MikroTik RouterOS simplifies the creation and deployment of a sophisticated firewall policies. In fact, you can easily create a simple one to filter your traffic or enable source NAT without need to know how packets are processed in the router. But in case you want to create more complicated policies, it is worth to know the underlying process details. IP packet flow through the router is depicted in the following diagram:
As we can see, a packet can enter the conveyer in two ways: whether the packet has come from an interface or whether it has been originated by the router. Analogically, a packet has two ways to leave the conveyer: through an outgoing interface or, in case the packet is locally destined, in the local process.
When the packet arrives to the router's interface, firewall rules are applied in the following order:
Additional arrows from IPsec boxes shows the processing of encrypted packets (they need to be encrypted / decrypted first and then processed as usual, id est from the point an typical packet enters the router).
If the packet is bridged one, the 'Routing Decision' changes to 'Bridge Forwarding Decision'. And in case the bridge is forwarding non-IP packets, all things regarding IP protocol are not applicable ('Universal Client', 'Conntrack', 'Mangle', et cetera).
The chain input is used to process packets entering the router through one of the interfaces with the destination of the router. Packets passing through the router are not processed against the rules of the input chain.
The chain forward is used to process packets passing through the router.
The chain output is used to process originated from the router and leaving it through one of the interfaces.
Packets passing through the router are not processed against the rules of the output chain.
These three chains cannot be deleted.
When processing a chain, rules are taken from the chain in the order they are listed there from the top to the bottom. If it matches the criteria of the rule, then the specified action is performed on the packet, and no more rules are processed in that chain. If the packet has not matched any rule within the chain, then the default policy action of the chain is performed.
The available policy actions are:
Usually packets should be matched against several criteria. More general filtering rules can be grouped together in a separate chain. To process the rules of additional chains, the jump action should be used to this chain from another chain.
The policy of user added chains is none, and it cannot be changed. Chains cannot be removed, if they contain rules (are not empty).
[admin@MikroTik] ip firewall> print # NAME POLICY 0 input accept 1 forward accept 2 output accept [admin@MikroTik] ip firewall>To add a new chain, use the /ip firewall add command:
[admin@MikroTik] ip firewall> add name=router [admin@MikroTik] ip firewall> print # NAME POLICY 0 input accept 1 forward accept 2 output accept 3 router none [admin@MikroTik] ip firewall>
[admin@MikroTik] ip firewall rule input> add dst-port=8080 protocol=tcp action=reject [admin@MikroTik] ip firewall rule input> print Flags: X - disabled, I - invalid 0 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:8080 out-interface=all protocol=tcp icmp-options=any:any tcp-options=any connection-state=any flow="" sconnection="" content="" rc-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=reject log=no [admin@MikroTik] ip firewall rule input>
[admin@MikroTik] system logging facility> set Firewall-Log logging=local [admin@MikroTik] system logging facility> print # FACILITY LOGGING PREFIX REMOTE-ADDRESS REMOTE-PORT ECH 0 Firewall-Log local no 1 System-Info local no 2 System-Error local no 3 System-Warning local no 4 Prism-Info local no 5 Web-Proxy-Access local no 6 Hotspot-Account local no 7 OSPF-Info local no 8 Hotspot-Error local no 9 IPsec-Event local no 10 IKE-Event local no 11 IPsec-Warning local no 12 System-Echo local yes [admin@MikroTik] system logging facility>
You can send UDP log messages to a remote syslog host by specifying the remote address and port (usually 514). Local logs can be viewed using the /log print command:
[admin@MikroTik] > log print without-paging ... mar/11/2003 17:44:55 chain added by admin mar/11/2003 17:45:51 rule added by admin mar/11/2003 18:00:26 web proxy cache size is limited by memory size [admin@MikroTik] >
