. Pole/wall mount compatible!
Outdoor 26V 250W AC/DC power supply units for the MikroTik netPower product line. Built for situations when your outdoor switches need that extra juice. Pole/wall mount compatible!
Wall mount kit for RB2011 desktop series, Protects cables, Powder coated steel
Low loss cable assembly, soldered on both ends, with silver plated copper and less than 0.65dB losses
A simple solution for mounting the RB4011 in public locations to avoid accidental unplugging of cables.
48 to 24V 10/100/1000Mbps PoE converter 802.3af support, 802.3at PoE plus support
Hot Swap -48V DC telecom power supply for CCR1072. Supported input Voltage -36 .. -57V.
Radome Cover Kit for mANT, reduces wind load, increases antenna operational life
Dual-polarization 5Ghz 15dBi 120 degree beamwidth antenna with two RP-SMA connectors
Sleeve30 kit for our mANT30 parabolic antenna to enhance point-to-point link performance
Dual-polarization 5Ghz 19dBi 120 degree beamwidth antenna with two RP-SMA connectors
Parabolic dish antenna for 5GHz, 30dBi gain. This model includes precision alignment mount
