Products
Products
    Ethernet routers
    hEX lite
    5x Ethernet, Small plastic case, 850MHz CPU, 64MB RAM, Most affordable MPLS router, RouterOS L4
    $39.95
    hEX
    5x Gigabit Ethernet, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4
    $59.95
    hEX PoE lite
    5xEthernet with PoE output for four ports, USB, 650MHz CPU, 64MB RAM, RouterOS L4
    $59.95
    PowerBox
    650MHz CPU, 64MB RAM, 5xEthernet with PoE output for four ports, RouterOS L4, outdoor case, PSU
    $69.00
    hEX PoE
    5x Gigabit Ethernet with PoE output for four ports, USB, 800MHz CPU, 128MB RAM, RouterOS L4
    $79.00
    RB2011iL-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    $99.00
    RB2011iL-RM
    1U rackmount, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    $99.00
    PowerBox Pro
    Five Gigabit Ethernet Router with 4xPoE-out ports, SFP cage and outdoor enclosure
    $99.00
    RB2011iLS-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, SFP cage, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    $109.00
    RB2011UiAS-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, USB, LCD, PoE out on port 10, 600MHz CPU, 128MB RAM, RouterOS L5
    $119.00
    RB2011UiAS-RM
    1U rackmount, 5xEthernet, 5xGigabit Ethernet, USB, LCD, PoE out on port 10, 600MHz CPU, 128MB RAM, RouterOS L5
    $119.00
    RB3011UiAS-RM
    1U rackmount, 10xGigabit Ethernet, USB 3.0, LCD, PoE out on port 10, 2x1.4GHz CPU, 1GB RAM, RouterOS L5
    $179.00
    RB1100AHx4 NEW
    Powerful 1U rackmount router with 13x Gigabit Ethernet ports
    $299.00
    RB1100AHx2
    1U rackmount, 13x Gigabit Ethernet, 1066MHz Dual Core CPU, 2GB RAM, RouterOS L6
    $349.00
    RB1100AHx4 Dude Edition
    Powerful 1U rackmount router with 13x Gigabit Ethernet ports, 60GB M.2 drive for Dude database
    $349.00
    CCR1009-7G-1C-PC
    7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 9 cores x 1GHz CPU, 1GB RAM, passive cooling case, RouterOS L6
    $425.00
    CCR1009-7G-1C-1S+PC
    7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1GHz CPU, 2GB RAM, LCD panel, passive cooling desktop enclosure, SmartCard slot, RouterOS L6, PSU
    $495.00
    CCR1009-7G-1C-1S+
    1U rackmount, 7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, SmartCard slot, RouterOS L6
    $495.00
    CCR1016-12G
    1U rackmount, 12x Gigabit Ethernet, LCD 16 cores x 1.2GHz CPU, 2GB RAM, 17.8mpps fastpath, Up to 12Gbit/s throughput, RouterOS L6
    $645.00
    CCR1016-12S-1S+
    1U rackmount, 12xSFP cage, 1xSFP+ cage, 16 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, RouterOS L6
    $745.00
    CCR1036-12G-4S
    1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD 36 cores x 1.2GHz CPU, 4GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6
    $995.00
    CCR1036-8G-2S+
    1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD 36 cores x 1.2GHz CPU, 4GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6
    $1095.00
    CCR1036-12G-4S-EM
    1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD 36 cores x 1.2GHz CPU, 16GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6
    $1195.00
    CCR1036-8G-2S+EM
    1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD 36 cores x 1.2GHz CPU, 16GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6
    $1295.00
    CCR1072-1G-8S+
    1U rackmount, 1x Gigabit Ethernet, 8xSFP+ cages, LCD 72 cores x 1GHz CPU, 16GB RAM, up to 120 million packets per second, 80Gbps throughput, RouterOS L6
    $3050.00
    Switches
    RB260GS
    5x Gigabit Ethernet Smart Switch, SFP cage, plastic case, SwOS
    $39.95
