Support Output File
Document revision:2.1.0 (Wed Mar 03 16:11:16 GMT 2004)
Applies to: V2.8
General Information
Summary
The support file is used for debugging MikroTik RouterOS and to solve the support questions faster. All MikroTik Router information is saved in a binary file, which is stored on the router and can be downloaded from the router using ftp.
Specifications
Packages required: system
License required: Level1
Submenu level: /system
Hardware usage: Not significant
Generating Support Output File
Command name: /system sup-output
Example
To make a Support Output File:
[admin@MikroTik] > system sup-output
creating supout.rif file, might take a while
Done!
[admin@MikroTik] >
To see the files stored on the router:
[admin@MikroTik] > file print
 # NAME                            TYPE         SIZE       CREATION-TIME
 0 supout.rif                      unknown      108787     dec/24/2003 10:12:38
[admin@MikroTik] >
Connect to the router using FTP and download the supout.rif file using BINARY file transfer mode. Send the supout.rif file to MikroTik Support support@mikrotik.com with detailed description of the problem.
Important!
Support output contains: Configuration export, Installed packages, Resource usage information, Firewall and queue statistics, Log files
It does NOT contain: Passwords for accessing the router
