RadioLAN 5.8GHz Wireless Interface
Document revision 29-Nov-2001
This document applies to the MikroTik RouterOS V2.6
Overview
The MikroTik RouterOS supports the following RadioLAN 5.8GHz Wireless Adapter hardware:
For more information about the RadioLAN adapter hardware please see the relevant User’s Guides and Technical Reference Manuals.
Contents of the Manual
The following topics are covered in this manual:
Wireless Adapter Hardware and Software Installation
Software Packages
The MikroTik Router should have the radiolan software package installed. The software package file radiolan-2.6.x.npk can be downloaded from MikroTik’s web page www.mikrotik.com. To install the package, please upload the correct version file to the router and reboot. Use BINARY mode ftp transfer. After successful installation the package should be listed under the installed software packages list, for example:
[admin@MikroTik] interface> /system package print
Flags: I - invalid
  #   NAME                  VERSION              BUILD-TIME           UNINSTALL
  0   ssh                   2.6beta2             jul/05/2002 13:43:42 no
  1   radiolan              2.6beta2             jul/05/2002 13:47:46 no
  2   system                2.6beta2             jul/05/2002 13:42:26 no
  3   vlan                  2.6beta2             jul/05/2002 14:13:43 no
  4   pptp                  2.6beta2             jul/05/2002 13:46:11 no
  5   ppp                   2.6beta2             jul/05/2002 13:45:40 no
  6   pppoe                 2.6beta2             jul/05/2002 13:46:40 no
Software License
The RadioLAN 5.8GHz wireless adapters require the RadioLAN 5.8GHz wireless feature license. One license is for one installation of the MikroTik RouterOS, disregarding how many cards are installed in one PC box. The wireless feature is not included in the Free Demo or Basic Software License. The RadioLAN 5.8GHz Wireless Feature cannot be obtained for the Free Demo License. It can be obtained only together with the Basic Software License.
System Resource Usage
Before installing the wireless adapter, please check the availability of free IRQ's and I/O base addresses:
[admin@MikroTik] interface> /system resource irq print
Flags: U - unused
   IRQ OWNER
   1   keyboard
   2   APIC
 U 3
   4   serial port
 U 5
 U 6
 U 7
 U 8
   9   ether1
 U 10
 U 11
 U 12
 U 13
   14  IDE 1
[admin@MikroTik] interface> /system resource io print
 PORT-RANGE        OWNER
 20-3F             APIC
 40-5F             timer
 60-6F             keyboard
 80-8F             DMA
 A0-BF             APIC
 C0-DF             DMA
 F0-FF             FPU
 1F0-1F7           IDE 1
 2F8-2FF           serial port
 3C0-3DF           VGA
 3F6-3F6           IDE 1
 3F8-3FF           serial port
 CF8-CFF           [PCI conf1]
 EF00-EFFF         [Realtek Semiconductor Co., Ltd. RTL-8139]
 EF00-EFFF         [8139too]
 FC00-FC7F         [Cyrix Corporation 5530 IDE [Kahlua]]
 FC00-FC07         IDE 1
 FC08-FC0F         IDE 2
Installing the Wireless Adapter
These installation instructions apply to non-Plug-and-Play ISA cards. If You have a Plug-and-Play compliant system AND PnP OS Installed option in system BIOS is set to Yes AND you have a Plug-and-Play compliant ISA or PCI card (using PCMCIA or CardBus card with Plug-and-Play compliant adapter), the driver should be loaded automatically. If it is not, these instructions may also apply to your system
The basic installation steps of the wireless adapter should be as follows:
  1. Check the system BIOS settings for peripheral devices, like, Parallel or Serial communication ports. Disable them, if you plan to use IRQ's assigned to them by the BIOS.
  2. Use the RLProg.exe to set the IRQ and Base Port address of the RadioLAN ISA card (Model 101). RLProg must not be run from a DOS window. Use a separate computer or a bootable floppy to run the RLProg utility and set the hardware parameters. The factory default values of I/O 0x300 and IRQ 10 might conflict with other devices.
Please note, that not all combinations of I/O base addresses and IRQ's may work on your motherboard. As it has been observed, the IRQ 5 and I/O 0x300 work in most cases.
For more information on installing PCMCIA cards, check Notes on PCMCIA Adapters first.
Loading the Driver for the Wireless Adapter
The ISA card requires the driver to be loaded by issuing the following command:
[admin@MikroTik] > driver add name=radiolan io=0x300
[admin@MikroTik] > driver print
Flags: I - invalid, D - dynamic
  #   DRIVER                            IRQ IO         MEMORY     ISDN-PROTOCOL
  0 D RealTek RTL8129/8139
  1   ISA RadioLAN                          0x300
[admin@MikroTik] >
There can be several reasons for a failure to load the driver:
Wireless Interface Configuration
If the driver has been loaded successfully (no error messages), and you have the required RadioLAN 5.8GHz Wireless Software License, then the RadioLAN 5.8GHz Wireless interface should appear under the interfaces list with the name radiolanX, where X is 1,2,... You can change the interface name to a more descriptive one using the set command. To enable the interface, use the enable command:
[admin@MikroTik] interface> print
Flags: X - disabled, D - dynamic, R - running
  #    NAME                 TYPE             MTU
  0  R ether1               ether            1500
  1 X  radiolan1            radiolan         1500
  2 X  vlan1                vlan             1500
[admin@MikroTik] interface> enable radiolan1
  #    NAME                 TYPE             MTU
  1  R radiolan1            radiolan         1500
  2 X  vlan1                vlan             1500
More configuration and statistics parameters can be found under the /interface radiolan menu:
[admin@MikroTik] interface radiolan> print
  0  R name="radiolan1" mtu=1500 mac-address=00:A0:D4:20:4B:E7 arp=enabled
       card-name="00A0D4204BE7" sid="bbbb" default-destination=first-client
       default-address=00:00:00:00:00:00 distance=0-150m max-retries=15
       tx-diversity=disabled rx-diversity=disabled
Argument description:
number - Interface number in the list
name - Interface name
mtu - Maximum Transmit Unit (68...1900 bytes). Default value is 1500 bytes.