    RB260GSP
    5x Gigabit PoE out Ethernet Smart Switch, SFP cage, plastic case, SwOS
    $55.95
    CRS106-1C-5S
    Smart Switch, 5x SFP cages, 1x Combo port (SFP or Gigabit Ethernet), 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    $59.00
    FiberBox NEW
    Outdoor router with five SFP ports
    $79.00
    CRS112-8G-4S-IN
    8x Gigabit Ethernet Smart Switch, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    $139.00
    CSS326-24G-2S+RM
    SwOS powered 24 port Gigabit Ethernet switch with two SFP+ ports in 1U rackmount case
    $139.00
    CRS109-8G-1S-2HnD-IN
    8x Gigabit Smart Switch, 1x SFP cage, LCD, 1000mW 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5, supports 10-57V, 802.3af/at compliant
    $149.00
    CRS125-24G-1S-IN
    24x Gigabit Ethernet layer 3 Smart Switch, 1x SFP cage, LCD, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5
    $189.00
    CRS326-24G-2S+RM
    24 Gigabit port switch with 2 x SFP+ cages in 1U rackmount case, Dual boot (RouterOS or SwitchOS)
    $199.00
    CRS125-24G-1S-2HnD-IN
    24x Gigabit Ethernet layer 3 Smart Switch, 1x SFP cage, LCD, 1000mW 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5
    $209.00
    CRS212-1G-10S-1S+IN
    Smart Switch, 1x Gigabit LAN, 10x SFP cages, 1x SFP+ cage, LCD, 400MHz CPU, 64MB RAM, Metal desktop case, RouterOS L5
    $219.00
    CRS210-8G-2S+IN
    8x Gigabit Smart Switch, 2x SFP+ cages, LCD, 400MHz CPU, 64MB RAM, Metal desktop case, RouterOS L5, supports 10-57V, 802.3af/at
    $229.00
    CRS317-1G-16S+RM NEW
    Smart Switch, 1 x Gigabit LAN, 16 x SFP+ cages, Dual Core 800MHz CPU, 1GB RAM, 1U rackmount passive cooling case, Dual Power Supplies
    $399.00
    Wireless systems
    LDF 5
    Dual chain 5GHz system for long distance links with satellite offset dish antennas
    $39.00
    SXTsq Lite5 NEW
    Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone
    $46.00
    DISC Lite5
    Dual chain 21dBi 5GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    $48.00
    SXT Lite2
    10dbi integrated CPE/Backbone, 2GHz dual chain, 600MHz CPU
    $49.00
    SXT Lite5
    16dBi integrated CPE/Backbone, 5GHz dual chain, 600MHz CPU
    $59.00
    Groove 52
    2.4GHz/5GHz Backbone/CPE, 500mW TX, N-male connector
    $59.00
    LHG 5
    Dual chain 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    $59.00
    SXT Lite5 ac
    16dBi integrated CPE/Backbone, 5Ghz dual chain with 802.11ac support, 650MHz CPU
    $65.00
    LHG HP5 NEW
    Dual chain High Power 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna
    $69.00
    SXT 2
    10dbi 60 degree integrated AP/Backbone/CPE, 1600mW dual chain, Gigabit Ethernet
    $79.00
    GrooveA 52
    2.4GHz/5GHz AP/Backbone/CPE, 500mW TX, N-male connector, includes 2.4GHz/5GHz 6dBi Omni Antenna
    $79.00
    Groove 52 ac
    2.4GHz/5GHz Backbone/CPE with 802.11ac and Gigabit Ethernet, N-male connector
    $79.00
    LHG XL HP5 NEW
    Dual chain eXtra Large High Power 27dBi 5GHz CPE/Point-to-Point Integrated Antenna
    $79.00
    OmniTIK 5
    7.5dBi Integrated AP, 5GHz Dual chain, 5xEthernet ports
    $89.00
    SXT 5
    16dBi integrated CPE/Backbone, high power 1250mW TX power
    $89.00
    BaseBox 5
    5Ghz integrated AP/Backbone/CPE, 2xRPSMA connectors, 1000mW TX power, miniPCI-e slot, Gigabit Ethernet
    $89.00
    BaseBox 2
    2.4Ghz integrated AP/Backbone/CPE, 2xRPSMA connectors, 1000mW TX power, miniPCI-e slot, Gigabit Ethernet
    $89.00
    SXT HG5
    17dbi integrated AP/Backbone/CPE, Gigabit Ethernet
    $95.00
    OmniTIK 5 PoE