dst-address (IP adress; default: 0.0.0.0/0:0-65535)
- destination IP address
src-address (IP adress; default: 0.0.0.0/0:0-65535) - source IP address
flow - flow mark to match. Only packets marked in the MANGLE would be matched
limit-time (time; default 0) - time interval, used in
limit-count
protocol (ah | egp | ggp | icmp | ipencap | ospf | rspf | udp | xtp | all | encap | gre |
idpr-cmtp | ipip | pup | st | vmtp | ddp | esp | hmp | igmp | iso-tp4 | rdp | tcp | xns-idp;
default: any) - protocol setting. The value all cannot be used, if you want
to specify ports
icmp-options (default: any:any) - ICMP options
content (text; default: "") - the text packets should contain in order to
match the rule
comment (text; default: "") - a descriptive comment for the rule
connection (text; default: "") - connection mark to match. Only connections (including
related) marked in the MANGLE would be matched
limit-burst (integer; default: 0) - allowed burst regarding the
limit-count/limit-time
limit-count(integer; default: 0) - how many times to use the rule
during the limit-time period
src-netmask (IP address) - source netmask in decimal form x.x.x.x
src-port (port) - source port number or range (0-65535). 0 means all
ports 1-65535
dst-netmask (IP address) - destination netmask in decimal form x.x.x.x
dst-port (integer) - destination port number or range (0-65535). 0 means all ports 1-65535
Masquerading helps to ensure security since each outgoing or incoming request must go through a translation process that also offers the opportunity to qualify or authenticate the request or match it to a previous request. Masquerading also conserves the number of global IP addresses required and it lets the whole network use a single IP address in its communication with the world.
[admin@MikroTik] ip firewall src-nat> add src-address=10.5.91.0/24:0 \ \... out-interface=Public action=masquerade [admin@MikroTik] ip firewall src-nat> print Flags: X - disabled, I - invalid, D - dynamic 0 src-address=10.5.91.0/24:0-65535 dst-address=0.0.0.0/0:0-65535 out-interface=Public protocol=all icmp-options=any:any flow="" connection="" content="" limit-count=0 limit-burst=0 limit-time=0s action=masquerade to-src-address=0.0.0.0 to-src-port=0-65535 [admin@MikroTik] ip firewall src-nat>If the packet matches the masquerade rule, then the router opens a connection to the destination, and sends out a modified packet with its own address and a port allocated for this connection. The router keeps track about masqueraded connections and performs the "demasquerading" of packets, which arrive for the opened connections. For filtering purposes, you may want to specify the to-src-ports argument value, say, to 60000-65535.
If you want to change the source address:port to specific adress:port, use the action=nat instead of action=masquerade:
[admin@MikroTik] ip firewall src-nat> add src-address=192.168.0.1/32 action=nat \ \... out-interface=Public to-src-address=10.10.10.5 [admin@MikroTik] ip firewall src-nat> print Flags: X - disabled, I - invalid, D - dynamic 4 src-address=192.168.0.1/32:0-65535 dst-address=0.0.0.0/0:0-65535 out-interface=Public protocol=all icmp-options=any:any flow="" connection="" content="" limit-count=0 limit-burst=0 limit-time=0s action=nat to-src-address=10.10.10.5 to-src-port=0-65535 [[admin@MikroTik] ip firewall src-nat>
Here, the
src-address - can be IP host's address, for example, 192.168.0.1/32,
or network address 192.168.0.0/24
to-src-address - can be one address, or a range, say 10.0.0.217-10.0.0.219.
The addresses should be added to the router's interface, or should be routed to it
from the gateway router.
The source nat can masquerade several private networks, and use individual to-src-address for each of them.
[admin@MikroTik] ip firewall dst-nat> add action=nat protocol=tcp \ \... dst-address=10.0.0.217/32:80 to-dst-address=192.168.0.4 [admin@MikroTik] ip firewall dst-nat> print Flags: X - disabled, I - invalid, D - dynamic 0 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=10.0.0.217/32:80 protocol=tcp icmp-options=any:any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=nat to-dst-address=192.168.0.4 to-dst-port=0-65535 [admin@MikroTik] ip firewall dst-nat>Here, if you want to redirect to the router's local address, use action=redirect and do not specify the to-dst-address.