mac-address - MAC address. Cannot be changed.
distance - distance setting for the link (0-10.2km)
rx-diversity - Receive diversity (disabled / enabled)
tx-diversity - Transmit diversity (disabled / enabled)
default-destination - default destination (ap, as-specified, first-ap, first-client, no-destination). It sets the destination where to send the packet if it is not for a client in the radio network.
default-address - MAC address of a host in the radio network where to send the packet, if it is for none of the radio clients.
max-retries - maximum retries before dropping the packet
sid - Service Set Identifier
card-name - Card name
arp - Address Resolution Protocol, one of the:
You can monitor the status of the wireless interface:
[admin@MikroTik] interface radiolan> monitor radiolan1
    default: 00:00:00:00:00:00
      valid: no
Here, the wireless interface card has not found any neighbour.
To set the wireless interface for working with another wireless card in a point-to-point link, you should set the following parameters:
All other parameters can be left as default:
[admin@MikroTik] interface radiolan> set 0 sid ba72 distance 4.7km-6.6km
       card-name="00A0D4204BE7" sid="ba72" default-destination=first-client
       default-address=00:00:00:00:00:00 distance=4.7km-6.6km max-retries=15
[admin@MikroTik] interface radiolan> monitor 0
    default: 00:A0:D4:20:3B:7F
      valid: yes
You can monitor the list of neighbours having the same sid and being within the radio range:
[admin@MikroTik] interface radiolan> neighbor radiolan1 print
Flags: A - access-point, R - registered, U - registered-to-us,
D - our-default-destination
      NAME                 ADDRESS           ACCESS-POINT
    D 00A0D4203B7F         00:A0:D4:20:3B:7F
You can test the link by pinging the neighbour by its MAC address:
[admin@MikroTik] interface radiolan> ping 00:a0:d4:20:3b:7f radiolan1 \
\... size=1500 count=50
                 sent: 1
    successfully-sent: 1
          max-retries: 0
      average-retries: 0
          min-retries: 0
                 sent: 11
    successfully-sent: 11
          max-retries: 0
      average-retries: 0
          min-retries: 0
                 sent: 21
    successfully-sent: 21
          max-retries: 0
      average-retries: 0
          min-retries: 0
                 sent: 31
    successfully-sent: 31
          max-retries: 0
      average-retries: 0
          min-retries: 0
                 sent: 41
    successfully-sent: 41
          max-retries: 0
      average-retries: 0
          min-retries: 0
                 sent: 50
    successfully-sent: 50
          max-retries: 0
      average-retries: 0
          min-retries: 0
Wireless Troubleshooting
Wireless Network Applications
Point-to-Point Setup with Routing
Let us consider the following network setup with two MikroTik Routers having RadioLAN interfaces: The minimum configuration required for the RadioLAN interfaces of both routers is:
  1. Setting the Service Set Identifier (up to alphanumeric characters). In our case we use ssid "ba72".
  2. Setting the distance parameter, in our case we have 6km link.
The IP addresses assigned to the wireless interface of Router#1 should be from the network 10.1.0.0/30, e.g.:
[admin@MikroTik] ip address> add address=10.1.0.1/30 interface=radiolan1
[admin@MikroTik] ip address> print
  #   ADDRESS            NETWORK         BROADCAST       INTERFACE
  0   10.1.1.12/24       10.1.1.0        10.1.1.255      ether1
  1   10.1.0.1/30        10.1.0.0        10.1.0.3        radiolan1
The default route should be set to the gateway router 10.1.1.254. A static route should be added for the network 192.168.0.0/24:
[admin@MikroTik] ip route> add gateway=10.1.1.254
comment  copy-from  disabled  distance  dst-address  netmask  preferred-source
[admin@MikroTik] ip route> add gateway=10.1.1.254 preferred-source=10.1.0.1
[admin@MikroTik] ip route> add dst-address=192.168.0.0/24 gateway=10.1.0.2 \
\... preferred-source=10.1.0.1
[admin@MikroTik] ip route> print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected,
C - connect, S - static, R - rip, O - ospf, B - bgp
    #    DST-ADDRESS        G GATEWAY         DISTANCE INTERFACE
    0  S 0.0.0.0/0          u 10.1.1.254      1        radiolan1
    1  S 192.168.0.0/24     r 10.1.0.2        1        radiolan1
    2 DC 10.1.0.0/30        r 0.0.0.0         0        radiolan1
    3 DC 10.1.1.0/24        r 0.0.0.0         0        ether1
The Router#2 should have addresses 10.1.0.2/30 and 192.168.0.254/24 assigned to the radiolan and Ethernet interfaces respectively. The default route should be set to 10.1.0.1
© Copyright 1999-2002, MikroTik