    7.5dBi Integrated AP, 5GHz Dual chain, 5xEthernet ports with PoE output
    $99.00
    Metal 5
    5Ghz Integrated AP/Backbone/CPE, 1300 mW TX power, N-male connector
    $99.00
    Metal 2
    2.4Ghz Integrated AP/Backbone/CPE, 1600 mW TX power, N-male connector, 6dBi Omni antenna
    $99.00
    SXT SA5
    14dBi integrated Sector AP, 90 degrees beamwidth, 1000mW TX power, Gigabit Ethernet
    $99.00
    GrooveA 52 ac
    2.4GHz/5GHz AP/Backbone/CPE with 802.11ac and Gigabit Ethernet, N-male connector + Omni antenna
    $99.00
    SXT 6
    Dual chain 16dBi 28 degree 5.9-6.4GHz Integrated antenna for licensed band
    $99.00
    SXT 5 ac
    802.11ac up to 540Mbit, 1300mW RF output, low latency Point to Point
    $109.00
    NetBox 5
    802.11ac support for up to 540Mbits, waterproof enclosure, 1300mW output
    $109.00
    OmniTIK 5 ac
    7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports
    $109.00
    SEXTANT G
    18dBi integrated CPE/Backbone, Gigabit Ethernet
    $110.00
    SXT SA5 ac
    802.11ac up to 540Mbit, 1300mW RF output, wide beamwidth sector antenna
    $119.00
    SXT HG5 ac
    Dual chain 5GHz 802.11a/n/ac QCA9882, 128 MB RAM, 720 MHz CPU, 17 DBI antenna gain
    $119.00
    Metal 52 ac
    2.4/5GHz software selectable AP/Backbone/CPE with AC support, 1300mW TX power, N-male connector, Omni antenna included
    $119.00
    Metal 9
    900MHz Integrated AP/Backbone/CPE, 500mW TX power, N-male connector
    $129.00
    SXT LTE
    SXT CPE with 3 (1800MHz) and 7 (2600MHz) LTE FDD band support, 9dBi 60 degree antenna, 400Mhz CPU, 64MB RAM, enclosure, PoE and PSU (RouterOS L3)
    $129.00
    OmniTIK 5 PoE ac
    7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports with PoE-out
    $129.00
    mANTBox 15s
    5GHz 120 degree 15dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
    $139.00
    QRT 2
    2.4Ghz AP/Backbone/CPE, 3166mW dual-chain, Gigabit Ethernet
    $149.00
    NetMetal 5
    Dual chain 5GHz integrated 802.11a/n/ac AP/Backbone/CPE with an additional miniPCI-e slot, 2xRPSMA connectors, Gigabit Ethernet, waterproof metal enclosure
    $149.00
    NetMetal 5
    Dual chain 5GHz integrated 802.11ac AP/Backbone/CPE, 2xRPSMA connectors, 1.3W TX power, Gigabit Ethernet, waterproof metal enclosure
    $159.00
    NetMetal 5
    Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE with an additional miniPCI-e slot, Gigabit Ethernet, waterproof metal enclosure
    $159.00
    QRT 5
    5GHz AP/Backbone/CPE, 1000mW dual-chain, Gigabit Ethernet
    $169.00
    NetMetal 5
    Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE, 3xRPSMA connectors, 2000mW TX power, Gigabit Ethernet, waterproof metal enclosure
    $169.00
    DynaDish 5
    Dual chain 5GHz 802.11a/n/ac QCA9882, 128MB RAM, 720 MHz CPU, 25dBi antenna gain
    $179.00
    DynaDish 6 NEW
    Dual chain 25dBi Long Range 5.9-6.4GHz Integrated antenna for licensed band
    $179.00
    Wireless Wire NEW
    1 Gbps full duplex without cables!
    $198.00
    QRT 5 ac
    Dual chain 5GHz 802.11a/n/ac QCA9882, 128 MB RAM, 720 MHz CPU, 24 DBi antenna gain
    $199.00
    mANTBox 19s
    5GHz 120 degree 19dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
    $199.00
    SXT Sixpack
    5Ghz Starter Kit, 5xSXT High Power CPE, 1x90 degree Sector AP (included FREE)
    $445.00
    Wireless for home and office
    hAP mini
    Tiny size home 2.4Ghz AP with three LAN ports
    $19.95
    hAP lite classic
    Low cost home wireless AP with dual chain 2.4GHz wireless, powered by USB
    $21.95
    hAP lite
    Small home AP with four ethernet ports and a colorful enclosure.