When packet is dst-natted (no matter - action=nat or action=redirect), dst address is changed. Information about translation of addresses (including original dst address) is kept in router's internal tables. Transparent web proxy working on router (when web requests get redirected to proxy port on router) can access this information from internal tables and get address of web server from them. If you are dst-natting to some different proxy server, it has no way to find web server's address from IP header (because dst address of IP packet that previously was address of web server has changed to address of proxy server). Starting from HTTP/1.1 there is special header in HTTP request which tells web server address, so proxy server can use it, instead of dst address of IP packet. If there is no such header (older HTTP version on client), proxy server can not determine web server address and therefore can not work.
It means, that it is impossible to correctly transparently redirect HTTP traffic from router to some other transparent-proxy box. Only correct way is to add transparent proxy on the router itself, and configure it so that your "real" proxy is parent-proxy. In this situation your "real" proxy does not have to be transparent any more, as proxy on router will be transparent and will forward proxy-style requests (according to standard; these requests include all necessary information about web server) to "real" proxy.
It is also possible to mark the packets associated (including related) with the same connection as the marked packet (in other words, to mark a connection with all related connections, you need to mark only one packet belonging to that connection).
You may also want to change the TCP Maximum Segment Size (MSS), to a value which is your desired MTU value less 40. The MSS can be set only for TCP SYN packets.
[admin@MikroTik] ip firewall mangle> add action=passthrough mark-flow=abc-all [admin@MikroTik] ip firewall mangle> print Flags: X - disabled, I - invalid, D - dynamic 0 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 protocol=all tcp-options=any icmp-options=any:any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=passthrough mark-flow=abc-all tcp-mss=dont-change mark-connection="" [admin@MikroTik] ip firewall mangle>To change the MSS, adjust the tcp-mss argument. For example, if your if you have encrypted PPPoE link with MTU = 1492, you can set the mangle rule as follows:
[admin@MikroTik] ip firewall mangle> add protocol=tcp tcp-options=syn-only\ \.. action=passthrough tcp-mss=1448 [admin@MikroTik] ip firewall mangle> print Flags: X - disabled, I - invalid, D - dynamic 0 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 protocol=tcp tcp-options=syn-only icmp-options=any:any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=passthrough mark-flow="" tcp-mss=1448 mark-connection="" [admin@MikroTik] ip firewall mangle>
[admin@MikroTik] ip firewall connection> print Flags: U - unreplied, A - assured # SRC-ADDRESS DST-ADDRESS PR.. TCP-STATE TIMEOUT 0 A 10.5.91.205:1361 10.5.0.23:22 tcp established 4d23h59m55s 1 A 10.5.91.205:1389 10.5.5.2:22 tcp established 4d23h59m21s 2 A 10.5.91.205:1373 10.5.91.254:3986 tcp established 4d23h59m56s 3 A 10.5.91.205:1377 159.148.172.3:23 tcp established 4d23h35m14s 4 A 80.232.241.3:1514 159.148.172.204:1723 tcp established 4d23h59m53s 5 159.148.172.204 80.232.241.3 47 9m21s [admin@MikroTik] ip firewall connection>
[admin@MikroTik] ip firewall service-port> set h323 disabled=yes [admin@MikroTik] ip firewall service-port> print Flags: X - disabled # NAME PORTS 0 ftp 21 1 pptp 2 gre 3 X h323 4 mms 5 irc 6667 6 quake3 [admin@MikroTik] ip firewall service-port>
This can be done by putting rules in the input chain to match packets with the destination address of the router entering the router through all interfaces.
This can be done by putting rules in the forward chain to match packets passing through the router with the destination addresses of customer's network.
This can be done by enabling the masquerading action for source NAT rules.
This can be done by putting rules in the forward chain, or/and by masquerading (source NAT) only those connections, that are allowed.
Examples of setting up firewalls are discussed below.
