[admin@MikroTik] > interface print Flags: X - disabled, D - dynamic, R - running # NAME TYPE MTU 0 R ether1 ether 1500 1 X farsync1 farsync 1500 2 X farsync2 farsync 1500 [admin@MikroTik] interface> [admin@MikroTik] interface> enable 1 [admin@MikroTik] interface> enable farsync2 [admin@MikroTik] > interface print Flags: X - disabled, D - dynamic, R - running # NAME TYPE MTU 0 R ether1 ether 1500 1 farsync1 farsync 1500 2 farsync2 farsync 1500 [admin@MikroTik] interface>
More configuration and statistics parameters can be found under the /interface farsync menu:
[admin@MikroTik] interface farsync> print
0 name="farsync1" mtu=1500 line-protocol=sync-ppp media-type=V35
clock-rate=64000 clock-source=external chdlc-keepalive=10s
frame-relay-lmi-type=ansi frame-relay-dce=no
1 name="farsync2" mtu=1500 line-protocol=sync-ppp media-type=V35
Argument description:
numbers - Interface number in the list
hdlc-keepalive - Cisco HDLC keepalive period in seconds (0..32767)
clock-rate - Speed of internal clock
clock-source - Clock source (external, internal)
disabled - disable or enable the interface
frame-relay-dce - Operate in DCE mode (yes, no)
frame-relay-lmi-type - Frame-Relay Local Management Interface type (ansi, ccitt)
line-protocol - Line protocol (cisco-hdlc, frame-relay, sync-ppp)
media-type - Type of the media (V24, V35, X21)
mtu - Maximum Transmit Unit (68...1500 bytes). Default value is 1500 bytes.
name - New interface name
You can monitor the status of the synchronous interface:
[admin@MikroTik] interface farsync> monitor 0
card-type: T2P FarSync T-Series
state: running
firmware-id: 2
firmware-version: 0.7.0
physical-media: V35
cable: detected
clock: not-detected
input-signals: CTS
output-signals: RTS DTR
One possible synchronous line configurations is discussed in the following example:
The interface should be enabled according to the instructions given above. The IP addresses assigned to the synchronous interface should be as follows:
[admin@MikroTik] ip address> add address 1.1.1.1/32 interface farsync1 \ \... network 1.1.1.2 broadcast 255.255.255.255 [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.0.0.254/24 10.0.0.254 10.0.0.255 ether2 1 192.168.0.254/24 192.168.0.254 192.168.0.255 ether1 2 1.1.1.1/32 1.1.1.2 255.255.255.255 farsync1 [admin@MikroTik] ip address> /ping 1.1.1.2 1.1.1.2 64 byte pong: ttl=255 time=31 ms 1.1.1.2 64 byte pong: ttl=255 time=26 ms 1.1.1.2 64 byte pong: ttl=255 time=26 ms 3 packets transmitted, 3 packets received, 0% packet loss round-trip min/avg/max = 26/27.6/31 ms [admin@MikroTik] ip address>
Note, that for the point-to-point link the network mask is set to 32 bits, the argument network is set to the IP address of the other end, and the broadcast address is set to 255.255.255.255. The default route should be set to the gateway router 1.1.1.2:
[admin@MikroTik] ip route> add gateway 1.1.1.2
[admin@MikroTik] ip route> print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected,
C - connect, S - static, R - rip, O - ospf, B - bgp
# DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r 1.1.1.2 1 farsync1
1 DC 10.0.0.0/24 r 10.0.0.254 1 ether2
2 DC 192.168.0.0/24 r 192.168.0.254 0 ether1
3 DC 1.1.1.2/32 r 0.0.0.0 0 farsync1
The configuration of the Mikrotik router at the other end is similar:
[admin@MikroTik] ip address> add address 1.1.1.2/32 interface fsync \ \... network 1.1.1.1 broadcast 255.255.255.255 [admin@MikroTik] ip address> print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.1.1.12/24 10.1.1.12 10.1.1.255 Public 1 1.1.1.2/32 1.1.1.1 255.255.255.255 fsync [admin@MikroTik] ip address> /ping 1.1.1.1 1.1.1.1 64 byte pong: ttl=255 time=31 ms 1.1.1.1 64 byte pong: ttl=255 time=26 ms 1.1.1.1 64 byte pong: ttl=255 time=26 ms 3 packets transmitted, 3 packets received, 0% packet loss round-trip min/avg/max = 26/27.6/31 ms [admin@MikroTik] ip address>