    $21.95
    mAP lite
    Tiny size 2.4GHz Dual Chain access point with a 650MHz CPU, 64MB RAM and one Ethernet
    $25.00
    cAP lite
    Low-cost dual-chain 2.4GHz AP with wall and ceiling enclosure
    $29.00
    mAP
    Dual-Chain 2.4GHz micro AP, 650MHz CPU, 64MB RAM, 2xEthernet, PoE out
    $45.00
    hAP
    2.4GHz AP, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
    $45.00
    wAP
    Small weatherproof wireless access point for mounting on a ceiling, wall or pole
    $45.00
    wAP (black edition)
    Small weatherproof wireless access point for mounting on a ceiling, wall or pole. In black
    $45.00
    cAP
    Ceiling AP, Dual-Chain 2.4GHz, 650MHz CPU, RouterOS L4, 802.3at/af support
    $49.95
    hAP ac lite
    Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
    $49.95
    hAP ac lite tower
    Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support, universal tower case
    $49.95
    RB951Ui-2HnD
    2.4GHz 1000mW AP with five Ethernet ports and PoE output on port 5. It has a 600MHz CPU, 128MB RAM and a USB port.
    $59.95
    wAP R NEW
    Small weatherproof wireless access point with LTE antennas and miniPCI-e slot
    $79.00
    RB951G-2HnD
    2.4Ghz 1000mW AP, 5xGigabit Ethernet, USB, 600MHz CPU, 128MB RAM
    $79.95
    wAP ac
    Small dual-band 2.4 / 5GHz white weatherproof wireless access point for mounting on a ceiling, wall or pole
    $89.00
    wAP ac (black edition)
    Small dual-band 2.4 / 5GHz black weatherproof wireless access point for mounting on a ceiling, wall or pole
    $89.00
    wAP LTE kit NEW
    Small weatherproof wireless access point with International LTE modem
    $119.00
    wAP LTE kit-US NEW
    Small weatherproof wireless access point with United States LTE modem
    $119.00
    RB2011UiAS-2HnD-IN
    2.4GHz 1000mW AP, 5x Ethernet, 5x Gigabit Ethernet, SFP cage, USB, LCD, PoE output on Eth10, 600MHz CPU, 128MB RAM
    $129.00
    hAP ac
    Dual concurrent triple chain 2.4/5GHz AP, 802.11ac/a/n/b/g, Five Gigabit Ethernet ports, PoE-out on port 5, SFP, USB for 3G/4G support or storage
    $129.00
    RouterBOARD
    911 Lite5
    600Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz single chain wireless, RouterOS L3
    $39.00
    911 Lite2
    600Mhz CPU, 64MB RAM, 1xEthernet, onboard 2Ghz single chain wireless, RouterOS L3
    $39.00
    M11G NEW
    Small size powerful OEM board with one Gigabit LAN and one miniPCIe slot
    $39.00
    911 Lite5 dual
    600Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz Dual chain wireless, RouterOS L3
    $45.00
    RB911G-2HPnD
    600Mhz CPU, 32MB RAM, 1xGigabit Ethernet, onboard 1000mW 2.4Ghz wireless, RouterOS L3
    $49.00
    911 Lite5 ac
    650Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz dual chain wireless with AC, RouterOS L3
    $49.00
    RB911G-5HPnD
    600MHz CPU, 32MB RAM, 1xGigabit Ethernet, onboard 1000mW 5GHz wireless, RouterOS L3
    $55.00
    RB450
    300MHz CPU, 64MB RAM, 5xEthernet, RouterOS L5
    $69.00
    RB411U
    300MHz CPU, 32MB RAM, 1xEthernet, miniPCI, USB, RouterOS L4
    $79.00
    RB411GL
    680MHz CPU, 64MB RAM, 1xGigabit Ethernet, miniPCI, USB, RouterOS L4
    $79.00
    RB912UAG-5HPnD
    600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 1000mW 5Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
    $79.00
    RB912UAG-2HPnD