Assume we want to create a firewall, that:
The basic network setup is in the following diagram:
The IP addresses and routes of the MikroTik router are as follows:
[admin@MikroTik] > ip address print Flags: X - disabled, I - invalid, D - dynamic # ADDRESS NETWORK BROADCAST INTERFACE 0 10.0.0.217/24 10.0.0.0 10.0.0.255 Public 1 192.168.0.254/24 192.168.0.0 192.168.0.255 Local [admin@MikroTik] > ip route print Flags: X - disabled, I - invalid, D - dynamic, J - rejected, C - connect, S - static, R - rip, O - ospf, B - bgp # DST-ADDRESS G GATEWAY DISTANCE INTERFACE 0 S 0.0.0.0/0 r 10.0.0.254 1 Public 1 DC 192.168.0.0/24 r 0.0.0.0 0 Local 2 DC 10.0.0.0/24 r 0.0.0.0 0 Public [admin@MikroTik] >
[admin@MikroTik] > ip firewall rule input [admin@MikroTik] ip firewall rule input> add protocol=tcp tcp-option=non-syn-only \ \... connection-state=established comment="Allow established TCP connections" [admin@MikroTik] ip firewall rule input> add protocol=udp comment="Allow UDP connections" [admin@MikroTik] ip firewall rule input> add protocol=icmp comment="Allow ICMP messages" [admin@MikroTik] ip firewall rule input> add src-addr=10.5.8.0/24 \ \... comment="Allow access from 'trusted' network 10.5.8.0/24" [admin@MikroTik] ip firewall rule input> add action=reject log=yes \ \... comment="Reject and log everything else" [admin@MikroTik] ip firewall rule input> print Flags: X - disabled, I - invalid, D - dynamic 0 ;;; Allow established TCP connections src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=tcp icmp-options=any:any tcp-options=non-syn-only connection-state=established flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 1 ;;; Allow UDP connections src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=udp icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 2 ;;; Allow ICMP messages src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=icmp icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 3 ;;; Allow access from 'trusted' network 10.5.8.0/24 of ours src-address=10.5.8.0/24:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=all icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 4 ;;; Reject and log everything else src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=all icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=reject log=yes [admin@MikroTik] ip firewall rule input>
Thus, the input chain will accept only allowed connections and reject and log everything else.
[admin@MikroTik] ip firewall> add name=customer [admin@MikroTik] ip firewall> print # NAME POLICY 0 input accept 1 forward accept 2 output accept 3 router none 4 customer none [admin@MikroTik] ip firewall> rule customer [admin@MikroTik] ip firewall rule customer> add protocol tcp tcp-option non-syn-only \ \... connection-state=established comment="Allow established TCP connections" [admin@MikroTik] ip firewall rule customer> add protocol udp \ \... comment="Allow UDP connections" [admin@MikroTik] ip firewall rule customer> add protocol icmp \ \... comment="Allow ICMP messages" [admin@MikroTik] ip firewall rule customer> add protocol tcp tcp-option syn-only \ \... dst-address 192.168.0.17/32:80 \ \... comment="Allow http connections to the server at 192.168.0.17" [admin@MikroTik] ip firewall rule customer> add protocol tcp tcp-option syn \ \... dst-address 192.168.0.17/32:25 \ \... comment="Allow smtp connections to the server at 192.168.0.17" [admin@MikroTik] ip firewall rule customer> add protocol tcp tcp-option syn \ \... src-port 20 dst-port 1024-65535 \ \... comment="Allow ftp data connections from servers on the Internet" [admin@MikroTik] ip firewall rule customer> add action reject log yes \ \... comment="Reject and log everything else" [admin@MikroTik] ip firewall rule customer> print Flags: X - disabled, I - invalid 0 ;;; Allow established TCP connections src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=tcp icmp-options=any:any tcp-options=non-syn-only connection-state=established flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 1 ;;; Allow UDP connections src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=udp icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 2 ;;; Allow ICMP messages src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=icmp icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 3 ;;; Allow http connections to the server at 192.168.0.17 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=192.168.0.17/32:80 out-interface=all protocol=tcp icmp-options=any:any tcp-options=syn-only connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 4 ;;; Allow smtp connections to the server at 192.168.0.17 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=192.168.0.17/32:25 out-interface=all protocol=tcp icmp-options=any:any tcp-options=syn-only connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 5 ;;; Allow ftp data connections from servers on the Internet src-address=0.0.0.0/0:20 in-interface=all dst-address=0.0.0.0/0:1024-65535 out-interface=all protocol=tcp icmp-options=any:any tcp-options=syn-only connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 6 ;;; Reject and log everything else src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=all protocol=all icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=reject log=yes [admin@MikroTik] ip firewall rule customer>
Note about the rule #5: active ftp data connections are made from the server's port 20 to the client's tcp port above 1024.
