BGP (Border Gateway Protocol)
Document revision:1.2 (Thu Mar 04 19:34:34 GMT 2004)
Applies to: V2.8
General Information
Summary
The Border Gateway Protocol (BGP) allows setting up an interdomain dynamic routing system that automatically generates the routing table for routing between autonomous systems (AS).
MikroTik RouterOS supports BGP Version 4, as defined in RFC1771.
The MikroTik RouterOS implementation of the BGP has filtering (using prefix lists) feature
Specifications
Packages required: routing
License required: Level3
Submenu level: /routing bgp
Standards and Technologies: RFC1771
Hardware usage: requires additional RAM for storing routing information (128MB recommended)
Related Documents
Description
The Border Gateway Protocol (BGP) is an Exterior Gateway Protocol (EGP). It allows setting up an interdomain routing system that automatically guarantees the loop-free exchange of routing information between autonomous systems (AS). It is widely used in companies assigned with a definite IP address ranges and connected to a nubmer of ISPs simultaneously so that if one of the links is down, the IP address ranges are still reachable via an another ISP.
The MikroTik RouterOS implementation of the BGP supports filtering with prefix lists, that is used for filtering received and sent routing information.
The routes learned by BGP protocol are installed in the route list with the distance of 200 for iBGP (Internal BGP) routes and of 20 for eBGP (External BGP) routes.
Additional Resources
BGP Setup
Property Description
enabled (yes | no; default: no) - enable or disable BGP
as (integer; default: 1) - autonomous system number
router-id (IP address; default: 0.0.0.0) - the Router identification in form of an IP address
redistribute-connected (yes | no) - if enabled, the router will redistribute the information about all connected routes, i.e., routes to the networks that can be directly reached
redistribute-static (yes | no; default: no) - if enabled, the router will redistribute the information about all static routes added to its routing database, i.e., routes that have been created using the /ip route add command on the router
redistribute-rip (yes | no; default: no) - if enabled, the router will redistribute the information about all routes learned by RIP protocol
redistribute-ospf (yes | no; default: no) - if enabled, the router will redistribute the information about all routes learned by the OSPF protocol
state (read-only: disabled | running | terminating) - status of the BGP
disabled - not working, has been disabled
running - working
terminating - shutting down, flushing all route information
Notes
Usually, you want to redistribute connected and static routes, if any. Therefore change the settings for these arguments and proceed to the BGP networks.
Example
To enable BGP protocol specifying that router 192.168.0.206, that belongs to the 65002 AS, should redistribute the connected routes
[admin@MikroTik] routing bgp>
[admin@MikroTik] routing bgp> print
                   enabled: yes
                        as: 65002
                 router-id: 192.168.0.206
       redistribute-static: no
    redistribute-connected: yes
          redistribute-rip: no
         redistribute-ospf: no
                     state: running
BGP Network
Submenu level: /routing bgp network
Description
BGP Networks is a list of the networks to be advertised.
network (IP address mask; default: 0.0.0.0/0) - network to advertise
Notes
You can add to the list as many networks as required.
The router is not checking whether the network is in the routing table, it always advertises all the routes that are specified here.
Note the difference with OSPF, that use network list for different purpose - to determine where to send updates.
Example
To advertise the network 159.148.150.192/27:
[admin@modux] routing bgp network> add network=159.148.150.192/27
[admin@modux] routing bgp network> print
 # NETWORK
 0 159.148.150.192/27
BGP Peers
Submenu level: /routing bgp peer
Description
You need to specify the BGP peer with whom you want to exchange the routing information. The BGP exchanges routing information only if it can establish a TCP connection to its peer. You can add as many peers as required.
remote-address (IP address; default: 0.0.0.0) - address of the remote peer
remote-as (integer; default: 0) - AS number of the remote peer
multihop (yes | no; default: no) - if enabled, allows BGP sessions, even when the neighbour is not on a directly connected segment. The multihop session is not established if the only route to the multi-hop peer's address is the default route (0.0.0.0/0)
route-reflect (yes | no; default: no) - defines whether to redistribute further the routes learned from router of the same AS or not. If enabled, can significantly reduce traffic between routers in the same AS
prefix-list-in (name; default: "") - name of the filtering prefix list for receiving routes
prefix-list-out (name; default: "") - name of the filtering prefix list for advertising routes
state (read-only: connected | not-connected) - the status of the BGP connection to the peer
routes-received - the number of received routes from this peer
Example
To enable routing information exchange with the neighbour (non-multihop) 192.168.0.254 that belongs to 65002 AS:
[admin@MikroTik] routing bgp peer> add remote-address=192.168.0.254 remote-as=65002
[admin@MikroTik] routing bgp peer> print
  # REMOTE-ADDRESS  REMOTE-AS MULTIHOP ROUTE-REFLECT PREFIX-LIS... PREFIX-LI...
  0 192.168.0.254   65002     no       no            none          none
[admin@MikroTik] routing bgp> peer print status
  # REMOTE-ADDRESS  REMOTE-AS STATE          ROUTES-RECEIVED
  0 192.168.0.254   65002     connected      1
Troubleshooting
Description