    600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 1000mW 2.4Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
    $79.00
    RB911G-5HPacD
    720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, onboard 1300mW 802.11ac Two Chain 5Ghz wireless, RouterOS L3
    $79.00
    RB411AR
    300MHz CPU, 64MB RAM, 1xEthernet, miniPCI, integrated 2.4Ghz wireless, RouterOS L4
    $89.00
    RB433UL
    400MHz CPU, 64MB RAM, 3xEthernet, 3x miniPCI, USB, RouterOS L4
    $89.00
    RB411AH
    680MHz CPU, 64MB RAM, 1xEthernet, miniPCI, RouterOS L4
    $99.00
    RB450G
    680MHz CPU, 256MB RAM, 5xGigabit Ethernet RouterOS L5
    $99.00
    RB922UAGS-5HPacD
    720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, 1xSFP cage, 1xminiPCI-e, 1xSIM, onboard 1000mW 802.11ac Two Chain 5Ghz wireless, RouterOS L4
    $99.00
    RB850Gx2
    Dual Core P1023 533MHz CPU, 512MB RAM, 5xGigabit Ethernet, RouterOS L5
    $129.00
    RB433AH
    680MHz CPU, 128MB RAM, 3x Ethernet, 3x miniPCI, RouterOS L5
    $149.00
    RB953GS-5HnT-RP
    720MHz CPU, 128MB RAM, 3x Gigabit Ethernet, 2xSFP cage, built-in 5GHz 3x3 MIMO wirelss, 2x miniPCI-e, 2x SIM, USB, 3xRPSMA connectors, RouterOS L5
    $169.00
    RB435G
    680MHz CPU, 256MB RAM, 3x Gigabit Ethernet, 5x miniPCI, 2xUSB, RouterOS L5
    $189.00
    RB493G
    680MHz CPU, 256MB RAM, 9x Gigabit Ethernet, 3x miniPCI, USB, RouterOS L5
    $199.00
    RB800
    800MHz CPU, 256MB RAM, 3x Gigabit Ethernet, 4x miniPCI, USB, miniPCI-express, daughterboard connector RouterOS L6
    $359.00
    Enclosures
    CA411-711
    Black aluminium indoor, fits RB411, RB911, RB912 and RB922 series, set of front panels
    $15.00
    CA150
    Black aluminium indoor case that fits the RB450 and RB850 series devices
    $19.00
    CA433U
    Black aluminium indoor, Fits RB433 series
    $20.00
    CA493
    Black aluminium indoor, Fits RB493 series
    $20.00
    CA800
    Black aluminium indoor, Fits RB800
    $20.00
    CAOTS
    Plastic outdoor, Ethernet insulator, fits RB411, RB911, RB912 and RB922 series, Mounting set included
    $45.00
    CAOTU
    Plastic outdoor, Ethernet insulator, fits RB411, RB433, RB493, RB800 series, Mounting set included
    $89.00
    Interfaces
    S-85DLC05D
    SFP (1.25G) module, 550m, Multi Mode
    $22.00
    S-31DLC20D
    SFP (1.25G) module, 20KM, Single Mode
    $29.00
    SFP+ 1m direct attach cable
    SFP+ direct attach cable, 1m
    $29.00
    S-RJ01
    RJ45 SFP 10/100/1000M copper module
    $29.00
    R11e-5HnD
    5Ghz miniPCI-express, 802.11a/n dual chain, 500mW, 2x MMCX
    $39.00
    R11e-2HPnD
    2Ghz miniPCI-express, 802.11b/g/n dual chain, 1000mW, 2x MMCX
    $39.00
    R11e-2HnD
    2Ghz miniPCI-express, 802.11b/g/n dual chain, 800mW, 2x u.Fl
    $39.00
    SFP+ 3m direct attach cable
    SFP+ direct attach cable, 3m
    $39.00
    R52nM
    2.4/5Ghz miniPCI 802.11a/b/g/n dual chain, 2x MMCX
    $49.00
    R2SHPn
    2Ghz miniPCI 802.11b/g/n single chain, 1600mW, MMCX connector
    $49.00
    RB14e
    4x miniPCI-e to PCI-e adapter, Long and short bracket
    $49.00
    R11e-5HacD
    5Ghz miniPCI-express, 802.11ac/a/n dual chain, 500mW, 2x MMCX
    $49.00
    R52H
    2.4/5Ghz miniPCI 802.11a/b/g single chain, 350mW, 2x u.Fl
    $59.00
    R5SHPn
    5Ghz miniPCI 802.11a/n single chain, 800mW, MMCX connector
    $59.00