All we have to do now is to put rules in the forward chain, that match the IP addresses of the customer's hosts on the Local interface and jump to the customer chain:
[admin@MikroTik] ip firewall rule forward> add out-interface=Local action=jump \ \... jump-target=customer [admin@MikroTik] ip firewall rule forward> print Flags: X - disabled, I - invalid 0 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=Local protocol=all icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=jump jump-target=customer log=no [admin@MikroTik] ip firewall rule forward>
Thus, everything that passes the router and leaves the Local interface (destination of the customer's network) will be processed against the firewall rules of the customer chain.
[admin@MikroTik] ip firewall rule forward> add protocol icmp out-interface Public \ \... comment="Allow ICMP ping packets" [admin@MikroTik] ip firewall rule forward> add src-address 192.168.0.17/32 out-interface \ \... Public comment="Allow outgoing connections form the server at 192.168.0.17" [admin@MikroTik] ip firewall rule forward> add action reject out-interface Public log yes \ \... comment="Reject and log everything else" [admin@MikroTik] ip firewall rule forward> print Flags: X - disabled, I - invalid 0 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=Local protocol=all icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=jump jump-target=customer log=no 1 ;;; Allow ICMP ping packets src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=Public protocol=icmp icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 2 ;;; Allow outgoing connections form the server at 192.168.0.17 src-address=192.168.0.17/32:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=Public protocol=all icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=accept log=no 3 ;;; Reject and log everything else src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=0.0.0.0/0:0-65535 out-interface=Public protocol=all icmp-options=any:any tcp-options=any connection-state=any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=reject log=yes [admin@MikroTik] ip firewall rule forward>
To use masquerading, a source NAT rule with action 'masquerade' should be added to the firewall configuration:
[admin@MikroTik] ip firewall src-nat> add action=masquerade out-interface=Public [admin@MikroTik] ip firewall src-nat> print Flags: X - disabled, I - invalid 0 src-address=0.0.0.0/0:0-65535 dst-address=0.0.0.0/0:0-65535 out-interface=Public protocol=all icmp-options=any:any flow="" connection="" content="" limit-count=0 limit-burst=0 limit-time=0s action=masquerade to-src-address=0.0.0.0 to-src-port=0-65535 [admin@MikroTik] ip firewall src-nat>
All outgoing connections from the network 192.168.0.0/24 will have source address 10.0.0.217 of the router and source port above 1024. No access from the Internet will be possible to the Local addresses. If you want to allow connections to the server on the local network, you should use destination Network Address Translation (NAT).
Assume you need to configure the MikroTik router for the following network setup, where the server is located in the private network area:
The server has address 192.168.0.4, and we are running web server on it that listens to the TCP port 80. We want to make it accessible from the Internet at address:port 10.0.0.217:80. This can be done by means of destination Network Address Translation (NAT) at the MikroTik Router. The Public address:port 10.0.0.217:80 will be translated to the Local address:port 192.168.0.4:80. One destination NAT rule is required for translating the destination address and port:
[admin@MikroTik] ip firewall dst-nat> add action=nat protocol=tcp \ \... dst-address=10.0.0.217/32:80 to-dst-address=192.168.0.4 [admin@MikroTik] ip firewall dst-nat> print Flags: X - disabled, I - invalid 0 src-address=0.0.0.0/0:0-65535 in-interface=all dst-address=10.0.0.217/32:80 protocol=tcp icmp-options=any:any flow="" connection="" content="" src-mac-address=00:00:00:00:00:00 limit-count=0 limit-burst=0 limit-time=0s action=nat to-dst-address=192.168.0.4 to-dst-port=0-65535 [admin@MikroTik] ip firewall dst-nat>
Read about connection tracking at
http://www.cs.princeton.edu/~jns/security/iptables/iptables_conntrack.html
Read more about NAT in RFC2663