    S+85DLC03D
    SFP+ (10Gbit), 300m, Multi Mode
    $59.00
    RB14eU
    4x miniPCI-e to PCI-e adapter, Long and short bracket, 6x USB, 4x SIM slots
    $59.00
    R11e-5HacT
    5Ghz miniPCI-e, 802.11ac/a/n tripple chain, 3x MMCX
    $59.00
    R52HnD
    2.4/5Ghz miniPCI 802.11a/b/g/n dual chain, 2x MMCX, up to 400mW
    $59.00
    S+RJ10 NEW
    6-speed RJ-45 module for up to 10 Gbps
    $65.00
    S-3553LC20D
    Two SFP (1.25G) module kit, 20Km, single mode
    $79.00
    GPON ONU module
    Pluggable GPON ONU interface for Fiber to Home
    $89.00
    S+31DLC10D
    SFP+ (10Gbit) module, Long range 10km, Single Mode
    $149.00
    S+2332LC10D
    pair of SFP+ (10Gbit) modules, 10km, for single optical cable
    $349.00
    Accessories
    5VUSB
    USB power injector for RB411UAHR or RB493G
    $3.00
    RBPOE
    PoE injector, for 10/100Mbps products
    $5.00
    quickMOUNT
    Basic wall mount adapter for small point to point and sector antennas
    $5.50
    RBGPOE
    PoE injector, for Gigabit LAN products
    $8.00
    MMCX-RPSMA pigtail
    MMCX to RPSMA pigtail
    $8.00
    2.4Ghz Dipole
    2.4Ghz 5dBi Dipole antenna with RPSMA connector
    $8.00
    RB2011 mount
    Wall mount kit for RB2011 desktop series, Protects cables, Powder coated steel
    $8.95
    ACUFL
    uFl to Nfemale pigtail, fits R52H, R11e-2HnD
    $9.00
    ACMMCX
    MMCX to NFemale pigtail
    $9.00
    18POW
    24V 0.8A Power adapter
    $9.00
    Flex-guide
    Low loss cable assembly, soldered on both ends, with silver plated copper and less than 0.65dB losses
    $9.00
    quickMOUNT pro
    Advanced wall mount adapter for small point to point and sector antennas
    $9.50
    quickMOUNT extra
    Advanced wall mount adapter for large point to point and sector antennas
    $9.50
    quickMOUNT pro LHG
    Advanced wall mount adapter for LHG
    $9.50
    ACSWI
    2.4/5Ghz Omni antenna, 4dBi gain, u.fl connector
    $15.00
    ACSWIM
    2.4/5Ghz Omni antenna, 4dBi gain, MMCX connector
    $15.00
    Woobm NEW
    The Wireless out of band management USB stick
    $16.00
    24HPOW
    24V 1.6A adapter, for long cables, for installations with many miniPCI
    $18.00
    48POW
    48V 1.46A power adapter
    $18.00
    48 to 24V Gigabit PoE Converter
    48 to 24V 10/100/1000Mbps PoE converter 802.3af support, 802.3at PoE plus support
    $24.95
    mUPS NEW
    PoE injector with battery backup capability
    $29.00
    FTC
    Fiber to Copper converter, Outdoor case, 12-57V PoE with 802.3af/at support
    $39.00
    12POW150
    Hot Swap power supply for CCR1072
    $100.00
    PW48V-12V150W NEW
    Hot Swap -48V DC telecom power supply for CCR1072
    $100.00
    Antennas
    Radome Cover Kit
    Radome Cover Kit for mANT, reduces wind load, increases antenna operational life
    $39.00
    mANT 15s
    Dual-polarization 5Ghz 15dBi 120 degree beamwidth antenna with two RP-SMA connectors
    $49.00
    Sleeve30 Kit
    Sleeve30 kit for our mANT30 parabolic antenna to enhance point-to-point link performance
    $89.00
    mANT 19s
    Dual-polarization 5Ghz 19dBi 120 degree beamwidth antenna with two RP-SMA connectors
    $99.00
    mANT30
    Parabolic dish antenna for 5GHz, 30dBi gain
    $119.00
    mANT30 PA
    Parabolic dish antenna for 5GHz, 30dBi gain. This model includes precision alignment mount
    $129.00
